Is there any way to calibrate the temperature reading? - Mustang Evolution
Old 04-03-2014, 11:17 PM   #1
sbbamafan's Avatar
Mine always indicates more than 5 degrees F higher than it really is. I checked the Air Intake Temp and at speed it always matches the ambient reading on the dash. Does any body else have this issue? If I cant resolve it, I will get a $3 thermometer from Wal Mart but it sure does not look good.
2013 Red Candy Convertible with Stone Leather, Pony Package and Mt-82
sbbamafan is offline   Reply With Quote
Old 04-06-2014, 10:25 AM   #2
Black12's Avatar
If you have a tuner (Diablosport), you can get the temp reading on it and check to see if what you have is accurate. If you know how far it's really off, then at least you know for sure what it really is. Don't know if gauges are tuneable. I doubt it, they read off a differential signal. The sender may be at one end of the signal window, as small as that is. If it was outside of that parameter it would work at all.
Black12 is offline   Reply With Quote
Using handheld tuner to calibrate speedo - Affect track key tune? mrsneakyz28 Boss Mustang 4 03-03-2014 12:08 PM
calibrate wideband gauge dreamstang 1979-1995 Mustang GT 15 08-11-2012 08:37 PM
Is there any way to increase mpg Jayjay 2005-2010 Mustang GT 32 05-03-2012 07:12 AM
There isn't any warranty approved headers is there? Xofferick 2011-2014 Mustang GT 16 02-14-2012 02:24 AM
Is there any way.... Blue GT 5.O The Bar 4 04-06-2004 05:01 AM
05:06 PM
