Raxiom halo projection HELP - Mustang Evolution
Old 06-28-2014, 11:10 AM   #1
2011 Kona Blue's Avatar
Can anybody tell me what HID bulb size do I need to fit this kit for my 2011. I do not have factory HID's and ordered a HID hit that comes with OEM size H13 bulbs. The H13 bulb is way too big to fit the Raxiom housing. What size HID kit do I need? Will a D2R size work. I need a dual beam HID kit?
Sent from my little Johnson.
Old 06-28-2014, 01:12 PM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
I believe the Raxiom headlights use a H9 bulb. Your best bet is to look at the bulb that came with the headlights. Should be marked with what size it is.
Sent from your mom's house.
2012 Kona Blue 3.7L V6:
Old 06-28-2014, 01:39 PM   #3
Your right. They do use H9 so I guess I need a H9 HiD bulbs. *****. I need an exchange. Ha ha ha
Old 06-28-2014, 02:12 PM   #4
JoeyM91's Avatar
If I remember correctly when I put my first set on, depending on the kit, you'll also need an H9 > H13 harness adapters, the connectors are slightly different. It's been a while though.
Now once I figured out the first kit was eBay/Amazon crap I stepped up to a good quality Morimoto kit. It came with a relay to the battery and it had the correct connectors and plugged straight up. (P.S. don't run HIDs without a relay harness. The ballasts/bulbs will burn up quick, especially if they're cheap)
Old 06-28-2014, 02:42 PM   #5
Couldn't agree more on going with a good kit vs the DDM/VVME/Kensun garbage. However, HIDPlanet has been reporting of a slew of Morimoto ballast issues lately which hopefully have been ironed out at this time. Scared me away from Morimoto though because it was happening when I was looking. I found a similar kit from XenonDepot, the "Volt" kit for $85 shipped on sale with a forum discount code I yoinked off a Lexus site. High quality ballasts, quartz glass bulbs and laser aligned on the bases.
And yes, almost every projector you can get uses a different bulb than stock including the ones I got for my 98. Instead of a 9007 it uses a 9006 and 9005 dual setup. Which is perfect because that allows me to run HIR bulbs in the hi-beam reflector.
Old 06-28-2014, 02:44 PM   #6
JoeyM91's Avatar
Have had 0 issues with mine so far. Could have been a bad batch between a certain timeframe. But Morimoto's customer service is excellent and they warranty all of their stuff.
Old 06-28-2014, 03:01 PM   #7
It was bad wiring in the ballasts themselves. A few ppl actually pulled them apart and just ran thicker/new wires and the ballasts worked fine. I'm not saying the company isn't good, I'm just saying that there was a bad run of ballasts this year that may or may not be sorted out yet so do your research. I have had 0 issues with my XenonDepot stuff and they are also a top notch company and highly recommended on HIDPlanet. They're Canadian based too so no dealing with the Chinese and someone speaking Engrish on the other end if you even get someone at all.
Old 06-28-2014, 03:35 PM   #8
If anyone was wondering H13 HID bulbs don't fit in the Raxiom projection halo lights. ***** I ordered the wrong HID bulb size kit. Ha ha ha
Here is the Raxiom projection halo lights off and on with out my HID lights because I'm a putz and ordered H13 bulb kit.
ID:	160278   Click image for larger version
Ordered Raxiom smoked projection halo headlights! 2011 Kona Blue 2011-2014 V6 Mustang 19 05-30-2014 10:22 AM
Raxiom Smoked Projection Headlights 2011 Kona Blue General Car Discussion 25 03-31-2014 08:40 PM
Raxiom ccfl smoked halo projector headlights 08SteedaQ350 FYI Ads | Recently Listed 5 06-16-2013 08:11 AM
Raxiom Chrome halo projector lights Robbiemustang96 Pre-2005 V6 Mustang 14 03-23-2013 01:26 PM
Dual ccfl halo raxiom smoked headlights Crafty615 Mustang Paint, Appearance & Detailing 8 01-04-2012 06:06 PM
05:30 PM
