4 Ways and Brake Lights 2013 - Mustang Evolution
Old 08-20-2014, 02:33 AM   #1
Mlarv5's Avatar
I was attending a funeral for a friend yesterday, and had to use my 4 ways whiel we where in the persuasion. The person behind me was driving a 65 Mustang GT and said that with my 4 ways on when I hit the brakes my brakes lights didn't come on. I went to the dealer afterwords and found out only the third brake light will come on the two rear lights keep flashing. Is this the way it is on your car because it just doesn't seem safe to me.
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 08-20-2014, 04:44 AM   #2
bucko's Avatar
The emergency flasher lights use the same circuit as the directional (turn signals). This circuit is also your brake lights, so yes, it's the normal operation. From the owners manual:
HAZARD FLASHER CONTROL
The hazard flasher control is located
on the center console next to the
gearshift lever. The hazard flashers
will operate when the ignition is in
any position or if the key is not in
the ignition.
Press the flasher control and all front and rear direction signals will flash.
Press the flasher control again to turn them off. Use it when your vehicle
is disabled and is creating a safety hazard for other motorists.
Note: With extended use, the flasher may run down your battery
Old 08-20-2014, 07:51 AM   #3
Abominable Mustang
WhoDat's Avatar
Region: Alaska
It's just like when you use your turn signal with brakes applied. One tail light and the third brake light will come on while the other tail light will flash. It's normal operation of any vehicle that has turn signals incorporated into the same bulbs used for its brake lights.
2012 Kona Blue 3.7L V6:
Old 08-20-2014, 08:24 AM   #4
Mlarv5's Avatar
OK I guess I am going to have to check this on my other car. I always thought when you hit the brakes the 4 ways stopped and the brakes lights just stayed on. I understand the turn signal working that way.
In fact the 2010 in front of me worked that way. His brakes lights would stay on the stop flashing while his foot was on the brake. So did the 65 GT
Old 08-20-2014, 08:27 AM   #5
Mlarv5's Avatar
the ignition.
I understand how they work I was using them. I just didn't understand that they would keep flashing while I pressed on the brake I am pretty sure in my other cars the 4 ways stopped and the brakes lights like normal until you let off the brake. In fact the 2010 in front of me worked that way. His brakes lights would stay on the stop flashing while his foot was on the brake.
Ways to drop weight from auto 2013 GT Premium. mustangz General Mustang Discussion 5 01-19-2014 09:37 AM
Ways to reduce body roll and stiffen suspension geepoons 2011-2014 V6 Mustang 10 02-03-2013 09:36 AM
Turn lights/ brake lights Mustang_Madness 1996-2004 Mustang GT 8 01-14-2013 08:14 AM
no headlights, tail lights or brake lights 68dnixcoupe Classic Mustangs 4 05-01-2012 05:49 PM
Idiot people and their idiot ways DropTop_Stang Pre-2005 V6 Mustang 5 08-08-2003 12:37 PM
01:15 PM
