1969 Mustang 302 - Mustang Evolution
Old 02-08-2014, 08:45 AM   #1
c_walsh97's Avatar
1969 Mustang 302
Hey guys currently I'm 16 and I have a 2007 mustang v6 and I've been looking to get an older one and I have an opportunity at a sweet trade for a 1969 Mustang 302 and I was wondering would the 69 be faster and what I could do to make it a lot faster and get the most power out out of the v8?
c_walsh97 is offline   Reply With Quote
Old 02-08-2014, 12:41 PM   #2
Check the car over carefully! Rust and body repair is super expensive to do. Older cars are pretty easy to hop up just do some reading or google it.
---------- Post added at 07:41 PM ---------- Previous post was at 07:41 PM ----------
And in any car gears can make it feel like a new machine!
royalpurple is offline   Reply With Quote
Old 02-08-2014, 01:50 PM   #3
89GTstanger's Avatar
Unless you have mechanical skill and body repair know how I would keep the 07. If you really do want the 69, and I dont blame you, make sure you crawl UNDER the car and check the floor pans, rocker panels, truck pans and all the points where the suspension bolts to the car for rust. More than likely tho all the bushings are going to need replace under the car. Its probably going to need shocks and the brakes are not going to be what you are use to. When you go to check the car out tell the guy you want it cold when you get their. Then check ALL the fluids. I like to take the oil filter off and look for glitter,metal, flakes in the oil. If it does have it then you dont want it. If it passes all the fluid tests then start it and listen for unusual sounds from the engine. Maybe a slight knocking or valve train clatter. It will make the most noise cold, hense the reason you want it cold when you get there. If it all sounds good then your ready for a test drive. Watch for smoke as you give it gas as that's a sign of bad rings or valve seals. Good luck man, if you do get it post some pics.
You can't lose if you put God first!
1989 LX, 306 with TF top end kit, Anderson N-21 cam, TKO 600 trans with steel splatter shield,full Maximum Motorsports Mustang maximum Grip box, Detroit locker rear end with 31 spline Moser axles. Staggered wheels with Nitto 555 315/35/17 out back.
89GTstanger is offline   Reply With Quote
Old 02-08-2014, 01:56 PM   #4
c_walsh97's Avatar
Thanks man and the reason I'm doing this is because my license is supended for 6 months because of a little trouble so I would have a lot of time to work on it and stuff and he says he uses it a lot?
Name:	ImageUploadedByMustang Evolution1391892903.949254.jpg
ID:	147361Click image for larger version
Name:	ImageUploadedByMustang Evolution1391892915.570083.jpg
ID:	147362Click image for larger version
Name:	ImageUploadedByMustang Evolution1391892924.816582.jpg
ID:	147363Click image for larger version
Name:	ImageUploadedByMustang Evolution1391892934.107189.jpg
Old 02-09-2014, 09:02 AM   #5
JMoney's Avatar
That is one sexy car
2012 Mustang V6 Performance White 6AT- Airaid CAI, Borla ATAKS, and Bama 93H Tune
JMoney is offline   Reply With Quote
Old 02-09-2014, 09:05 AM   #6
+1
Looks like its in better shape than I assumed...lol. I would still check for rust tho.
Old 02-09-2014, 09:18 AM   #7
c_walsh97's Avatar
+1
Yeah and do you know what steps I should do in order to improve the engine and the prices and ways I can get the most power out of it?
Old 02-09-2014, 09:32 AM   #8
There is a lot that you can do. What kind of budget are you looking at? Try to find out what been done to up to today.
Old 02-09-2014, 04:23 PM   #9
c_walsh97's Avatar
I don't know what's been done but I'm only 16 so affordable stuff?
Old 02-09-2014, 04:36 PM   #10
Well for those I like the edelbrock air gap intakes. That's a little over 200 if I remember correctly. Headers, I would go long tube, and an h-pipe. A k&n air filter. And a Cam. That would require new springs also. And always put new lifters in with a cam. If you do a little at a time it won't be to expensive. If you put it all on at the same time you'll notice a HUGE difference.
1969 mustang
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
Latest news on the 2015 Mustang!!! blackbeast12 2015+ Mustang Ecoboost (and V6) 48 08-20-2013 01:09 PM
Does Our 2012 Boss 302 Mustang Sound Insane or What?! Read more: VIDEO: Does Our 201 AMDanBailer AmericanMuscle 0 01-27-2012 03:51 PM
11:21 AM
