Want to take good pics of my green Mustang. - Mustang Evolution
Old 12-25-2014, 01:16 PM   #1
My iPhone has a hard time taking good pictures of the Gotta Have It Green my car has. It always looks washed out in the sun, and only close to the actual color away from the sun. My reg old digital camera looks 20x worse, almost white!
Josh_101 is offline   Reply With Quote
Old 12-25-2014, 01:23 PM   #2
Stangholio's Avatar
Hard to do with a small pic. Not that clear of an image. Little better though.
GHIGitty
Stangholio is offline   Reply With Quote
Old 12-25-2014, 01:27 PM   #3
Stangholio's Avatar
GHIGitty
Old 12-25-2014, 01:29 PM   #4
Yeah I played around with the iPhoto app on the iPad to up the saturation, and that gets it their.
Old 12-25-2014, 01:35 PM   #5
Stangholio's Avatar
I feel your pain. I adjust most of my pics on snap seed on ipad. Otherwise the pictures don't do the car justice.
GHIGitty
Old 12-25-2014, 01:49 PM   #6
I would like to know if there's a good camera out their that can take pics of the color accurately
Old 12-26-2014, 01:02 PM   #7
Accurate colour capture is somewhat problematic in most affordable cameras. Some brands, and some models of brands, capture certain colours better than others. If a camera has a light sensitive lens, it sometimes works to aim at a bright source such as the sky, press the button down halfway to "lock" the setting, and then redirect the lens to the object being photographed and press the button all the way to take the photo. The viewfinder or image plate on the camera will show what the photo and colours will look like. Conversely, one can aim at a darkened area, "lock" the lens, and then complete the photo of the desired object. Experimenting with this system can bring good results. But if the camera can't accurately capture the colour regardless of lighting, then the picture may need to be edited. Some cameras will let you do this in-camera. Otherwise, some type of computer-assisted editing file such as iPhoto in Macs can help.
cheval is offline   Reply With Quote
Old 12-31-2014, 02:20 PM   #8
Buy a DSLR. I paid $500 shipped for a Nikon D3200 with two lenses and a case on cyber Monday. Usually they are in the $800-$1k range.
If you can't afford that then maybe look for a used lower end 4/3 camera like this
http://www.amazon.com/Olympus-E-PL1-.../dp/B0035LBRJO
I paid $125 shipped from the evilbays for one of these with the lens and case last year. Takes really good pics even with the lower megapixel count and extra lenses aren't that much $$$. The DSLR blows it out of the water obviously but still much better than a smartphone.
Some of the newer cameras on some of these phones like the G3 and s5 are real good but you'll never get close to what a good dedicated camera will do.
Old 01-02-2015, 06:38 PM   #9
chopper's Avatar
How's this
chopper is offline   Reply With Quote
Old 01-06-2015, 09:52 PM   #10
If you want to take an accurate picture of your car's color, you will need to adjust the white balance, color temperature and metering of your photo. Most cameras use an automatic white balance system which is generally accurate but is often fooled in various lighting scenarios such as back or side lighting. You need to be able to set a manual white balance for the light hitting your subject using a grey card. Your camera's auto metering system is set to render an 18% grey card as the reference for color. If your subject is not 18% grey, the metering system tries to adjust your color to fall into this window.....hence the reason you get grey snow instead of white. So you will either need to use a grey card to set your white balance and then meter your subject manually, or use your exposure compensation to adjust the metering.
Generally cell phone and tablet cameras do not have these options. You get get after market photo aps that will help, such as Procamera or 645Pro, but ir is better to get a feal camera such as a micro 4/3rds camera or a DSLR or high end compact. These will allow direct manual control off all options. Then tweak in Photoshop or Lightroom and your done.
jdglover is offline   Reply With Quote
94 dark forest green pics? Army_Stang Mustang Wheels & Tires 3 12-06-2011 11:21 PM
I want to keep the 3.8 liter v6 in my mustang but i want performance? yitzchak8 General Mustang Discussion 10 03-22-2010 05:43 PM
67 Mustang "Bullitt Green" atc89 Mustangs for Sale and Wanted 2 09-02-2006 09:49 PM
So you want to donate, and you can't/don't want to use Paypal: Brent ME Site Help & Announcements 0 12-06-2005 11:35 PM
Anyone want to take a shot at a sig for me? Ken The Bar 7 10-08-2003 05:18 PM
01:49 AM
