4.6L 2V & 4V Alternator/Grounding Issues? - Mustang Evolution
Old 05-15-2014, 01:02 PM   #1
What is known about 4.6L 4V alternator issues and possible grounding issues with same part?
-When i installed my new 200amp alternator & power wire on the '96 Cobra, I did my best to eliminate any touching between the engine block, any framing, and the alternator itself.
-I rubber coated the bottom and back side of the alternator anywhere it would directly rest up against engine. I applied grease along area at bottom where bolts in, the bolts it rests on, bolts attaching to wire loom frame on top, applied a layer of silicone on engine block behind alternator. Overkill? I don't know.
What say you??
Old 05-15-2014, 09:46 PM   #2
Might not be as frequent as thought. Good thing I guess. Anyway, new 200amp unit is working like a champ so far.
grounding carlosmorris29 1979-1995 Mustang GT 4 11-15-2013 12:08 PM
Alternator Issues 08Mustang 2005-2010 V6 Mustang 13 05-07-2013 11:54 AM
Alternator & Starter FYI NeedSomeMods 1979-1995 Mustang GT 4 12-22-2011 07:04 PM
Replace alternator & Oil leak 1996 Ford Mustang? riordain General Mustang Discussion 3 03-27-2010 02:07 PM
96 GT alternator Rellik Pre-2005 V6 Mustang 8 11-19-2003 11:12 AM
09:53 PM
