Changing Diff Fluid - Mustang Evolution
Old 01-15-2015, 10:50 AM   #1
JoeyM91's Avatar
Changing Diff Fluid
So it's about time for another change since my gear swap was a good bit of time ago but I can't find any solid instructions since I have an aftermarket diff cover.
It's the Steeda cover with fill and drain ports.
I know it's as easy as unbolting the drain plug, draining and cleaning the magnetic plug, then some thread sealant, then tighten for the drain.
Then open up the fill port and use the friction modifier first and then the oil.
I guess my question is for the people that have these diff covers: Were you able to do it straight from the bottle or did you need a fluid pump to reach the fill port?
Of course, if I'm missing anything, let me know. This would be the first time I've ever changed it myself.
Old 01-18-2015, 02:58 PM   #2
I don't have the Steeda cover but I have the Factory aluminum finned diff cover that I installed when my car had about 3,600 miles on it and it has the fill and drain ports on the cover.
On my cover I had to use one of those fill hoses that you attach to the bottle that you turn the attachment to open and close the flow of oil. There was no enough room for me to just fill it from the bottle. I have since bought a fluid pump just for this at Autozone that I will use next time since the thing I was using still made a mess.
You can also still fill the rear end from the fill plug in the front of the pumpkin.
Wayne
2014 GT/automatic/Sterling Gray Metallic/GT500AB/GT500 OTA pipes/Bob's oil catch can/Ford aluminum finned diff cover. Ford STB.
70monte is offline   Reply With Quote
Old 01-18-2015, 05:17 PM   #3
JoeyM91's Avatar
Wayne
Gotcha, I hadn't taken a look under the car to judge the distance but I figured it'd be too tight. I'll pick up a fluid pump.
Thanks!
Diff fluid Screaming Mach General Mustang Discussion 6 10-19-2013 10:01 PM
Rear diff fluid 96 stang General Mustang Discussion 12 06-27-2011 06:10 PM
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
changing the differential fluid greenpony02 1996-2004 Mustang GT 17 06-12-2010 12:03 AM
Changing transmission fluid electricstang Pre-2005 V6 Mustang 4 12-16-2005 02:11 PM
03:47 AM
