1995 SVT Cobra - Mustang Evolution
Old 01-23-2015, 08:58 AM   #1
1995 SVT Cobra
So after reading many forums I am still inconclusive as to what my problem may be. About a week ago my car wouldnt start the first three times I cranked it over. (It is cranking fine, just no spark). It was pretty hit and miss as to when it would fire right up or not. So a week later the problem slowly seems to be getting more and more persistant. It has never died on me once started and running, so between that and the intermittency I am puzzled. I am running a Kenne Bell SC and full two stage MSD ignition. Only things I can think of is possibly an ignition control module on its way out, maybe the PIP, or some sensor. Any insight would be fantastic.
1995 SVT Cobra
Kenne Bell SC
2 Stage MSD Ignition
95CobraGuy is offline   Reply With Quote
Old 01-23-2015, 09:04 AM   #2
Do you have the 5.0 pushrod in it or a different engine in it?
After all is said and done, more is said than done...
Old 01-23-2015, 01:12 PM   #3
5.0
1995 SVT Cobra
Kenne Bell SC
Old 01-23-2015, 01:15 PM   #4
What's the miles and how long has it been since a tune up was preformed on the car?
Old 01-23-2015, 01:19 PM   #5
140k so its definately getting up there. I gave it a standard tune up, plugs, oil, and what not, about 6 momths ago.
1995 SVT Cobra
Kenne Bell SC
Old 01-23-2015, 01:21 PM   #6
What about spark plug wires? And something I'd do is check the timing and double check that the correct wire was put on the correct spark plug.
Old 01-23-2015, 01:25 PM   #7
They all appear to be fine but i will double check them And timing.
1995 SVT Cobra
Kenne Bell SC
Old 01-23-2015, 01:35 PM   #8
I'd love to know more about your car. I'm planning on going back into circuit racing and my plan was a 94/95 cobra as my race car if you don't mind me asking what else have you done to the engine and what's the power you're making with the supercharger?
Old 01-27-2015, 09:15 AM   #9
Are you the same 95CobraGuy from the corral? Anyway, id say its the pip or the coil. MSD is also not a very good company these days (or recently). Msd=might suddenly die/my spark disappeared.
I would bypass the msd ignition and see if the problem persists. is your distributor stock or msd?
Old 01-27-2015, 12:17 PM   #10
Hmm I dont think so. As far as your advice; wouldnt the coil or pip cause the car to suddenly die while running too? It hasnt ever done that. Only when starting
1995 SVT Cobra
Kenne Bell SC
Old 01-27-2015, 01:01 PM   #11
I had all sorts of issues with the PIP in my car. Like I said I'd bypass the MSD stuff you have and see if it works with the stock ignition.
Old 01-27-2015, 06:02 PM   #12
My entire system is msd. Distributor, cap, coil, plugs, everything...
1995 SVT Cobra
Kenne Bell SC
Old 01-27-2015, 08:43 PM   #13
Hmmm, could be something in the Might Suddenly Die system or it could be something as simple as a bad ground. Check all your grounds first. You do your fuel filter anytime recently? That could be plugged up too. Trying to think of anything else simple it could be...
Also as far as the ignition, all you really need is a hotter ignition box for a supercharger. The stock ignition is more than capable of handling anything the stock block can take once that is added to the mix. But since you already have it all replaced that doesn't pertain to you anymore really.
Old 02-18-2015, 10:56 AM   #14
So after all this it ended up being that my coil went out. I went to napa and replaced it with a generic model coil for my car and it fired right up. A day went by of it starting and running fine until i parked it that night. Went to start it up the next day and nothing again...and ideas? Do i need an msd coil if i am possibly gapped more on my plugs?
1995 SVT Cobra
Kenne Bell SC
Old 02-18-2015, 05:49 PM   #15
1995 SVT Cobra
Kenne Bell SC
Its the PIP in the distributor. Same thing happened to mine. It'll keep eating coils until you replace the PIP or the whole dizzy. You may just have a bad one, would not be the first MSD product to be garbage as they are all made in China these days anyway.
svt
2001 SVT Cobra :: 2001 Ford SVT Cobra 98StangKid Member Garages 0 06-22-2012 03:49 PM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1995 Mustang Cobra :: 1995 Ford Mustang Cobra jwhayne0001 Member Garages 0 08-20-2011 11:22 PM
04:46 AM
