Rear end swap - Mustang Evolution
Old 06-27-2014, 09:44 AM   #1
Rear end swap
I have a 1997 v6 automatic stock 7.5 rear end. I recently bought a 2004 rear end with motiv 3.73 gears and a Ford racing t-lok. Will the 04 rear end bolt up in place directly with my 97? I know the tires will stick out a half inch more on each sides. I'm worried about the control arms and everything else bolting up correctly. Thanks.
Sent from my SM-N900V using Mustang Evolution mobile app
sunderwood is offline   Reply With Quote
Old 06-27-2014, 06:21 PM   #2
The actual 99-04 housing is wider by ~1.5" so the axles are wider, making the wheels stick out a bit more, not a huge deal.
I do believe the UCA and LCA bolt holes may be different sizes. I think the 99-04 are 14mm while the 94-98's are 12mm. That may be your biggest concern.
Old 06-27-2014, 06:59 PM   #3
+1 done this on my 98 v6 bolts are different but it all interchanges.
Bigshow14 is offline   Reply With Quote
Old 06-27-2014, 07:05 PM   #4
Thanks for confirming that. I thought they were interchangeable but having not done the swap myself I couldn't say for sure.
Old 06-27-2014, 07:10 PM   #5
How long you've had your Mach1?
Old 06-27-2014, 07:12 PM   #6
Not to jack the thread but I've had her about 3 weeks now. There's only one problem...I can't stop driving her!
Old 06-27-2014, 07:19 PM   #7
Yea im with you about the thread, I just asked because I remember some time ago you was wanting a Mach1. My screen name was bigshow98 but I forgot my password and changed emails so I had to start over
Old 06-27-2014, 07:32 PM   #8
Yah I started a thread asking about things to look for when looking at Mach 1's but didn't get much feedback lol.
Not too many active Mach owners on the site these days.
Luckily the bit of research I did do paid off and I ended up with a clean car.
Old 06-27-2014, 07:38 PM   #9
Perfect find 04, Azure Blue, I wouldn't have it any other way. Good luck with it and don't neglect the lil sixer lol. I'll catch you later on one of your posting.
Old 06-28-2014, 12:28 AM   #10
Thanks guys. I'll update you all on the swap Monday.
Old 06-28-2014, 12:31 AM   #11
BigShow-
Do you have any advice for me? I have the whole real axle assembly, but not the UCA and LCA. Do I need them from the 04 Mustang or can I use the 97's UCA/LCA? I thought they were interchangeable throughout the 94-04 mustangs so I didn't think to grab them when I bought the rear end. What exactly do you mean by the bolts are interchangeable?
Old 07-01-2014, 04:33 PM   #12
Install went perfect. No need for new bolts. If you're installing a 99-04 axle on a 94-98 all you need is the assembly. All bolts interchange, uca and lca will work. The only thing you need is a 23 tooth speedo gear from DallasMustang (not the 21 tooth from AM).
Old 07-01-2014, 06:35 PM   #13
I'm glad it worked out for you.
Old 07-01-2014, 06:38 PM   #14
Thanks. Just have to wait on the 23 tooth for my speedometer to be correct and it's perfect.
Old 07-01-2014, 07:18 PM   #15
Awesome! Glad everything went smooth for you.
Good to know that the bolts are interchangeable as well.
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
Mod 7.5 or Do An 8.8 Rear End Swap? Donny B Pre-2005 V6 Mustang 2 11-30-2003 04:15 PM
Rear End Swap Ken Pre-2005 V6 Mustang 13 10-02-2003 01:49 PM
finished my rear end swap Monkey Pre-2005 V6 Mustang 3 07-27-2003 05:23 PM
07:49 AM
