HID lights in reflector housings- A reminder to some of you out there - Mustang Evolution
Old 06-23-2014, 10:56 AM   #1
I'm copypasta-ing this from another forum. With the rash of "I'm getting HIDs for my car" or "how to put HIDs in my Mustang" or whatever threads. I urge anyone/everyone here considering it or with friends that do it to give it a read.
Ok, another fun rant for everyone...well, maybe not everyone. Those of who you care about "doing things right" and research your modifications before installing them, I'm not looking at you. Yes, there are correct ways to retrofit HIDs into your car that came with reflector housings. If you have done this, thank you and good job. If you have OEM projectors and have put HIDs in, then you're fine as well. The ones I am looking at, again, are those who blindly throw parts at their cars without even the basic understanding as to what they are doing. Today's focus is lighting. With the introduction of H.I.D (high intensity discharge ) or "Xenon" lighting in automotive applications, drivers have been given a better and safer way to see at night....mostly. This types of lights started out as OEM options and have slowly (well, back then) trickled their way down to the average consumer for a low price. At first, to have Xenon lighting in a car that did not come with it required getting a hold of an OEM setup, which was (and still is) very expensive. As aftermarket manufacturers saw the demand for these kits, they flooded the market with them for every automotive bulb under the sun. While a benefit to some, it has been a glaring problem to many motorists. Far too often, owners who like to modify their cars have been like horny leg-humping dogs by sticking these lights in every hole they can think of...weather they belong there or not. Not only have the applications of many of these lights been wrong, manufacturers have even gone as far as to manipulate the technology of these light to produce some of the most annoying and unusable lights ever conceived.
Let's look at a few basics.
Reflector vs projector housings..in one simple picture-
What is a H.I.D/Xenon bulb anyway? Well, your standard halogen bulb that has been standard for decades is nothing different in design than your typical household light bulb. It works by passing energy over a small filament which in turn causes the filament to become super heated and produce light. We should all understand how this works. Like this-
In HID or Xenon lighting, a small arc of plasma is created by energy passing through various gases and elements in a sealed chamber. This arc produces the light you see..it's kind of like a small lightning bolt to put it in simple terms. It works like this-
Let's discuss the two types of light bulbs and the two types of light housings used on cars today.
Now for a general light, this really is no different other than overall light output. The HID is able to produce a brighter light with less energy. But when it comes to automotive applications, things change...a lot. Automotive lights are designed in a very specific manner in order to put light where you need it, and not put light where you don't, as in putting light on the road and not in oncoming driver's faces. The general standard for years has been a halogen bulb in a reflector housing. In this housing, bulbs have a shield built into them to help control light output. Think of it like walking though a dark room with a candle to light your way. Notice that when you do this, the glare from the candle hurts your ability to see what you are trying to light up. What do most people do? Well, instinctively most people put their hand between their eyes and the candle. This is the same concept on most halogen bulbs and is designed to only allow light into a specific part of the reflector housing. You can see it here as a little piece of metal next to the filament-
And this is the desired effect of all of this. The location of the filament and the shield are super critical in the design of a reflector, changing the location of the filament's location even a couple of millimeters will change every angle at which the light travels, ultimately letting light go in places it was not designed to. This is is also the exact same reason why your high-beams project light much higher and wider- because the high-beam filament is no shielded and placed in a location that causes the light to scatter in a different direction.
There are many cars with projector lenses that use halogen bulbs. But the bulbs used in the projector housings do not, I repeat, do not have a shield on them. This is because the way a projector housing works, the lens (and if applicable, the shield build into the housing) does all the focusing. In some projector setups, both high and low beam patterns are available and are controlled with a movable shield. Here is an example of what I am talking about-
..and this is how a projector housing works-
Now when it comes to HID lights, almost all of the cheap/regular kits for most all bulbs are unshielded. There are a few exceptions that have a shield operated by a solenoid, but generally speaking most, if not all of your average HID installs in reflector housings are done wrong.
