Moisture In My Headlight - Mustang Evolution
Old 04-08-2014, 08:20 AM   #1
Tyriqq's Avatar
It seems like over night after a few days of rain I have moisture on the inside lens of my Raxiom driver side headlight. I don't see any visible cracks in it either. Is there a way to fix this problem without having to replace the whole headlight
Name:	ImageUploadedByMustang Evolution1396966783.110649.jpg
Tyriqq is offline   Reply With Quote
Old 04-08-2014, 08:53 AM   #2
Well you are at least going to have to pull the light and re-seal it so it doesn't happen again. To absorb the moisture you can stuff a dessicant pack in there after you pull it (just make sure you can get it back out) and see if that absorbs the moisture.
Its good practice to ALWAYS seal aftermarket housings although I have had tremendous luck with DEPO stuff on my CSVT, my 98 and the current DEPO projectors I'm putting in were sealed up very tight. Raxioms... I've been less than impressed with them.
Old 04-08-2014, 09:07 AM   #3
Loc: Austin,TX
Throw em in the oven,reseal em and be done. There are tons of videos on youtube. I've done this on a 07 Charger,pretty simple.
Old 04-08-2014, 09:48 AM   #4
Tyriqq's Avatar
Thank you Sir!!
Old 04-08-2014, 11:06 AM   #5
Yeah but if they used crap glue it might still not hold. If you REALLY want to make sure it never happens again, bake them open, apply 3M Butyl Tape and then bake them closed again as it probably shows in the vid.
However if it was me in a Coyote I'd be getting ahold of some factory HID housings/ballasts/HIDs and swapping them in vs Raxioms. You will not get a better headlight setup in a Coyote and I can promise you that.
Fog light moisture help Doe_Rae_mi 1996-2004 Mustang GT 10 02-28-2013 03:40 PM
Moisture INSIDE the headlights Torchredmustang Mustang Paint, Appearance & Detailing 13 12-12-2012 05:13 AM
moisture on the inside of the windshield Jettin Stang 1979-1995 Mustang GT 3 02-16-2012 02:39 PM
Moisture in the head light. 99 SVT Cobra 1996-2004 Mustang GT 5 07-21-2009 10:19 AM
stupid moisture in headlight = gone sonic04edge Pictures and Videos 7 05-10-2007 07:09 PM
05:05 AM
