Changing a transmission - Mustang Evolution
Old 06-25-2014, 04:32 PM   #1
SkylerTallman_'s Avatar
Hey guys as some of you know, I sold my mustang a couple days ago. I have my eyes on this really clean Gt but one downside. It's a automatic. It's a white 98 gt. How much would changing it from auto to manual cost me. If I can buy the transmission off of craigslist used for a couple hundred bucks or in a junkyard. How much does someone charge for labor on something like that. I would not want to try it myself. Lol
SkylerTallman_ is offline   Reply With Quote
Old 06-26-2014, 07:57 AM   #2
If you aren't going to DIY it will cost you more to do the swap than to find a clean manual car. Keep looking. Also you aren't going to get a trans in good shape for $200.
Or just buy the auto. 98 is actually a good auto. Late 97-onward is when they stopped sucking.
2000 Mustang GT Steeda #0048
Old 06-26-2014, 08:03 AM   #3
Actually I found a 5 speed and going to look at it in like 30min. Will post how it goes. It's a 94 5.0
Old 06-26-2014, 05:07 PM   #4
I got that red one so I don't need to swap a transmission now.! I'm set now
Old 06-26-2014, 05:19 PM   #5
Good, give that biznitch a full tune up, drain/fill trans and diffs, oil change, plugs and wires etc... Let me know if you need any tips, 94/95 cars are what I spent most of my time on over the years.
Old 06-26-2014, 05:23 PM   #6
Sweet, tomorrow I'm changing the oil, plugs and wires, disturber cap, and all the filters. And detailing if I have time
Old 06-26-2014, 05:24 PM   #7
Hey the speedometer doesn't work. Is that the sensor messed up or the gear is not working
Old 06-26-2014, 05:31 PM   #8
Autolite 25 coppers gapped to .054, Motorcraft wires, any old cap/rotor is fine, the 94/95 uses the FL1A oil filter and if the car has a lot of miles its probably a good idea to do the waterpump too. Its very easy on 94/95 cars, falls right off the front of the motor.
When you do the cap/rotor, look for a silvery dust inside the distributor. If it is there, you might as well do the whole distributor since the silvery dust is usually a sign of a failing PIP (pickup).
I'd also make sure the clutch cable is properly adjusted and do 3 quarts of synchromesh in the T-5, that's like mother's milk for transmissions and available everywhere. Fill through the shifter opening and this also allows you to see what/if any aftermarket shifter is in there.
Any mods on this car?
Old 06-26-2014, 05:36 PM   #9
It has full flowmaster exhaust, hurst short throw shifter (it likes to vibrate a lot), and he says it has a mild cam in it but I don't know. You can almost believe it is by the exhaust if you listen real close but then again it could have a bad idle Bc it's has 200,000 miles. so basically it's stock.
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 04:09 AM
Changing a Transmission...What is involved? riordain General Mustang Discussion 2 03-22-2010 01:38 AM
changing automatic transmission fluid 007z28350 Pre-2005 V6 Mustang 8 08-30-2009 02:25 AM
Changing transmission fluid electricstang Pre-2005 V6 Mustang 4 12-16-2005 03:11 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 05:49 PM
06:35 PM
