Adjustable Suspension Components? - Mustang Evolution
Old 05-29-2014, 07:22 AM   #1
Frozen Yettie's Avatar
I have a 2014 V6 Premium and I've been slowly modding it. Now I am looking at suspension components and I am trying to figure out which one I should get.
An Adjustable Panhard Bar, Lower Control Arms, and Upper Control Arm or should I get the Non- Adjustable ones.
I plan on keeping the ride height stock so no modifications to the springs or struts.
(Until I really want to but IMO the wheel gap looks good enough for me).
I will however be upgrading to a One Piece Driveshaft soon and have read that it is best to have an adjustable UCA to set the Pinion angle. So which of which should I get Non-Adjustable or Adjustable?
Thanks!
2014 Black Mustang 3.7L V6 Premium | 93Race MPT Tuned | Too many mods to list just check out my garage.
Frozen Yettie is offline   Reply With Quote
Old 05-29-2014, 04:53 PM   #2
Bump.
Old 06-02-2014, 12:56 PM   #3
If you plan on keeping stock ride height then you don't need adjustable control arms. The one piece drive shaft should be fine if you remain at factory ride height, but I would double check with the manufacturer. However with adjustable lower control arms you can accurately align the rear axle, which due to manufacturing tolerances can sometimes be off. That is of course if you want to get an alignment done.
I've found that the adjustable pieces are not all that much more expensive then the standard ones, and it doesn't hurt to have the flexibility. My plan for my car was to get adjustable lower control arms and leave the stock upper control arm alone (I hear its a ***** to change).
BadCon is offline   Reply With Quote
Old 06-02-2014, 01:18 PM   #4
Oh2freshstang's Avatar
An adjustable UCA is good to set your pinion angle..if ur gonna change to a 1 piece DS I would get it just to be safe!
Adj panhar bar is to align your rear end that can be slightly off even from the factory.
Adj LCA are not needed & if not set properly they can cause major damage go with NON adj LCA!
Is Transmission fluid flush necessary?? jmpark527 2005-2010 Mustang GT 11 10-04-2017 06:43 AM
Suspension install... One-time use components? GrayGhost 2011-2014 Mustang GT 3 01-21-2012 12:45 PM
Strut tower brace. necessary? Texastboneking SVT Mustang 4 05-06-2011 08:55 PM
No title necessary *WW* Ken The Bar 6 10-17-2006 05:19 PM
install kit necessary for gears? tedness Pre-2005 V6 Mustang 3 06-30-2005 05:23 PM
09:44 AM
