Ring and Pinion - Mustang Evolution
Old 03-24-2014, 11:36 PM   #1
96_Mustang_GT's Avatar
Ring and Pinion
I just put a Ford racing 355 ring and pinion in my 96 mustang gt. The pattern on the ring is good on both the drive side and coast side and the back lash is about 10. It takes off great and doesn't make any noise in while going forwards or in REVERSE but wines like crazy when coasting. It doesn't make sense to me why it wines while coasting but not in reverse since they're both on the coast side. Any help will be greatly appreciated..
96_Mustang_GT is offline   Reply With Quote
Old 03-25-2014, 07:22 AM   #2
Mile high JDF's Avatar
Is this a new set or a used set?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-25-2014, 08:14 AM   #3
It's brand new
Old 03-25-2014, 08:38 AM   #4
Do you think it just needs time to wear?
Old 03-25-2014, 08:51 AM   #5
Not installed correctly
Here is some information to read. It is long but well worth reading. You should not hear any noise at all.
Some good gear installation information
then click on "TECH"
Really pay attention to #9
Old 03-25-2014, 08:55 AM   #6
Any suggestions? I didn't get a link
Old 03-25-2014, 11:07 AM   #7
Try this
Tech
Click on above tech
This should work for you.
Whoever put your gears together did not do it correctly because you should not be hearing any noise.
Gear Noise === Wear.
Don't let anybody try to tell you that the noise is normal or it will go away. It won't go away and will get worse and it is Never ever "NORMAL"
Whoever did it needs to do it again properly.
Old 03-25-2014, 11:29 AM   #8
Tech
Click on above tech
Alright. Thank you!
Ring and Pinion fastforddad 2005-2010 Mustang GT 3 09-15-2013 09:25 AM
Bad ring and pinion Csinclair1991 2005-2010 Mustang GT 1 08-25-2013 10:32 PM
Summit racing ring and pinion kit Varasios 1979-1995 Mustang GT 4 07-05-2013 02:38 PM
What brand of Ring and pinion gears to buy? runvsofthisbull Pre-2005 V6 Mustang 32 02-18-2010 05:52 PM
8" 4.11 Richmond Gear Ring and Pinion New in the box kellyjc Mustang Parts for Sale and Wanted 0 07-01-2006 10:27 PM
11:46 AM
