Blackwolf Performance Oil/Air separator kit - Mustang Evolution
Old 03-08-2015, 10:48 AM   #1
What do you think?
ID:	176967   Click image for larger version
blackwolfndn is offline   Reply With Quote
Old 03-08-2015, 11:04 AM   #2
Commercial Member
au01st's Avatar
Looks like a good way to introduce unmeasured air after the MAF sensor...
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 03-08-2015, 11:11 AM   #3
No the negative PCV valve is capped to prevent unmetered air from entering AFR has been steady thru testing at idle and street.
Old 03-08-2015, 11:45 AM   #4
Location: Camp Pendleton North (San Clemente/Orange County
Does it actually do anything for you?
Sent from my SM-G900P using Mustang Evolution mobile app
swhitfield2013 is offline   Reply With Quote
Old 03-08-2015, 12:11 PM   #5
Yeah its great! I wish i had taken pictures but after 2.5k miles of driving without it, I opened the intake manifold and it was fairly dirty and gunked up underneath, then after installing the catch can i drove for another 2.5k miles and the inside was prefectly clean. The can catches a lot of excess blow-by.
Old 03-08-2015, 12:16 PM   #6
So just a portion of the air is diverted through the lines?
Old 03-08-2015, 12:28 PM   #7
Yes the air from the BOTH positive PCV valves enters thru the lines and exits thru the breather. It utilizes both the passenger AND driver side PCV valves at the same time unlike most oil catch cans where you have to buy 2 to utilize both.
Old 03-08-2015, 12:34 PM   #8
DiESeven's Avatar
Here's my JLT oil separator. Just emptied it today after 1,300 miles of it installed. Click image for larger version
Name:	ImageUploadedByMustang Evolution1425839644.671808.jpg
Old 03-08-2015, 04:04 PM   #9
Commercial Member
au01st's Avatar
So if the air is only vented what is the purpose of the can? Seems like it's just a breather filter with an oil collecting unit and no air is returned to the intake?
And do you have any affiliation with the product?
Old 03-08-2015, 04:22 PM   #10
It is unmeasured in stock form, this just vents it instead while catching the oil.
2011 Mustang 3.7: 13.2 @ 105
BBK Shorty, MRT H, Borla S, 3.55 Gear, MPT Tuned.
LiveWire003 is offline   Reply With Quote
Old 03-08-2015, 04:24 PM   #11
Not to sure I am digin on that.
Teak 14 is offline   Reply With Quote
Old 03-08-2015, 06:53 PM   #12
Yes it vents the air but it also collects the Blow-by in the can... I'll be taking a 500 mile trip Tuesday so I'll empty it out and post some pics
Old 03-08-2015, 06:56 PM   #13
What dont you like??
Old 03-08-2015, 07:17 PM   #14
Commercial Member
au01st's Avatar
I thought one of the benefits of a catch can was the maintaining of a bit of octane boost without the sludge? Crank case gas shouldn't be just plain air, which is the reason it is recirculated in the first place (emissions).
And what is your affiliation to the product?
Old 03-09-2015, 05:54 AM   #15
I don't like the looks under the hood and it seems like it not a close circuit. Also will let gases out and that is the purpose of it being close. Not saying it does not work!!!
Old 03-09-2015, 06:55 AM   #16
I am part of the Design team.
Old 03-09-2015, 07:38 AM   #17
MustangDawg's Avatar
Originally Posted by DiESeven View Post
Here's my JLT oil separator. Just emptied it today after 1,300 miles of it installed. Attachment 176971
+1
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 03-09-2015, 10:20 AM   #18
Voltwings's Avatar
Seems to be some confusion here.
In stock form, (metered) air comes IN the crankcase from the drivers side from the air intake, and OUT the passenger side flowing into the intake manifold. This is due to the intake manifold having significantly higher vacuum (post throttle body) then the intake (pre throttle body).
So, under this scenario you have fresh air flowing in, and contaminated PCV gases flowing out of the crankcase. The affects are cleaner emissions, but typically some "reduced" performance in the case of dirty valves, oil in the intake, and in excessive cases reduced octane if enough oil is present.
