Rear end whine normal? - Mustang Evolution
Old 02-10-2014, 03:54 PM   #1
SouthFLV6's Avatar
I here a whining noise coming from my rear end, especially when I'm cruising at high way speeds. I've recently started hearing the noise at most a month ago and have no clue what it is.
My mods:
CAI
Full exhaust
3.73s, which were installed way before I heard the noise
One piece driveshaft
Lowered 1'5in
LCAs
Adjustable UCA
Adjustable pan hard bar
Bama tune
If anyone can help me out it would be much appreciated. Thanks.
SouthFLV6 is offline   Reply With Quote
Old 02-10-2014, 04:06 PM   #2
ArtU's Avatar
Are you sure it is not tire whine? One way to see is reduce your rear tire pressure like 6psi and drive again and see if the pitch of whine changes at the same MPH. Then put the 6PSI back in the tires.
Next find a large large empty parking lot where you can do circles large and tight with the windows down and see if you can hear a whine that changes the tighter you make the circles, and if it changes in sound from left circles to right circles.
If you still are not sure, seek out a local person to check for you. Your shop that put in the gears would be a good choice. How many miles ago was it?
Old 02-10-2014, 04:09 PM   #3
SouthFLV6's Avatar
I can hear the whine at lower speeds, it just not as loud
Old 02-10-2014, 04:09 PM   #4
GrabberMeBlue's Avatar
If you let your foot off the gas does it quiet down or go away and then come back as soon as you step on the gas? Especially if you touch the gas just hard enough to maintain speed but not really accelerate?
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 02-10-2014, 04:09 PM   #5
SouthFLV6's Avatar
That is exactly what it does!
Old 02-10-2014, 04:11 PM   #6
I just added one more line to my original post. Please read and answer.
1979 Gold Trans Am
Old 02-10-2014, 04:13 PM   #7
SouthFLV6's Avatar
yep, still describes it perfectly
Old 02-10-2014, 04:15 PM   #8
It sounds like gear whine. Shorter gears do whine more than taller gears, but if it's getting worse I would definitely get it checked out. It could be as simple as being low on fluid, or it could be more serious.
1979 Gold Trans Am
Old 02-10-2014, 04:17 PM   #9
My 4-wheel drive Dakota does exactly that same thing, but it has done it ever since I bought the truck so I would say mine is normal. I bought it with 95,000 and have 166,000 on it now.
1979 Gold Trans Am
Old 02-10-2014, 04:22 PM   #10
SouthFLV6's Avatar
Alright man, I appreciate the advice. I'll call up the shop that I had them installed and have them take a look. Thanks a lot.
Old 02-10-2014, 04:29 PM   #11
Sure, let us know how it turns out. That will help the next person that searches for a similar problem out here next time.
1979 Gold Trans Am
Old 02-10-2014, 06:50 PM   #12
Abominable Mustang
WhoDat's Avatar
Region: Alaska
When you had the 3.73 gears installed, did they add friction modifier to the gear oil?
American Muscle: Ford Racing Friction Modifier
2012 Kona Blue 3.7L V6:
Old 02-10-2014, 09:22 PM   #13
2011 Kona Blue's Avatar
Yes, friction modifier needs to be added to the gear install.
Old 02-10-2014, 10:34 PM   #14
NewMtang's Avatar
My mods:
CAI
Full exhaust
Lowered 1'5in
LCAs
Adjustable UCA
Bama tune
Perhaps you should state that differently.
"I here a whining noise coming from my rear end."
Instead, I here a whining noise coming from the axle area.
Old 02-11-2014, 08:18 AM   #15
Add the friction modifer
Put it in and I'm sure the noise will totaly disappear.
Old 02-11-2014, 09:08 AM   #16
gt07's Avatar
My mods:
CAI
Full exhaust
Lowered 1'5in
LCAs
Adjustable UCA
Bama tune
The end play was not set properly and may need to be disassembled.....if the friction modifier does not work take it to where you had them installed .....
gt07 is offline   Reply With Quote
Old 02-11-2014, 10:19 AM   #17
Site Sponsor
Sponsor
AMWill's Avatar
Good call bringing it back to the shop who installed the gears! If the noise is "new" and wasn't already existent, than there's most likely an issue with the gearing. I doubt it's because you're missing the friction modifier, as you would have hear this noise a lot sooner. Plus the clutch gears would easily lock up around tight turns.
