95 mustang 5.0 - Mustang Evolution
Old 02-05-2014, 10:01 PM   #1
95 mustang 5.0
So I got a 95 mustang and the engine went bad on it.. I'm looking at a 302 5.0 v8 and I was wondering.. will I need to replace the Tranny too or could I keep the original one?? Plz help me out!
95stangking45 is offline   Reply With Quote
Old 02-06-2014, 11:58 AM   #2
89GTstanger's Avatar
What engine is in it now?
You can't lose if you put God first!
1989 LX, 306 with TF top end kit, Anderson N-21 cam, TKO 600 trans with steel splatter shield,full Maximum Motorsports Mustang maximum Grip box, Detroit locker rear end with 31 spline Moser axles. Staggered wheels with Nitto 555 315/35/17 out back.
89GTstanger is offline   Reply With Quote
Old 02-06-2014, 12:08 PM   #3
The original 3.8 v6 but it's garbage haha
Old 02-06-2014, 12:45 PM   #4
Your trans should bolt up but I believe the gearings are different than the V8 5 speed. I believe the rear end is different also. I dont think its the 8.8. Maybe someone else will chime in and clarify some of this. I've never had a V6 or done the swap. Not sure what kind of power the V6 trans and rear will hold either. Obviously you XAN put the V8 in and drive the car without problems but I'm just not sure how it will hold up to abuse.
Old 02-06-2014, 12:50 PM   #5
Yea or I'm have a v6 the original one but of a donar car would that bolt right up no problem and would I be able to throw on a turbo onto the stock engine? It's only got 90,xxx on it
Old 02-06-2014, 01:17 PM   #6
Yeah if you had a 94-95 donar car everything would swap rite over. You can't use an older T-5 because the input shaft is shorter. The rear end is also narrower on the fox body cars. The trans in the 96-98 will also fit but those are the T-45 trans and I believe those would just bolt rite up also.
As for the turbo, I can't answer that question with confidence because I've never had or used one. Personally I would take all that money and put heads, cam and intake on it with 70mm TB and 73mm C&L CAI and then have it all tuned.
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
FJ Cruiser to Mustang 5.0 AveryPlaysBass 2011-2014 Mustang GT 5 12-13-2013 02:10 PM
03 5.0 mustang? Doe_Rae_mi 1996-2004 Mustang GT 3 12-02-2011 05:25 PM
06:06 PM
