Ordered a Motive brake bleeding kit - Mustang Evolution
Old 04-07-2014, 10:46 AM   #1
Sick of the wife complaining about helping me bleed the brakes. Also she was letting off the pedal too early this weekend with the 98 and wound up sucking a bunch of air into the system... yay. Now I can't drive it and even safely put it up onto ramps to finish wiring my HIDs/Projectors and mounting the ballasts under the car.
So I ordered the Motive kit from Jegs for Ford 3 tab twist on style caps like I have in the 98. I did NOT order a universal, those never work. This is the correct way to bleed a brake system anyway because you always suck a little air back into the system when the pedal hits the floor and the pressure drops doing it the manual way. You can use check valves and whatever to help but nothing is going to replace a positive pressure line bleed. Will post results when I'm done.
Old 04-07-2014, 11:11 AM   #2
mystang50's Avatar
how much was it?
Old 04-07-2014, 11:34 AM   #3
$57 shipped from Jegs with my military discount. Its $64 normally I think.
Old 04-11-2014, 08:02 PM   #4
Used this thing finally and I swear I could hear a chorus of angels singing somewhere in the background. Cap locks right on, set to 15 psi, stick a hose on a bleed port and go. I can't believe I've never had one of these... I will say do NOT buy the universal fitting, I've heard those never work but this one was great. This is one of those mandatory tools that everyone should have but nobody does for whatever reason.
Old 04-15-2014, 07:25 PM   #5
surfinglbi23's Avatar
Interesting. I have always used a Mity Vac though this sounds like a cool setup. I like the mity because I can do brakes on my cars and bikes without help and it works on anything
surfinglbi23 is offline   Reply With Quote
Old 04-15-2014, 08:59 PM   #6
This lets you do it without help too and a positive pressure brake bleed is optimal. The cap I have fits Ford and a lot of imports and I think Chevys too.
Old 04-16-2014, 08:47 PM   #7
Agreed with wife helping. Been there, done that. No thank you!
For Sale: 2011-14 Mustang V6 Brand New Ford Racing 3.73 Gears and Motive Gear Bearing Kit BlueSoulStang Mustang Parts for Sale and Wanted 7 06-24-2013 05:13 PM
Brake Bleeding Labrat 2005-2010 Mustang GT 22 03-09-2012 08:23 PM
one man brake bleeding kickerofdoom General Mustang Discussion 2 02-06-2012 04:28 PM
Painting Calipers/Bracket and Caliper Reinstalltion/Brake Bleeding Napoleon85 2011-2014 Mustang GT 22 02-02-2012 04:12 AM
Motive Gears Ghostbuster 1996-2004 Mustang GT 10 04-29-2005 05:43 AM
12:17 PM