Your typical Catch can, like my Bob's firewall mounted unit, serves to still allow the stock system to actively pull those PCV gases out of the crankcase but allows that oil and gunk to fall out of suspension and into a can. In this case, only "clean" air is making its way back into your intake manifold, since the oil and gunk has had a chance to separate out.
VTA (vent to atmosphere) on the other hand, is where people just simply install breather filters on both valve cover fittings and cap the air intake / intake manifold. No metered air is going through the crankcase in this scenario, so there's no potential for vacuum leaks in doing this. The only downsides are potentially messy valve covers, and the system is no longer actively pulling a vacuum on the crankcase. It can be argued that most engine seals / piston rings prefer a vacuum to healthy operation, but that is not the point of this thread, I am just trying to cover the pros and cons of both.
This system is kind of a "meet in the middle" type deal. It is still 100% VTA, so no chances of vacuum leaks, but it gives the oily gases a chance to fall out of suspension into a can, instead of just venting all over the valve covers. Its not as cheap as just putting some filters on, but I would imagine if going VTA is your plan, this will be the better choice.
The only way to have a vacuum leak when going VTA is if you only vent one valve cover and leave the other attached to either the intake, or intake manifold.
Old 03-09-2015, 10:25 AM   #19
Well said, explained it much better than myself lol.
Old 03-09-2015, 10:27 AM   #20
TedG's Avatar
I use a JTL and it works very well at catching oil.
Yesterday, I emptied the can and it was very hot. When I went to screw it back in to place, it slipped and fell under the car. I couldn't reach it without moving the car. Guess what? The car won't start with the oil-catch system open. I had to push the car. Once the can was screwed back on, everything was fine.
Become an Organ Donor today: http://donatelife.net/register-now/
Save as many as 50 lives. Thanks.
TedG is offline   Reply With Quote
Old 03-09-2015, 10:43 AM   #21
This is a great kit... I have it on my GT works extremely well way better than my old Mishimoto did (which was good too)
Fast5.0 is offline   Reply With Quote
Old 03-09-2015, 11:16 AM   #22
Lorraine's driver
ab_mach1's Avatar
^My preference.
Instagram: @ab_mach1
Old 03-09-2015, 11:17 AM   #23
Voltwings's Avatar
Because massive vacuum leak.
Old 03-09-2015, 11:23 AM   #24
Kevin.Cook
Guest
Posts: n/a
I would have held on to the original line just for events like this. Not common but helpful if you hang on to it.
Old 03-09-2015, 11:25 AM   #25
Absolutely, I keep mine in the trunk in my tool kit just in case
Old 03-09-2015, 12:22 PM   #26
smurf stang's Avatar
I think some people got a little confused as this is only capturing the crankcase pressure into a vented catch can. This is not like the oil separators from JLT or Bob's which recirculate it back into the intake manifold.
2016 VW GTI 2.0 Turbo
Old 03-09-2015, 05:28 PM   #27
what would you all consider good pricing for this kit?
Old 03-09-2015, 05:34 PM   #28
Kevin.Cook
Guest
Posts: n/a
It has to be competitive with the other solutions . so 100-140 range?
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 03-11-2015, 04:03 AM   #29
bucko's Avatar
There's always the possibility of a better mousetrap, so your success in selling this product will rely heavily on its ability to work as good as the others, as well as it's price.
I've seen them range from a few dollars (being home made), up to fancy smancy eye candy billit ones in the hundreds range.
If you are simply after a functional catch can, then the price would have to be matching that way of thinking as well.
Old 03-12-2015, 10:20 AM   #30
MADSCOTSMAN's Avatar
Is it mounted somehow or simply free hanging like the JLT. I would consider it ONLY if it is mounted somehow with a bracket of sorts (And BLACK)
MADSCOTSMAN is offline   Reply With Quote
JLT Oil Separator GrabberBlue5.0 2011-2014 Mustang GT 55 12-23-2015 10:35 AM
JLT Oil Separator 08Mustang 2005-2010 V6 Mustang 16 06-30-2012 07:56 AM
JLT oil separator Mustangpower5.0 2011-2014 Mustang GT 13 05-18-2012 10:32 PM
making a oil separator 03GT88 1996-2004 Mustang GT 2 03-17-2012 04:39 PM
Oil separator? tea84 2011-2014 Mustang GT 6 02-10-2012 03:59 PM
11:27 PM
