change transmission oil??? - Mustang Evolution
Old 05-08-2014, 07:39 AM   #1
Just Bout a 2007 v6 Auto about 5 months ago and its been driving perfect until recently. Now at times at a stop at a redlight or coming off a roll itll hold a rev before jerking then taking off. Like as if it was in netural for 2 seconds then drive off.
Is this because of trans fluid?
Should i just pay to get it changed or does this sounds lile a deeper issue?
It has 70,000 miles btw
retrofuture is offline   Reply With Quote
Old 05-08-2014, 09:08 AM   #2
Part of used car ownership is assuming the previous owner never changed any fluids or did the plugs/wires or scheduled maintenance unless there is a receipt for it and even then. I ALWAYS suggest doing oil, trans fluid, brake fluid, differential fluid and inspecting the brakes. I'd also do the spark plugs.
Also if you take it to get it done do NOT get it "power flushed" or whatever. Just a full drain/fill of the trans and converter.
manual transmission oil change Torchredfrankie Pre-2005 V6 Mustang 13 02-03-2013 12:33 AM
when should i change my transmission oil? Andy714 2005-2010 V6 Mustang 8 10-31-2012 04:36 AM
oil change and transmission fluids Andy714 2005-2010 V6 Mustang 15 10-29-2012 01:52 PM
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
transmission oil change!!!!! secomejia 1996-2004 Mustang GT 9 10-04-2011 08:07 AM
03:57 PM
