Changing out rear end - Mustang Evolution
Old 02-10-2014, 02:29 PM   #1
Milehigh STK's Avatar
I'm young and inexperienced and looking to get experienced! What's the best way to swap out the rear? If someone could give me a little step by step instruction that would be awesome! Swapping my 04 7.5 rear with an 04 8.8
Milehigh STK is offline   Reply With Quote
Old 02-10-2014, 02:39 PM   #2
Venomouz831's Avatar
Are you just going to swap the housing of the rear end?
)02 Gt, Founder of WE2G
Old 02-10-2014, 03:07 PM   #3
It's the entire rear
Old 02-10-2014, 03:28 PM   #4
Not that hard took me a couple hours to get it all out. I recommend power tools for the job and an extra set of hands. Take tires off. Remove top and lower bolt of brake, also the shock bolt to drop arm. Will need a 36mm socket to remove bolt from spindle. Will need a 12 socket for the driveshaft remove driveshaft from rear end and let it hang. Now with a rubber mallot hit the end of the spindle and pull the brake towards you. Pull at the other end were it goes in the housing of the rear end. For this you will need muscle and help. After you take em off remove the sway bar that's connected to the frame and the arm. This will be a 19 I believe. After there will be 2 bolts holding up the housing which I believe are 14's. They will have bushings on them. Get a wrench and put it on the top bolt so it doesn't spin. And then 2 more bolts on the side being held to the frame next to the housing. After that everything is off.
Old 02-10-2014, 09:22 PM   #5
Now THAT is exactly what I needed! Thank you so much for your help. And now I'll do it and gain that experience and never have to ask again!
Old 02-10-2014, 09:33 PM   #6
No problem if you run into a problem let us know. I can also post pics of anything you need. Most of my rear end is out
Old 02-10-2014, 10:52 PM   #7
Don't know when exactly I'll have time for this but I'm sure I'll run into some sort of problem
Old 02-10-2014, 11:33 PM   #8
Yea but any one with tools and patience can do it
Old 02-12-2014, 01:42 PM   #9
Mile high JDF's Avatar
Feel free to hit me up if you ever get stuck at some point. I ended up just googling what I needed when I did my IRS swap
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-12-2014, 01:47 PM   #10
Thanks JDF, I will for sure!
Old 03-22-2014, 01:50 PM   #11
For any of the bolts need to be torqued?
Old 03-22-2014, 02:05 PM   #12
What do you mean?
Old 03-22-2014, 02:09 PM   #13
Like to a certain ft/lbs
Old 03-22-2014, 02:13 PM   #14
Got any specific bolts you're thinking of? Most of them I would get pretty tight.
Old 03-22-2014, 02:22 PM   #15
None specific I was just curious
Old 03-22-2014, 03:53 PM   #16
Just make sure everything is pretty tight and you should be good.
Old 03-22-2014, 03:54 PM   #17
Alright thanks!
Old 03-23-2014, 07:18 AM   #18
Yes there are torque values, you are doing a suspension component... Get a Chilton's and that will have your correct numbers.
Old 03-23-2014, 09:26 AM   #19
What exactly I a Chilton's
Old 03-23-2014, 10:59 AM   #20
surfinglbi23's Avatar
Chiltons is a service manual
surfinglbi23 is offline   Reply With Quote
Old 03-23-2014, 11:11 AM   #21
Do I just find one online?
Old 03-23-2014, 12:15 PM   #22
You should be able to find them at any auto parts store.
Old 03-23-2014, 02:15 PM   #23
Eh... some. Most places have Haynes which suck cock.
Sent from my VS980 4G using Mustang Evolution mobile app
Old 03-23-2014, 02:19 PM   #24
So here do I get it then
Old 03-23-2014, 02:25 PM   #25
Old 03-23-2014, 03:02 PM   #26
Hmm I must have a Haynes then. Is Chilton something that you just purchase online?
Old 03-23-2014, 05:14 PM   #27
I'm looking up the torque specs and I think I found them but I'm not sure which bolts are which
Old 03-23-2014, 05:31 PM   #28
Post up the specs and which bolts they are to, or post up a picture of them.
Old 03-23-2014, 06:40 PM   #29
WJL
You should load the axle before tightening
After the housing is in and bolts are snug, you should put jack stands under the axle and lower the car, loading the axle. once all the weight of the car is on the axle you can tighten.
WJL is offline   Reply With Quote
Old 03-23-2014, 06:41 PM   #30
That post is slightly confusing to me
Old 03-23-2014, 06:43 PM   #31
I just want and bought a Haynes so I think I can figure it out!
Old 03-23-2014, 06:49 PM   #32
Never mind I read it wrong. Where on the axel should I put the jack stands? And what is the benefit to this?
Old 03-23-2014, 06:53 PM   #33
WJL
If you tighten the bolts on the control arms (which are the bars that hold the axle) while the suspension is hanging, not supporting the weight of the car. When you put the car back down it will have a tendency to twist or even tear the rubber bushings.
When you remove the existing axle you will have to support the car on jack stands from the body supports which allows the axle to hang. When you tighten the bolts you want the axle in the position it would be in when normally driving to avoid what i explained above. hope that helps
Old 03-23-2014, 06:58 PM   #34
Makes sense! Thanks I'll be sure to do that
Old 03-23-2014, 06:59 PM   #35
WJL
Just make sure they don't interfere with putting the tires on and you will be good
Whine in the rear end Blovett55 Pre-2005 V6 Mustang 21 07-06-2013 07:28 AM
NMRA "Super 'Stang" rules and regulations rebeltx At the Track 4 03-06-2013 11:02 AM
rear end elijah.m.b 2011-2014 V6 Mustang 7 11-28-2011 09:08 PM
Heavy vibration in rear end Blackedout Pre-2005 V6 Mustang 23 09-15-2011 02:35 PM
What size gear for rear end? BlackBeauty01 1996-2004 Mustang GT 21 09-02-2011 08:00 PM
04:38 PM