You average HID bulb looks like this-
Notice the little bubble in the middle? That is where the arc is produced and where the light comes from. Notice the difference in the following picture of the location of the halogen filament vs. the location of the HID "filament". This is the root cause of why putting HIDs in reflectors is never a good idea-
Upon changing the location of the actual light source, you get massive amounts of light scatter (glare). This is what is very bad and annoying to all other drivers on the road. You are essentially blinding them as if you were driving with your high-beams on. I've heard many people exclaim "but I can see so much better with my HIDs (in reflector housings)"...and this is only true because you are scattering light all over the place. Here are some examples of what I am talking about-
Halogen in reflector-
Halogen in projector-
HID in reflector housing-
Notice all the light scatter/glare that is up higher than the "cut off" line? That is bad...very bad. I could post up numerous examples of this all day long. Even while it "might not look so bad", it is bad. Aiming your headlights down won't help any either. All aiming your lights down will do is move the focus point down, but glare will still be emitted up and out. Oncoming drivers will see this. Most people might thing your brights are on too....even though they're not. Both of the car in the following picture are equipped with traditional halogen reflector housings..but one of them had improperly installed HID lights, can you tell which one is which?
See how bad that is? Sadly, none of the people doing this actually care they are blinding other drivers...nor do they really listen to those who care to inform them politely.
Lastly, we have color. For whatever reason that I may never understand, people seem to love the blue/pink/purple lights too. They think it looks "cool" or that they can see better with it. In fact, no matter what the reasoning is, they are 100% dead wrong. HID lights, as many know, are offered in different "K" ratings. This is for Kelvin. The Kelvin range describes light at different frequencies. Here is a simple way to understand Kelvin (K) and light output-
In reality, anything above 5K is really not any more helpful or useful to the human eye. In fact, the lower the Kelvin rating, the "better" it is for your eyes. Natural sun light is actually pretty yellow. Regualr halogen light is also on the yellow scale. The human eye likes this and is why we can see the colors we see. Notice with a blue or red light how everything looks a single color? This is the same for HID lights in the 8K+ range. Your eye does not like the frequency and takes much longer to adjust as well as a severe loss of detail when looking at something. This is actually why police lights are blue...because they're VERY attention getting and police want you to see their blue lights from as far away as possible...so you know they're there. Blue/purple/pink headlights are terrible for your eyes. I could actually give much more detailed information as to why, but I don't need to be that technical right now. Just know, and please understand why all of this is so bad.
TL;DR? Just read this:
If you put HIDs in your car and they don't look almost exactly like this-
Then you are doing it wrong and irritating everyone driving down the road at night.
If your lights looks like this..regardless of the HID in reflector housing...
...you are a danger to everyone else on the road.
Old 06-23-2014, 11:14 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
I vote that this should be stickied
Sent from the future.
2012 Kona Blue 3.7L V6:
Old 06-27-2014, 05:37 AM   #3
LivelyMustang's Avatar
I second that. Sticky please. Very useful
LivelyMustang is offline   Reply With Quote
Old 12-29-2015, 09:44 AM   #4
Bumping this to the top for all you kiddies thinking of HIDs with holiday or tax return money. Please if you are going to upgrade the lighting of your car do it right. Buy an actual HID housing, pay for a retrofit or learn to DIY.
Old 12-29-2015, 10:56 AM   #5
Or do what I did and go buy a 2015
Sent from my SM-G920V using Mustang Evolution mobile app
Old 12-29-2015, 11:44 AM   #6
I brought this up several years ago and was told by mods to leave. It should be legal to run ppl with hid's in halogen housings off the road.
Sent from my XT1045 using Tapatalk
Old 12-29-2015, 02:59 PM   #7
XSlashDashX's Avatar
LED seems to be the new thing. I hardly see people with HID around my area.
Old 12-29-2015, 03:19 PM   #8
LED is a look thing it's not any brighter than a real good halogen and I'm still skeptical of a non halogen anything in a housing designed for halogens. You likely do not see HIDs so much because I think more and more ppl are realizing how bad they are or they are now into the HS ricer category where they belong. Either way...
Also a properly done HID will be holy ****balls brighter than any LED.
And lowflyn, I don't think I was here for that and while I don't advocate any illegal activity, I will turn my brights on and leave them on until I'm past any idiot with a plug and play kit in a halogen housing. And I have snow plow HIR bulbs in my truck which are ridiculously bright for halogens.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 12-29-2015, 04:29 PM   #9
AngryTech's Avatar
I too was once an offender. But then I saw the light...
**see what I did there?**
Ok, moving on. I ordered another set of OEM housings, ordered the Mini H1 kit from theretrofitsource.com. Completed the retorfit and now I am in love with my HID's. Love the cut off line and the output. I have 6500k bulbs and see clearer down the road than just splashing the light everywhere. In this case, ScottyDOESknow!!! Ok, sorry. Last pun.
