Floor jack or ramps - Mustang Evolution
Old 06-27-2014, 09:12 PM   #1
dacm99's Avatar
Floor jack or ramps
I need to buy either one to do my oil change. Pros and cons for either? I have a feeling at some point I will have both, but for the sake of oil change only what would you buy?
dacm99 is offline   Reply With Quote
Old 06-27-2014, 09:14 PM   #2
Rapinator126's Avatar
I have to use a low profile floor jack. Ramps hit my splitter b4 they even get to my tires themselves.
Old 06-27-2014, 09:17 PM   #3
dacm99's Avatar
That's what I was thinking. I eventually want lowering springs, at that point the ramps are a waste.
Old 06-27-2014, 09:50 PM   #4
GrabberMeBlue's Avatar
Put some smaller blocks of wood in front of them and drive up on them first. It will get you high enough that your splitter won't hit.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 06-27-2014, 09:52 PM   #5
Low pro jack alot easier
Old 06-27-2014, 10:10 PM   #6
Loc: Austin,TX
+1 on the floor jack and some stands. If you want to do some DIY ramps later......check these out.
Mustangworld - Build yourself some ramps !
Old 06-28-2014, 09:26 AM   #7
My vote goes to a quality set of stands and a jack. I have an older set of ramps that are saddled and I cannot simply pull either of my mustangs up them due to the front wheels being too wide. They will literally push the ramps forwards once the wheels make contact.
+1 on front splitter clearance. You won't have that problem with a jack/stands.
Old 06-28-2014, 03:07 PM   #8
I got some free ramps from my father which my car is too low to drive onto so I got a few 10" wide boards, cut them in equal lengths and I just use them to extend the ramps. I can have the car up on the ramps in about a minute although a low profile jack and jackstands would probably be just as fast which I use sometimes as well.
Old 06-28-2014, 03:20 PM   #9
Tyoung68's Avatar
Cant change pretty much any suspension parts on ramps
68 coupe resto mod check my garage for pictures
Old 06-28-2014, 03:24 PM   #10
JoeyM91's Avatar
I use ramps for mine, but I also have a jack and stands. But I will say at stock ride height, the ramps I have there's maybe 1-2cm clearance between the front splitter when it sits at the bottom of the ramps. Once I get it up on them, there are no issues.
But as the others have said, once you lower it or get fatter tires, ramps may not be a great option.
Old 06-28-2014, 03:42 PM   #11
nhcowboy's Avatar
Low profile ramps for oil changes... I also have low profile jack/stands for other work.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 06-28-2014, 04:51 PM   #12
Correct, although OP was asking about oil changes.
1979 Gold Trans Am
Old 06-28-2014, 04:54 PM   #13
Adogg's Avatar
I had ramps they worked fine then got a chin spoiler and now it scraps so I use jack stands now
Don't hate....... appreciate
Old 06-29-2014, 02:07 AM   #14
Tyoung68's Avatar
I guess i missed the first post but id still get jack stands over ramps if i could only have one
Old 06-29-2014, 08:35 AM   #15
dacm99's Avatar
Thanks guys, I'm going to get a two ton low pro jack from harbor freight.
I have a coupon for the 1.5 ton racing jack( 59 bucks). But the mustang just exceeds that jack rating.
Old 06-29-2014, 08:38 AM   #16
1.5 ton will be more than enough. Your not lifting the whole car up.
Old 06-29-2014, 10:23 PM   #17
dacm99's Avatar
My god, it's amazing that I can remember to breath. Man am I glad you said that. De-da-de. $u&king moron I am.
Old 07-01-2014, 01:03 PM   #18
610swolf's Avatar
I have ramps and a low profile jack. I only use the ramps for oil changes however. It's just quicker for me instead of the jack and jack stands when doing something that simple.
610swolf is offline   Reply With Quote
Old 07-01-2014, 01:06 PM   #19
610swolf's Avatar
The 1.5 ton aluminum racing jack from harbour freight is the one I have . It works pretty good and it's very light. I took mine to NMRA with me last year and to autocross events when I want to switch tires.
Old 07-01-2014, 08:27 PM   #20
I have the low profile jack from HF as well. Half my **** is from that store. Yeah its chinese made... so is everything else. Its all lifetime warrantied and so far its all worked great.
Jack & jack stand point Otis 2011-2014 V6 Mustang 6 10-15-2013 12:48 AM
Where to lift rear with floor jack? 02GTvert 1996-2004 Mustang GT 10 05-26-2013 01:27 PM
Where to buy a good floor jack and stands? MachMan1017 General Mustang Discussion 17 03-06-2013 04:12 PM
Floor jack advice JBillone General Car Discussion 10 10-20-2011 06:17 PM
Anyone else LOVE parking ramps? jimmy_beaner The Bar 6 08-20-2005 05:38 PM
10:02 PM
