Staggered wheel problems - Mustang Evolution
Old 02-27-2014, 07:44 AM   #1
2013_DIB_GTCS's Avatar
I just recently put some leguca seca replicas on, 19x9 in the front and 19x10 in the rear wrapped in Michelin AS 3 275/40/19 all around. I went with the 275s all around cause I got a pretty good deal on 4 of them. Got them mounted balanced and put on at a shop right next to work out of convenience and noticed the ride went to crap and there was a vibration. Took it to a different shop who usual takes care of my tires and all the wheels but one were off balance. They were off between .25-1 ounces. Now I noticed it rides a little better but there still seems to be a vibration noticeably mainly at highway speeds. I think it has to be the wheels and tires because the stock wheels and tires never had near the ride discomfort. Since they've been balanced twice, I have no idea what to do. Any help?
2013_DIB_GTCS is offline   Reply With Quote
Old 02-28-2014, 08:16 AM   #2
gweze001's Avatar
Did you have it realigned after the balancing? Were the stock wheels 19s? Once they are balanced they are balanced, but there could be an alignment or front end suspension compensation that only manifest itself at higher speeds. Are they mild vibrations in the steering or make the whole car shake?
2010 GT, Airaid CAI with BAMA 87 Performance Tune, and Flowmaster Outlaws
gweze001 is offline   Reply With Quote
Old 02-28-2014, 08:27 AM   #3
Alignment really won't contribute to the vibrations but I had it initially balanced. Then aligned. Then rebalanced twice. Took it in again yesterday and had the guy ride with me to pin this thing down. Seemed to be coming from the rear cause the vibration was mainly felt in the seats. They 've balanced the rears again and they were both off by a quarter of an ounce. Seemed to drive smooth and right afterwards...best it's felt since I've had the new wheels and tires on. Well see how it does this weekend cause I've got and hour and a half trip to St Louis.
I know the vibration has something to do with the new wheels and tires because I never felt it with the stockers. If the vibration comes back the tire shop will unmount the tires and test the rims to see if they're outta whack. If the rims are fine it's probably a tire problem and I'll have to get on the phone with Michelin. Hopefully I dont have to take it that far
Old 02-28-2014, 08:49 AM   #4
gweze001's Avatar
Glad it's better, mine was an issue of alignment. Can't rule out all possibilities. New wheels and tires cause it to sit different and can throw things out of wack. I agree though, hopefully you won't have to call the tire guys
Old 02-28-2014, 01:51 PM   #5
Mile high JDF's Avatar
Are they using stocky weights or are they just hammered them onto the outside lip? I have had issues with sticky weights not sticking on new rims after I've balanced them. But usually they pop off when I'm trying to mount them back onto the car.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-28-2014, 01:57 PM   #6
I hope you only paid for one balance and in any event, find another shop. If it takes them 3 tries to balance a set of wheels they probably shouldn't be touching anyone's vehicle...
2000 Mustang GT Steeda #0048
aftermarket steering wheel setup Brad.krieg 1996-2004 Mustang GT 27 08-26-2016 03:44 AM
Solved all the MT82 problems with new Clutch Kit mustangcito 2011-2014 Mustang GT 11 10-25-2014 03:30 AM
2012 GT engine problems?? jjl3717 2011-2014 Mustang GT 15 02-09-2014 10:00 AM
Need Wheel Spacers but not sure which ones runvsofthisbull 1996-2004 Mustang GT 3 07-05-2012 08:36 PM
steering wheel problem edgar_32 1996-2004 Mustang GT 5 01-15-2012 12:37 AM
04:19 PM
