More horsepower... - Mustang Evolution
Old 02-05-2014, 11:41 AM   #1
Megan's Avatar
More horsepower...
I have an 08 GT and it's all stock. I want more horsepower though and I want to make it louder. I have a functional scoop so I was told I don't need to change my air intake, is that true? I started looking into turbo's and superchargers but they're really expensive if I buy them new. So far the cheapest I found was $6k. I don't have that kind of money to put up front. Is there another way I can work on increasing my HP but in piece work? I hope that doesn't sound silly. Any help or advice would be appreciated!! Thanks!
Megan is offline   Reply With Quote
Old 02-05-2014, 11:54 AM   #2
Loc: Austin,TX
Start with a basic handheld tuner like SCT. If this is your first experience with a tuner I would go with American Muscle and a Bama race tune. I suggest this because its a email tune and their customer service is top notch. When you decide later down the line to add more high end parts you can switch to a different tuner or dyno tune.
You can add a H or X mid pipe for some extra HP or do a full exhaust with longtubes and mid pipe. On my 07 I did Longtubes,H pipe,High flow cats,CAI with 93 octane Bama race tune and 4.10 gears all at the same time. It was a completely different car after that and put me right at 300HP to the wheels which makes for a fun little toy.
Here she sat....Shaundra was her name.
Old 02-05-2014, 12:10 PM   #3
Rapinator126's Avatar
Full exhaust. Intake. Motion delete plates. And a set of hot rid cams to start.
---------- Post added at 01:10 PM ---------- Previous post was at 01:09 PM ----------
*rod
Old 02-05-2014, 12:16 PM   #4
bucko's Avatar
I would also question the functionality of the "functional scoop" relating to the air intake. Is it the replica Mach 1 shaker hood scoop that connects to the air intake box? If not, then its most likely just allowing some air into the engine area through the center, which is not helping the air intake by much at all.
The older muscle cars used to have a scoop (like the Mach 1 Mustangs) that had a shaker hood scoop directly over the carb/air cleaner. This is not the case today, unless you have one of those types of setups. There is a "shaker hood scoop" kit sold for some late model Mustangs.
Old 02-05-2014, 12:30 PM   #5
Loc: Austin,TX
*rod
Good idea on the cams. LTs with the cams for more power.
Old 02-05-2014, 04:45 PM   #6
Megan's Avatar
Shaundra, love her! Lol.
Thank you so much! I've been looking at American Muscle, they have a lot info and parts. Their videos help too. I'm going to attach a picture of my car with the scoop, I don't know if that helps determine it's functionality with the air intake... Should I take a picture of underneath the good too? Click image for larger version
Name:	ImageUploadedByMustang Evolution1391643803.753589.jpg
Old 02-05-2014, 04:46 PM   #7
Megan's Avatar
***underneath the hood too*** is what I meant to write. Sorry.
Old 02-05-2014, 05:41 PM   #8
That scoop will do nothing but release heat. Your air cleaner is up in right front corner pulling in the cooler air. Upgrade full exhaust is a great start it just get more fun and expensive from there ! Lol good luck with the build.
royalpurple is offline   Reply With Quote
Old 02-05-2014, 07:27 PM   #9
Pop the hood and give us a pic at the engine. If there is a tube leading to where your intake is then it's functional.
Old 02-05-2014, 07:42 PM   #10
Loc: Austin,TX
Yeah,that looks like a shaker kit. Post some under hood pics.
Old 02-05-2014, 10:25 PM   #11
Megan's Avatar
Okay, I'll have to wait until morning since it's night and I don't have a strong enough light to illuminate it all.
Old 02-05-2014, 10:44 PM   #12
2 Stangz's Avatar
Region: Nevada
I tuned my 3v 4.6 two weeks ago and I still haven't gotten used to the 'newly awoken' power. Can't believe how much Ford left on the table. I was going to continue with bolt-ons and exhaust but now I'm thinking I need to tackle my suspension before I can put anymore power to the ground.
Old 02-05-2014, 11:00 PM   #13
Loc: Austin,TX
You will be good on stock suspension with what you have now. You probably haven't even hit 300WHP with just that tune. Get some LTs and a O/R H.
Old 02-05-2014, 11:17 PM   #14
2 Stangz's Avatar
Region: Nevada
JBA LT's and catted h-pipe are next on the list. I've had two issues since I've tuned my GT; rear tires spinning out a lot more and the increased throttle response causing the rear end to squat excessively accelerating from a stop.
Maybe a new LCA and some new springs and struts at the very least would address those issues?