Hope everything works out for you! Keep us updated.
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 02-11-2014, 03:33 PM   #18
willb2305's Avatar
one thing to mention is aluminum driveshafts will make any noises you have louder as it transmits the noise more. i had my stock driveshaft on for a week after my 373 gears installed and when i switched to the aluminum driveshaft the gear whine got louder but im used to it. also not everyone will use ford friction modifier but im probably one of the few v6 owners that uses a wavetrac lsd which uses helical type gears and any friction modifier makes my lsd work worse. my lsd actually likes friction i have to use super thick synergyn 80w140 gear oil for my lsd. and my brakes actually work about 15% better and stop faster with my lsd upgrade. supposely this lsd is bulletproof uses 9309 steel gears and a billet or forged case and never requires maintenance.
2012 V6
AirRaid CAI, BBK Ceramic LT Headers, BBK Catted X Pipe, Borla ATAK, MPT 93/97 Tune, Steeda LCA's and UCA, Steeda Relocation Brackets, 373 gears, WaveTrac LSD, Dynotech Driveshaft. Prothane Motor Mounts, Whiteline adjustable panhard bar & brace.Ground Control Coilovers with Koni's custom valved. Coming soon Circle D 3800 Stall and Lone Wolf Intake Manifold.
willb2305 is offline   Reply With Quote
Old 02-12-2014, 03:54 AM   #19
bucko's Avatar
Depends on the rear gear oil used. Royal Purple adds in a modifier to their gear oil. I use it, but also add the tube of modifier as well, as I track my car once or twice a month.
Old 02-12-2014, 11:42 AM   #20
SouthFLV6's Avatar
Had them use royal purple. So what do you guys think? Normal for the gears with a one piece driveshaft to whine after a few thousand miles? Or not normal and should have them take a look at her?
Old 02-12-2014, 11:47 AM   #21
A rear differential should not make any noise at all
Take it back to the people that installed the rear and they should fix it at no charge. If they did not put in the friction modifier let them try it to see if it quiets down. If it don't the rear needs to come apart and lapped in.
Old 02-12-2014, 02:29 PM   #22
ArtU's Avatar
It was common for street guys in the 70s to get gears at a local shop at low cost. After months or years they would whine or even get damaged 20k miles later from backlash and other shimming not up to factory standards taking it toll thousands of miles later.
That is why I took mine to the dealer, and paid double a shops price to keep my axle warrentee. They took 2 days to do it right, they had to order a shim size that they didn't have in stock. No I am not trashing the OP here for going to a shop, there are many good shops that do things correctly, but gears have to be done careful to last 100k+ miles.
Something for all folks getting gears to think about.
Old 02-12-2014, 02:44 PM   #23
I would have to respectfully disagree and in fact a dealership would be the last place I would want my gear install too be done at. Simple reason, a gear install is not a common repair or install service a dealership does on a weekly or monthly basis. Other than performance enthusiasts , the majority of customers who owns Fords or mustangs don't do gear swaps.
I would prefer a performance shop who does gear installs on a regular basis complete my gear install. Or a known local shop who has a mechanic that's known for performance installs such as gears and is real familiar with them.
I don't want a Ford mechanic at a dealership who spends 99 percent of his or her time repairing warranty items and gear warranty issues is not one of those things they work on a daily, weekly or monthly basis.
I would personally stay away from dealerships for several reasons but that's just my opinion.
Old 02-12-2014, 02:46 PM   #24
SouthFLV6's Avatar
Just called up the shop that installed the gears and they said that it's normal to have harmonics with gears and a aluminum driveshaft
Old 02-12-2014, 02:49 PM   #25
Well , I must be uncommon because I have a one piece aluminum driveshaft and had my 3:73 gears installed with the one piece and I have no harmonics. Lol
Old 02-12-2014, 03:04 PM   #26
Are they really kidding or are they serious????
That is just plain not true. They just don't want to do it over right this time. It's lucky they are not talking to me. "VERY LUCKY"
The gears are not shimmed properly if the friction reducer did not work.
