First oil change and a slightly stupid question - Mustang Evolution
Old 11-11-2014, 09:58 PM   #1
Question First oil change and a slightly stupid question
Hello everyone
I've gone and done my first oil change and decided to go with Motorcraft synth blend and filter seeing as how they're Ford recommended and price was good for my purposes (not driven hard, no stop-go traffic), and people seem well satisfied with it.
But onto the main part of why I'm posting this thread, after I had drained the oil and replaced the filter, it was time to put in the new oil. I put in the first 5 1/4 quarts of oil and everything is dry underneath. But then I foolishly decided to start the car to get the oil flowing before I add the remainder of the oil, thinking it will help or something.
I start up the car and it makes no noise for the first 10 seconds or so, but then I hear a familiar chatter noise that I sometimes hear on morning start-ups. I let it run for no more than 25-30 seconds tops, and shut it off. I add the remainder of the oil and close everything up and it's bone dry underneath. Test drove it and everything seems to be hunky dory.
So my question after this wall of text is; did I harm the engine by starting it up without the full 6 quarts of oil?
TL;DR: Filled up the engine with 5 1/4 quarts, started and idled it for 20 something seconds, shut off, added the rest. Did this hurt anything?
EDIT: Also I had the oil cap off while it was idling, not sure if this causes an issue.
jayg20769 is offline   Reply With Quote
Old 11-12-2014, 12:29 AM   #2
natestang07's Avatar
You are probably fine but I always fill it all the way at once and never idle without the cap on.
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 11-12-2014, 04:55 AM   #3
bucko's Avatar
You did no harm. No worries. Most auto manufacturers discurage topping off oil between oil changes unless it gets to the "add" mark on the dipstick; I guess this is to prevent overfill if the engine is not perfectly horizontal when checking it.
What some folks will do to aid in getting quicker oil pressure on a fresh oil change is to fill the new oil filter with oil prior to its install, but these engines make that difficult/messy, as the angle of the filter (at least on the 3.7's) make that darn near impossible with their horizontal position.
Old 11-12-2014, 09:52 AM   #4
I'm glad to hear that. I don't remember where I picked up the habit of starting the car right before the last bit of oil or so but I'm going to stop doing that. Also I'll stop running the engine with the cap off. I thought it did no harm.
Old 11-12-2014, 10:07 AM   #5
Strange Mud's Avatar
don't do that again.
Old 11-12-2014, 03:34 PM   #6
You said 6 qts. Hope its not a GT it takes 8 qts.
bodon is offline   Reply With Quote
Old 11-12-2014, 05:03 PM   #7
Sadly yes, it's not a GT. Still love it.
Old 11-12-2014, 09:33 PM   #8
24kmach's Avatar
24kmach is offline   Reply With Quote
Old 11-13-2014, 08:33 PM   #9
Embarrassing thing is, I saw this video right before I started. But I was cocky because I had done plenty of oil changes (now I know incorrectly), so I only watched the video to find where the drain plug was.
Old 11-14-2014, 08:12 AM   #10
Lol, not even 1 quart low you are totally fine. Don't worry about it although I have 0 clue why if you knew it needed 6 quarts you didn't just put 6 quarts in... like... why stop at 5.25 and then start it?
Old 11-14-2014, 08:52 AM   #11
To be honest I don't even remember why I started doing that. I think I heard somewhere when I was younger that you need to run the engine a bit to get the oil flowing before you put more in. I never questioned it until now and thinking about it again it sounds extremely dumb.
Question about my first oil change. Devil Strider 2011-2014 Mustang GT 9 11-14-2014 01:04 PM
First oil change what oil sinister 2011-2014 Mustang GT 48 08-18-2014 07:57 AM
First oil change on 2014..QUESTION 1800CoolGuy 2011-2014 V6 Mustang 3 06-29-2014 08:30 PM
oil intake valve slightly loose? ironsurvivor 2011-2014 V6 Mustang 13 09-13-2013 03:54 AM
Stupid stupid stupid!!!! lowflyn The Bar 10 10-23-2004 07:33 PM
11:27 PM
