New to this need advice please - Mustang Evolution
Old 06-19-2014, 08:27 AM   #1
Question New to this need advice please
New to this need some advice
What's up,
Just got a 99 gt vert 100,000 miles runs great
Ok so everything is stock except h pipe flow master mufflers.
Basically I want to know if this is a good setup to start off with or should I go another route or if there's anything else I should get, I will be buying in pieces not all at once
BBK cai with throttle body 78mm
Long tube headers
Under drive pulleys
High flow water pump
Exedy Stage 2 clutch
Ford racing 4;10 gears
Ford racing aluminum drive shaft
Drilled rotors (needs new rotors anyway)
Lowering springs 2" front 1.5 rear
New shocks
Strut tower stabilizer
Thanks any info is greatly appreciated
Bruno_ge is offline   Reply With Quote
Old 06-19-2014, 09:26 AM   #2
garbill2003's Avatar
Start with rotors and then do gears
garbill2003 is offline   Reply With Quote
Old 06-19-2014, 12:28 PM   #3
If you lower the car Caster Camber plates are required. Get the Max Motorsports ones, don't get the cheaper ones as they make noise and actually can fail and have fun with that...
A good starter combo is:
4.10 Gears
Lower Control Arms
Lowering Springs/Shocks/Struts/CC plates
Subframe connectors (Steeda)
Short shifter (MGW or Steeda)
Offroad midpipe and catback (stock manifolds are not really restrictive on modulars)
Underdrive pullies
Intake Plenum (Trick Flow or Accufab)
Full tune up (New OEM COPs or COP rebuild kit, Autolite 103s and all new fluids)
Cobra front rotors/brackets/calipers
Good wheels/tires
Custom tune
Old 06-19-2014, 06:15 PM   #4
Thumbs up
4.10 Gears
Lower Control Arms
Underdrive pullies
Good wheels/tires
Custom tune
Ok thanks alot. I already have the sub frame connectors and did a full tune up as soon as I bought it, everything OEM but I used accel cops. Now i do A LOT of highway driving i would say about 80% of the time but do you think the 4;10s would be too much? Or should i go with 3;73s ? Thanks again
Old 06-19-2014, 06:58 PM   #5
If you do a ton of highway driving you may want to keep the gears you have provided they are 3.27s. Also depends how fast you go. 99/00 cars and a few 01s have the good version of the T-45 and a .68 overdrive. At 70mph with stock size wheels you will be turning 2450 or so with 4.10s. You will also need a speedcal to get your speedometer corrected unless you get a tuner and then they can just do it in the tune.
As far as the Accel COPs... if they are running well now then leave them alone but just be aware they are not nearly as good as OEMs as far as durability goes.
Old 06-19-2014, 06:59 PM   #6
Old 06-19-2014, 07:36 PM   #7
Hmm... I wonder if the guy before me put gears in already cause when I'm doing like 80 I'm at 2500 and the speedo is about 7-10 mph off
Old 06-19-2014, 07:47 PM   #8
Tangtang2.0's Avatar
Is it better going 70mm or 75mm on the trick flow tb and plenum
Tangtang2.0 is offline   Reply With Quote
Old 06-19-2014, 07:55 PM   #9
Just get the 75mm.
This
Old 06-19-2014, 07:56 PM   #10
Just get the 75mm.
This
Old 06-19-2014, 07:56 PM   #11
Just get the 75mm.
This
That's exactly what I was looking at thank haha
Please help! Need advice from people who have came across this problem skorch85 New Member Introductions & Greetings 1 03-02-2014 07:11 AM
Need mechanical advice please!!! Chadillac34 1996-2004 Mustang GT 5 09-20-2013 07:34 AM
96 3.8l with some bolt ons whats next...? Need some advice please!!! Mavs32 Pre-2005 V6 Mustang 6 02-02-2011 04:56 PM
need advice please blumustang98 Pre-2005 V6 Mustang 0 05-21-2007 10:01 PM
need tire advice-please help! Echicky143 Mustang Wheels & Tires 7 03-17-2006 03:39 PM
06:24 AM