Check this out>>http://www.ringpinion.com/TechnicalHelp/TechHelp.aspx
Scroll down until you get to why does my rear whine.
It says this:
What is this whirring noise?
Whirring noise only while decelerating at any or all speeds is most likely caused by bad pinion bearings or loose pinion bearing preload, and almost never by bad ring and pinion gears.
A howl or whine during acceleration over a small or large speed range is usually caused by worn ring and pinion gears or improper gear set up.
Rumbling or whirring at speeds over about 20 mph can be caused by worn carrier bearings. The noise may change while turning.
Regular clunking every few feet may indicate broken ring or pinion gears.
Banging or clunking only on corners can be caused by broken spider gears, lack of sufficient positraction lubrication, or worn positraction clutches.
Rumble while turning may indicate bad wheel bearings.
A steady vibration that increases with the vehicle’s speed can be caused by worn u-joints or an out of balance driveshaft.
Clunking only when starting to move or getting on and off the gas might be loose yokes, bad u-joints or worn transfer case or transmission parts.
Old 02-12-2014, 03:22 PM   #27
SouthFLV6's Avatar
Old 02-12-2014, 03:23 PM   #28
Plenty of information on Google
Just look it up.
They screwed up. No Ring and Pinion is supposed to make any noise. Drive shaft my ***.
Old 02-12-2014, 03:38 PM   #29
I would be screaming for my $$$$ Back and not let them touch my car
Check this out>>Technical Help
It says this:
Old 02-12-2014, 04:26 PM   #30
I need to check my u joints lol
Sent from my Barbie Dream Phone®
CoolHorsey is offline   Reply With Quote
Old 02-12-2014, 05:21 PM   #31
ArtU's Avatar
That may be true in your case. In my town my Ford dealer has one of the best gear guys in town. They do gears every month. They are a cooperative Ford Racing Dealer. Every GT owner is a target for them to get yet another gear sale. They do performance add ons.
They sell lots of regular mustangs, Shelbys and Boss every year. They take then back in trade, sell the guy a new Boss and put the used one inside the showroom. And yes I miss the 2014 Boss, but seen a few of almost new 2013 ones on there floor this year.They are the place to go to get a car you want speced out from as well, they search for it and bring to their showroom for you. Thats how I got by car.
Old 02-12-2014, 05:21 PM   #32
Abominable Mustang
WhoDat's Avatar
Region: Alaska
It says this:
They should add this to the list:
Clunking/rumbling only when decelerating - broken and/or backed out ring gear bolts (due to the shop not using loctite)
I have first hand experience from this thanks to the PO of the '05 GT I had being cheap and going to the shop that quoted him the lowest price.
Sent from my HTC One X using Mustang Evolution mobile app
Old 02-12-2014, 06:17 PM   #33
Well then, that's great and no brainer for you too have it done at the dealership. Around me , there are three Ford dealerships in a 25 mile radius and none do performance mods and racing. Too boot the dealerships my way want 800 too 1000 dollars for gear install and that doesn't even include gears. They are smoking crack.
I paid 300 for my gear install from a mechanic who works on performance vehicles and does gear installs all the time.
Old 02-13-2014, 06:24 AM   #34
Hi WhoDat
Click here>Technical Help
They have a lot of good advice and information on this site.
Old 02-13-2014, 08:20 AM   #35
gt07's Avatar
go to American muscle and drivetrain
,gear sets installation read #19 to #32 this is a time consuming procedure and where your problem is ......hope this helps
Mustang 2 motor swap. Curtiswhitehead 2.3 Mustang 2 07-10-2013 08:06 AM
ranger rear end dreamstang General Car Discussion 4 01-07-2012 10:14 PM
What size gear for rear end? BlackBeauty01 1996-2004 Mustang GT 21 09-02-2011 08:00 PM
Any idea of what rear end gears i may have in my 92 GT? macmarine39 1979-1995 Mustang GT 4 07-16-2011 08:25 PM
Rear end in 1994 mustang V6 kevin Grove General Mustang Discussion 4 07-16-2011 06:14 PM
» Members Mustangs
Millie
1ijack
Stella
Lovin14
Add your Mustang
11:24 AM
