injectors - Mustang Evolution
Old 02-09-2014, 05:58 PM   #1
Jar72's Avatar
injectors
Question. Gt40 heads explorer intake long tube headers. 65mm throttle body. Cold air intake.
What size injectors?
JMF
Jar72 is offline   Reply With Quote
Old 02-09-2014, 06:48 PM   #2
89GTstanger's Avatar
I would put 24# in and the lose are good for like 400+ HP. They would support most of your upgrades up to nitrous or FI.
You can't lose if you put God first!
1989 LX, 306 with TF top end kit, Anderson N-21 cam, TKO 600 trans with steel splatter shield,full Maximum Motorsports Mustang maximum Grip box, Detroit locker rear end with 31 spline Moser axles. Staggered wheels with Nitto 555 315/35/17 out back.
89GTstanger is offline   Reply With Quote
Old 02-09-2014, 06:51 PM   #3
Roguestang's Avatar
What's your plans for the future? You might want to keep future mods in mind too. 24's would be fine, heck you could get away with the stock 19's, pending on a tune.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 02-09-2014, 06:53 PM   #4
I was thinking the same thing but I recommended the 24# BC they will support future upgrade without buying more injectors.
Old 02-09-2014, 09:53 PM   #5
Jar72's Avatar
Well its a highway car pulled the 373 posi out threw in 273 I run 30 miles one way 75(third gear 5 g then ease to 5th lol) to work every day. Future plans are a tune for sure. Msd. Maybe a cam swap depends on selling my harley to buy an older project. Wife or mom may get the stang. I just want to get it set up right took me 2 years to get most of the prev owners BS fixed.
JMF
Old 02-10-2014, 06:35 AM   #6
Roguestang's Avatar
Yeah 24's would be fine
Old 02-10-2014, 06:39 AM   #7
Jar72's Avatar
Will I need a new fuel pump.
JMF
Old 02-10-2014, 07:14 AM   #8
That's crazy!! I could never pull my gears out for a higher gear.. lol. When I went to collision school I had a 3 hour round trip everyday. I had a 94 GT back then. Had a mildly built 302. Had 373 gears in it. I averaged about 22-23 mpg on the highway at 80 mph or more. One thing I've never took into consideration when building my car is gas mileage. If I was to worry about that my car would never be what I want it to be.
As for the fuel pump question... you will need a new one if you want more that about 300hp. The stock pump will starve the engine in higher RPM's. You can either get a 190lph or 255lph. I've always opted for the 255lph just because I like to know all my upgrades are covered. You should notice better throttle response with a new pump also. I know I did.
Old 02-10-2014, 07:17 AM   #9
mystang50's Avatar
stock one will work at lower rpms,,, But I'd recommend bumping it up
Old 02-10-2014, 10:10 PM   #10
Jar72's Avatar
Thanks as for the axle swap it wasfree and the old one was toast still have it need full rebuild then it goes back in . Just not priority right now and I get 21 mpg now was getting 16 before
Sent from my GT-N8013 using Mustang Evolution mobile app
JMF
AmericanMuscle Carries Injector Dynamics Mustang Fuel Injectors AMWill AmericanMuscle 0 01-31-2014 03:04 PM
fuel injectors 1987mustanglx50 1979-1995 Mustang GT 10 01-02-2013 05:01 PM
Fuel injectors? WhiteCobra94 1979-1995 Mustang GT 12 01-05-2012 07:03 PM
Fuel injectors ?? stangstar92 1996-2004 Mustang GT 3 10-05-2011 04:59 PM
60 lb injectors question? CZYFAST 2011-2014 Mustang GT 27 07-19-2011 02:56 PM
05:52 PM
