Double clutching - Mustang Evolution
Old 02-18-2014, 04:00 AM   #1
The Puma's Avatar
Double clutching
I understand the mechanics, I'm looking for personal opinions and thoughts, not out of the book jargon. is it good, bad, performance gains, less or more stress on the transmission, etc...?
I ask because I have been making a conscious effort to do it lately and wonder if my opinion matches up or I'm missing something.
Thanks in advance for your commentary.
The Puma is offline   Reply With Quote
Old 02-18-2014, 05:48 AM   #2
Ish416's Avatar
Your car has a synchronized transmission, there is no need to double clutch.
That said, it can help make smoother shifts but you will not be shifting faster as you will need to wait for engine rpm to rise (down shift or fall (up shift).
With smoother shifts also means less wear and tear as there will be less of a shock to the transmission/clutch.
If you are racing, unless you want to be slower, don't do it. Although, it does sound good. Watch the chase scene from the movie Bullitt. Steve McQueen does an excellent job double clutch his Mustang.
Old 02-18-2014, 10:33 AM   #3
66Sprint200's Avatar
I'm with Ish, the best time for double clutching is when there is no syncro and you don't want to grind gears. I got very good at it driving a 1929 Ford Model A (no syncro's at all) and a 1959 Edsel Ranger (3 on the tree, no syncro on first gear).
1966 Mustang Sprint 200--Wimbledon White
1998 Mustang V6 Coupe--Silver--RIP, Totalled by brother
2005 Mustang V6 Premium Coupe--Sonic Blue
66Sprint200 is offline   Reply With Quote
Old 02-18-2014, 10:52 AM   #4
The Puma's Avatar
I understand it isn't needed... I am just looking for personal opinions, not mechanical answers.
Old 02-18-2014, 11:20 AM   #5
Well, as for personal opinion, I think it makes it more fun. It's almost like driving an old racecar.
Old 02-18-2014, 01:48 PM   #6
Mile high JDF's Avatar
I see no need for it either. If I feel like being nice I'll just rev match instead of double clutching
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-18-2014, 02:56 PM   #7
The Puma's Avatar
Rev matching does feel a bit smoother, but double clutching gives that little bite upon disengagement of the clutch with that little added feel of power in the initial acceleration, no?
Agreed. Quite a bit more fun.
Old 02-18-2014, 03:00 PM   #8
I've never noticed a difference honestly
Old 02-18-2014, 03:08 PM   #9
I see no need for a car with properly functioning synchros.
Old 02-18-2014, 07:32 PM   #10
Bear376's Avatar
As someone who had to frequently double shift a truck, I greatly appreciate modern transmissions. It is nice to have the skill when needed, but I have never mastered any real speed doing it.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 02-19-2014, 11:06 AM   #11
Double clutching is something that you had to do way back when (and nowadays in large trucks) because the synchros sucked or were nonexistant and just pressing the clutch once wouldn't allow you to shift into the next gear smoothly, so you would press the clutch, shift to neutral, let it out, and then press it again, and shift tot he next gear and the speeds of the input shaft and the idler gear would be more closely matched. To kind of sort of get a feel for why this makes it easier, you can try shifting without using your clutch. As long as your engine RPM and your speed are at the right ratio for the gear you are shifting to, you'll shift smoothly. If your speeds are too far off, even with synchros, you'll grind the gears
Double clutching doesn't mean what you seem to be implying. To double clutch, you're just using the clutch to shift to neutral and then again to shift to the next gear. There is no "bite" because you're removing the difference between rotational speeds of the input shaft and the gear. It should feel as smooth as butter
Shuvool is offline   Reply With Quote
Old 02-19-2014, 11:20 AM   #12
The Puma's Avatar
Thanks again for the mechanical explanation even though it clearly says I understand what a double clutch is... As for the term bite, it was used to describe the transmission engaging the gear upon acceleration and feeling a better acceleration than a typical shift, nothing to do with smoothness of the shift. Thanks though.
Old 02-19-2014, 04:39 PM   #13
Ok, well you go on double clutching your shifts then, if it makes you happy.
Old 02-20-2014, 12:05 AM   #14
The Puma's Avatar
Lol. I wasn't trying to be rude, bro. My bad if I came off that way...
I'm just looking for opinions on here and keep getting info on synchros and that it isn't needed... Sorry again, I reread my message and didn't mean to sound so snotty.
Ditching my Metra double DIN dash kit InfinibandGT 2011-2014 Mustang GT 12 05-08-2014 10:13 AM
Double mid pipe for better sound?? Fintile 2011-2014 V6 Mustang 10 02-25-2014 09:22 AM
I have a Holley 4bbl double pumper with electric choke that stays way too wide open.. 85stangrevo 1979-1995 Mustang GT 11 02-21-2014 07:45 PM
Best Double Din for 06 GT Solomo2 Mustang Audio & Video 5 02-18-2012 11:46 AM
ebay double din 03GT88 Mustang Audio & Video 11 09-22-2011 11:57 AM
03:52 PM