Old 02-05-2014, 11:17 PM   #15
Tires is all you really need for your power level
Old 02-05-2014, 11:19 PM   #16
2 Stangz's Avatar
Region: Nevada
I've got the factory Pirelli P Zero Neros on right now... Although I've heard summer tires like those just suck in the cold weather.
Old 02-05-2014, 11:20 PM   #17
Loc: Austin,TX
Some good sticky tires really help. You will be able to feel the difference if you have never had a good set of stickies. Its a DD right?
Old 02-05-2014, 11:24 PM   #18
A really good daily tire is the Mickey Thompson sport comps. I run these for my every day tires. No offense but the p zeros suck.
Old 02-05-2014, 11:25 PM   #19
Street comps i mean. I run a 285/35/19. I make 440 to the tire on motor and they do a dam good job
Old 02-05-2014, 11:25 PM   #20
2 Stangz's Avatar
Region: Nevada
I'll look into that. I have to keep in mind my GT is my DD.
Old 02-05-2014, 11:28 PM   #21
Now if you want a drag radial. NT05R is the way to go.
Old 02-05-2014, 11:30 PM   #22
2 Stangz's Avatar
Region: Nevada
How much do those street comps go for? And NT05R's too?
Old 02-05-2014, 11:33 PM   #23
285/35/19 street comps i paid $560 mounted balances out the door at discount tiré. And for the NT05r's i paid $650 mounted balanced out the door they are 305/35/19
Old 02-05-2014, 11:38 PM   #24
2 Stangz's Avatar
Region: Nevada
Huh... Cheaper than new Pirelli's. Found this thread about them... They do just suck in the winter
Pirelli Pzero Nero in cold weather = NO traction
Old 02-05-2014, 11:43 PM   #25
Loc: Austin,TX
I'm running the KDW2s (285/30/20 R) and couldn't be happier but I will look into the Street comps now that you brought them up. Mine isnt a DD though.
Old 02-05-2014, 11:51 PM   #26
The KDW2s are dam good also. Only downside to the mickeys is the widest they come in for a 19 is a 285. U can get them for $250 à piece from AM B4 discount.
Old 02-05-2014, 11:57 PM   #27
Loc: Austin,TX
How are those street comps as far as wear on a DD?
Old 02-06-2014, 12:04 AM   #28
Really good actually. I light mine up daily also. Still nowhere near the wear indicator
Old 02-06-2014, 12:13 AM   #29
Loc: Austin,TX
Well I've put less than 8k on my KDWs (and 5.0) in 3 years and they are nowhere close to being wore out. I got warned about wear before I bought them but so far so good.
Old 02-06-2014, 12:19 AM   #30
I put the street comps on when i did the built motor. So i have roughly 1,400 miles on them
Old 02-06-2014, 11:10 AM   #31
Megan's Avatar
Name:	ImageUploadedByMustang Evolution1391710192.488749.jpg
ID:	147185Click image for larger version
Name:	ImageUploadedByMustang Evolution1391710200.706892.jpg
ID:	147186Click image for larger version
Name:	ImageUploadedByMustang Evolution1391710208.807019.jpg
I checked and it says I have a Shaker in my car. What does that mean? Does that change anything??
Old 02-11-2014, 03:50 PM   #32
Excretionx's Avatar
Intake,headers,throttle body,exhaust, and tie it all together with tube
Excretionx is offline   Reply With Quote
Old 02-11-2014, 03:59 PM   #33
2 Stangz's Avatar
Region: Nevada
Two big power packs from Ford Racing:
375 hp - FORD RACING 2005-2010 4.6L INTAKE/CAMS/THROTTLE BODY POWER PACKAGE -- M-FR5-S197
440 hp (all motor) - Ford Racing 2005-2010 Mustang GT 400HP+ Top End Power Package -- M-FR4-S197
I picked up an extra 35 horsepower today ronnie948 2011-2014 V6 Mustang 51 06-13-2013 05:32 AM
rated horsepower on 99 explorer Robbie94gt 1979-1995 Mustang GT 3 02-05-2012 02:17 PM
Accel-erate Your 2011+ Mustang’s Horsepower with Coil-On-Plugs! AMDanBailer 2011-2014 Mustang GT 13 01-11-2012 09:00 PM
9 Mustangs and 7,176 Horsepower on the Dyno & Track AMDanBailer AmericanMuscle 0 11-16-2011 04:22 PM
6 Cylinder Horsepower Tuch65 Classic Mustangs 9 08-16-2011 04:36 AM
11:53 AM