AngryTech is offline   Reply With Quote
Old 12-29-2015, 04:58 PM   #10
I do enjoy blinding ppl with my plow.
Old 12-29-2015, 05:17 PM   #11
Lmao... Hey even a mini mag can be pretty bright!
As for me, I work with a guy who charges $175 labor for a retrofit, the client provides all parts. He has done a bunch of stuff and does good work. Once I get my car up and running he will get my housings and some morimoto stuff and I'll have a nice set of bi xenon retrofits.
Old 12-29-2015, 05:20 PM   #12
Get me a set lol
Old 12-29-2015, 08:35 PM   #13
Get me a set lol
I thought you were in the same boat as me with a car with a blown motor?
Old 12-29-2015, 08:37 PM   #14
natestang07's Avatar
That hurts lol
Old 12-29-2015, 09:10 PM   #15
Nearly blown motor
Nearly broken tranny
Dented Driver quarter panel
Battery drain issue
12v connectors not working
Need i list more? lol
Old 12-29-2015, 09:28 PM   #16
Testing your love isn't it lol
Old 12-29-2015, 10:04 PM   #17
Very much so lol
Trying to not spend money on it so i can invest more. Then i'll have more available once i graduate.
Old 12-29-2015, 10:12 PM   #18
Still telling you to buy some saleen stock lol
Old 12-29-2015, 10:18 PM   #19
$0.0008 per share lol
Not a fan of penny stocks. I'd rather put money into stocks that pay good dividends, that way even if the stock is up or down there is still money rolling in, which i can have re-invested for more shares for free.
More dividends = More shares bought = even more dividends = even more shares bought.... Its literally a snowball effect.
Don't want to derail the thread though lol
Old 12-30-2015, 05:42 AM   #20
More dividends to buy a HID retrofit?
Or just get some bright halogens for $40. Half the ppl who complain about the crappy halogen output are running aftermarket housings with silverstars or some other gimmick bulb anyway.
Old 12-30-2015, 06:01 AM   #21
parkerz28's Avatar
Name:	ImageUploadedByMustang Evolution1451480451.762736.jpg
Very nice huh fellas 😏😘
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 12-30-2015, 06:16 AM   #22
Originally Posted by parkerz28 View Post
Attachment 195270
Well, at least you are posting an example of exactly what not to do. Nothing about that is functional and it looks very boy racer.
Old 12-30-2015, 07:43 AM   #23
parkerz28's Avatar
What can I say some ppl never grow up
Old 12-30-2015, 07:56 AM   #24
DiESeven's Avatar
Hate these guys. And yes, it was a civic.
Name:	ImageUploadedByMustang Evolution1451487345.326965.jpg
Instagram: @v6beast
Old 12-30-2015, 10:01 AM   #25
Not sure. I have 2 sets of headlights right now. One will probably be turned into an air intake. The other is either Projectors or just a really bright halogen. Visibility is fine for me right now.
Old 12-30-2015, 02:58 PM   #26
You can joke about it all you want but your vehicle is a road hazard to oncoming traffic.
I'm sorry you need to look JDM at the expense of other people's safety.
Old 12-30-2015, 04:03 PM   #27
Thats not even JDM. Real JDM would agree with us. Thats just rice.
Old 06-11-2017, 09:40 AM   #28
how do yall feel about HIDs behind halogen projectors?
asking for a friend
only kidding im all halogen
p.s. I just realized I drug this up from the dead :skull:
Old 06-11-2017, 07:07 PM   #29
Mod status=revoked! Llolololol1!!111!4124!
Hey good, maybe some other ppl will see it again. Probably should sticky it. I post this on the FB Mustang groups sometimes and all the boy racers come out of the woodwork guns blazing lol.
Old 06-12-2017, 08:06 AM   #30
I figured that HIDs behind a projector was slightly better than just in a reflector housing. I also figured this would be a sticky by now.
Old 06-16-2017, 04:44 PM   #31
noldevin's Avatar
This is now my favorite post on the site. Huge pet peeve of mine
noldevin is offline   Reply With Quote
Is there any Stangs out there that run 10-11s on a 3kish budget? 01Smoke 1979-1995 Mustang GT 6 08-24-2012 04:59 PM
HID in reflector housing mickeyp49 2011-2014 V6 Mustang 14 07-21-2011 01:49 PM
There are still some good parents out there... n8r The Bar 18 01-11-2008 04:01 PM
There are some crazy people out there..... Brent The Bar 1 02-12-2004 11:20 PM
08:09 PM
