347 stroker with t5 - Mustang Evolution
Old 03-29-2015, 08:05 PM   #1
Ubnbit's Avatar
347 stroker with t5
I've read this might be a bad idea or the t5 might not be able to handle much. But let's say we were gonna couple the two, is there anything special I need to know? It's a manual t5.
Old 03-30-2015, 10:02 PM   #2
Ubnbit's Avatar
Scotty, where you at?
Old 03-30-2015, 10:21 PM   #3
smurf stang's Avatar
Well if the T5 is in relatively good condition it might last a while till you power shift it a few times or a few launches on DR. It could last a while who really knows but a well build 347 will eventually need a stronger tranny.
2016 VW GTI 2.0 Turbo
Old 03-31-2015, 06:54 AM   #4
Ubnbit's Avatar
Definitely agreed. If it was bolted to an auto before and I'm switching to this manual t5, does anything need swapped?
Old 03-31-2015, 02:17 PM   #5
What computer are you going to use?
You are gonna need.....
T5 w/ bellhousing
Pedal assembly
Clutch Pedal Safety Switch
Transmission Mount
Flywheel
Clutch and Pressure Plate
Clutch Cable
Fire Wall Adjuster
Clutch Fork
Throw Out Bearing
Shifter Boot
Fluid
And various other little things I probably forgot.
Old 03-31-2015, 05:59 PM   #6
Panther140's Avatar
That tranny is rated at around 280 Ft/Lbs of torque.
T-5 behind a 347 stroker? Seems legit, id put some drag radials on it too and make sure to launch it frequently so that it doesn't atrophy like muscles do when u dont use them enough
Panther140 is offline   Reply With Quote
Old 03-31-2015, 07:43 PM   #7
A World Class T5 is rated for 310 actually. It might last a little while. It'll get you running and driving at least and I've seen them hold up surprisingly well if you go relatively easy on them and don't powershift. However... first good launch on race tires or a missed high RPM 3rd gear shift and say bye bye.
The good news is you can have them rebuilt into an A5 for less money than a TKO and it'll shift x1000 better than any other stick shift. People always like to throw around "butter smooth" when talking about shifting. Nothing and I mean NOTHING shifts as smooth as a fresh T5. The A5 is rated at 585ft lbs for the top model btw, but that is conservative.
As far as the swap... a 347 is still a 5.0 externally, the T5 will bolt up just like it would to a stock motor. Now... if you are going from auto to manual then its just a regular conversion, there are a metric assload of threads on how to do this swap.
Or if you are planning on 1/4 mile then just stay auto. Pull a 4R trans with low miles out of a JY, converter, manual valve body or standalone controller and rock down the 1/4 mile never missing a shift and launching harder.
2000 Mustang GT Steeda #0048
Old 03-31-2015, 09:08 PM   #8
Panther140's Avatar
And you can turn th T5 into a dog box, which is cool as ****. I want a dog box transmission in my life. I agree auto is faster for drag racing times, but I wanna go racing like a man, not cruise around like a little girl! lol
Old 04-01-2015, 05:37 AM   #9
Ubnbit's Avatar
Thanks guys. Much appreciated and yeah, this is just to get it off the ground. Not for a permanent situation.
347 Stroker numbers!!! WhiteCobra94 1979-1995 Mustang GT 5 02-16-2012 06:02 PM
96 347 Stroker for My 302 Fox? Qwik Four Six Pictures and Videos 5 11-25-2011 05:37 PM
347 stroker Stang89 1979-1995 Mustang GT 1 10-17-2011 07:20 PM
347 stroker vs. superK24 vs. blown V6....thoughts??? rinfield2004 Pre-2005 V6 Mustang 54 07-21-2010 12:30 AM
347 stroker powerhungry966 1979-1995 Mustang GT 10 10-12-2006 09:52 PM
04:32 PM
