Thinking about lowering - Mustang Evolution
Old 07-26-2014, 08:38 AM   #1
SixBanger's Avatar
So I'm finally thinking of lowering the car a little. I'm not slamming it, I just wanna get rid of some of the fender gap (especially in the rear). What I'm looking at are the Steeda Sport Springs on AM. They look like a good choice for me because it's very mild drop (1.0 front, 1.25 rear). I guess I'll also need an adjustable panhard bar too. I'll probably have a shop install them so I'll have them realign the wheels too. Is there anything else I need to do? I just figured I wouldn't because of how slight the drop is. Also, the Steeda Sport Springs only have one review on AM. Are they not that great? It got a good review. Lol
2014 V6 Base Coupe, Sterling Gray Metallic///3.31 Gears///FP6 Appearance Package///Tech. Package///Reverse Sensing and Security Package///Mods: Boss 302 grille, MMD Ducktail Spoiler, Weathertech Floor Mats, Bassani Axle-Back Exhaust
SixBanger is offline   Reply With Quote
Old 07-26-2014, 12:10 PM   #2
SixBanger's Avatar
Also looking at the Steeda Ultralites which would be a 1.25F/1.5R drop.
Old 07-27-2014, 06:26 PM   #3
tj@steeda's Avatar
You can check out more reviews here:
Steeda 2005-14 Mustang Coupe Sport Springs - Made in USA 555-8215 - Free Shipping!
Yes, it is recommend to get a panhard bar when lowering these cars. The rear end tends to shift upon lowering.
If you are looking to do shocks/struts down the road ... it may be more cost effective to do them at the same time as the springs (same install labor).
Also, it depends on what you are looking for more in the springs.
The Ultra Lites will provide a slightly ride better than the Sports Springs.
The Sports Springs offer better handling.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 08-01-2014, 05:28 PM   #4
Savage_5.0's Avatar
Here are h&r super sports on 20" wheels. Love it! Did it myself and the took it to get aligned and they said it was perfect. No camber plates or pan hard bar. Click image for larger version
Name:	ImageUploadedByMustang Evolution1406935699.873551.jpg
2013 5.0 Premium. | H&R Super Sport Springs | 20" Black AMR Wheels | Roush Axle-Backs
Savage_5.0 is offline   Reply With Quote
Old 08-02-2014, 12:54 PM   #5
SixBanger's Avatar
Originally Posted by Savage_5.0 View Post
Here are h&r super sports on 20" wheels. Love it! Did it myself and the took it to get aligned and they said it was perfect. No camber plates or pan hard bar. Attachment 162679
So all you did was the springs?
Old 08-02-2014, 01:16 PM   #6
Savage_5.0's Avatar
That's it. Ride is good. Cut about .5" off the back bump stop. Alignment is perfect. Ima upgrade the shocks eventually.
Old 08-02-2014, 04:13 PM   #7
Take measurements of the rear end of your car, see if the tires are exactly the same distance from the fender edge on both sides. When you lower a car with a panhard bar, the angle of the bar changes and it physically pushes the rearend to the left as the angle is reduced. This is why you need an adjustable bar when lowering, you shorten it up when you lower to keep the rear centered.
I would be HIGHLY suspect of any alignment shop that just says "G2G" on a lowered car with no CC plates or adjustable PH bar.
Old 08-02-2014, 05:45 PM   #8
silvr002001's Avatar
H&r super sports look fantastic. Had them on my 03. The ride was outrageously stiff though. The camber was totally whacked out after the install. The alignment was totally effed also. I opted for a less aggressive spring on my 05. Love the way H&R's look though
silvr002001 is offline   Reply With Quote
Old 08-02-2014, 05:46 PM   #9
Savage_5.0's Avatar
I watched the machine. Everything was perfect.
Old 08-02-2014, 08:38 PM   #10
Oh2freshstang's Avatar
That's it. Ride is good. Cut about .5" off the back bump stop. Alignment is perfect. Ima upgrade the shocks eventually. Sent from my iPhone using Mustang Evolution
How did u cut the bump stops? Got a pic?
Old 08-02-2014, 08:43 PM   #11
Savage_5.0's Avatar
It's like a Christmas tree shape kinda. I cut the top tier off.
Old 08-03-2014, 04:00 AM   #12
It's like a Christmas tree shape kinda. I cut the top tier off. Sent from my iPhone using Mustang Evolution
What did u use to cut it off?
Old 08-03-2014, 04:05 AM   #13
Savage_5.0's Avatar
Razor blade. It's just that polyurethane ****.
Old 08-03-2014, 04:24 AM   #14
Razor blade. It's just that polyurethane ****. Sent from my iPhone using Mustang Evolution
cool thanks!
Old 08-07-2014, 10:07 AM   #15
MADSCOTSMAN's Avatar
05-10 Koni Yellows
BMR Springs (1.5" drop all 4 corners)
BMR Panhard Bar
GT500 Strut Mounts
BMR LCA relocation brackets
bump stops cut 1" off back ones, 1/4" inch off front ones
If you keep your car long enough after just a spring install, apparently the OEM shocks will ware out prematurely and will need replacement. replacing the shocks with the springs initially, you pay the same labor only once if having it done at a shop
MADSCOTSMAN is offline   Reply With Quote
Thinking about lowering slonison 2011-2014 Mustang GT 96 07-22-2013 12:31 PM
Thinking of lowering? ChrisD522 1996-2004 Mustang GT 6 06-23-2013 07:08 PM
Thinking about lowering my car Rcary Mustang Paint, Appearance & Detailing 6 05-13-2012 01:09 AM
Thinking about some lowering springs 2002Gt 1996-2004 Mustang GT 68 06-25-2011 11:45 AM
i was thinking about "things i would never do"... tire The Bar 37 07-30-2003 05:58 PM
06:39 AM
