Check engine light :( - Mustang Evolution
Old 05-03-2014, 11:01 PM   #1
G3racing's Avatar
OK so I bought a steeda cai installed it tuned my car ran great later on their check engine light came on and the code said bank 1 was running lean. Need help my car is running like **** and getting 7mpg I heard something about battery disconnect to fix it but idk
2014 Mustang V6 Manual
AMR Charcoal Wheel & NITTO Tire Kit - 20x8.5
G3racing is offline   Reply With Quote
Old 05-03-2014, 11:46 PM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Get your tune checked and also check all of the connections on and near CAI. Something may be loose or off.
Sent from the future.
2012 Kona Blue 3.7L V6:
Old 05-04-2014, 11:07 AM   #3
G3racing's Avatar
What do you mean tune checked
Old 05-04-2014, 02:30 PM   #4
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Exactly what I said. Get with whoever built your tune, and have then go over it again to make sure they didn't get something wrong.
Old 05-04-2014, 02:58 PM   #5
PonyBoyV6's Avatar
I'd start with checking the MAF and any and all vacuum lines. Very easily could have shook a line lose, or dirtied, or even broke the mass airflow sensor. Did this all start immediately after installing the CAI?
PonyBoyV6 is offline   Reply With Quote
Old 05-04-2014, 06:34 PM   #6
G3racing's Avatar
It worked fine for a couple hours then messed up
Old 05-04-2014, 07:25 PM   #7
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Have you done anything we've suggested yet and did you find anything? The MAF is a good call by PonyBoyV6. When I installed my CAI, the two screws holding the MAF in backed out, causing the MAF to be very loose.
Old 05-04-2014, 08:42 PM   #8
G3racing's Avatar
I tightened the metal zip ties and made sure everything was connected well then reset my computer by unhooking the negative on battery then tuned it check engine light went away but I feel less power than I should when I get on it and also should rpms at idle be a like 500-700
Old 05-04-2014, 08:59 PM   #9
Abominable Mustang
WhoDat's Avatar
Region: Alaska
My idle is around 750. Who did your tune, because you should be able to get them to datalog the tune to see if they can get the power you're looking for. They can also adjust your idle rpm if it's too low.
Old 05-05-2014, 08:15 AM   #10
G3racing's Avatar
I have a Bama tuner and when my car idles the rpm needle moves up and down a little bit and my car rumbles it never did this before cai and tune
Old 05-05-2014, 08:51 AM   #11
PonyBoyV6's Avatar
What model year is this car? Also, If you have a bama handheld, Use the Check engine function. If the light is not there, it should still show pending CEL codes. You'll probably have a p1000 code from resetting the battery, but ignore that. See if anything else pops up.
Old 05-05-2014, 10:23 AM   #12
G3racing's Avatar
2014 v6 the code was for bank 1 being to lean
Old 05-05-2014, 05:58 PM   #13
Abominable Mustang
WhoDat's Avatar
Region: Alaska
If you're tuned through Bama, you should have 3 tunes. Have you tried loading either of the other two tunes yet?
Old 05-12-2014, 12:57 PM   #14
pete2013's Avatar
The oil on the after market filter might have fouled the air flow sensor
pete2013 is offline   Reply With Quote
Old 05-15-2014, 05:32 PM   #15
Abominable Mustang
WhoDat's Avatar
Region: Alaska
So did your issue ever get resolved?
Old 05-15-2014, 06:56 PM   #16
G3racing's Avatar
It has something to do with the 2014 computer and the adaptive shifting thing relearn feature
check engine
Check Fuel Cap & Service Engine Soon Light??????? mattstang Pre-2005 V6 Mustang 8 12-25-2006 01:33 PM
check engine soon light finally off stangracer Pre-2005 V6 Mustang 4 02-04-2004 10:41 AM
Check Engine Light MUSTANGJUNKY420 Pre-2005 V6 Mustang 11 08-09-2003 12:29 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 1 08-03-2003 08:24 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 2 07-30-2003 12:22 AM
10:26 AM
