Rear gear help - Mustang Evolution
Old 09-20-2014, 06:38 PM   #1
Luna1994's Avatar
Region: Utah
Rear gear help
So I hit a bump to hard and messed up my rear end. I replaced all my beArings and seals and now iv found out my 4.10s are bad and have to be replaced. Do I have to by new instLl kit?
Luna1994 is offline   Reply With Quote
Old 09-21-2014, 03:38 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
If you've already replaced all of your bearings and seals, you should be good with just the new gears.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 09-21-2014, 10:13 AM   #3
JoeyM91's Avatar
Make sure the new gears also come with a new pinion crush sleeve as well.
On a side note, how hard did you hit?! That's a lot to snap gears. Unless you went with a cheaper manufacturer like motive or yukon.
5th gear, gear noise? SitinprettyGT 1996-2004 Mustang GT 6 01-10-2013 06:37 PM
Help! 1st gear issue / 5th gear grinding Missxalii General Mustang Discussion 2 06-06-2012 01:18 PM
1st gear & 2nd gear out! Vick Classic Mustangs 3 05-01-2012 08:29 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
10:45 AM
