Foxbody rebuild - Mustang Evolution
Old 04-01-2015, 08:23 PM   #1
Foxbody rebuild
I just got a new 5.0. I had a 2.3 turbo that was completely mint. Now how should i have this rebuilt should i drop a crate in it or stroke it?
tony56100 is offline   Reply With Quote
Old 04-10-2015, 10:38 PM   #2
wbrockstar's Avatar
If it was me,I would throw a 331 or 347 stroker in it and a good set of heads.Then you can bolt on other parts as money becomes available. If you're just looking for stock power,get a 302 or 306(302 bored .030 over)then add a few bolt ons.If the car isn't needed in a hurry,you can pull the engine,disassemble it and let a machine shop do the engine prep and reassembly with any new parts that are needed.It will save money vs a crate engine.You can usually get the crank turned,add oversize bearings,use the stock pistons(unless the cylinder walls are too worn.If so,you can bore it and put larger pistons in.You'll be reusing the block internals,except for the pistons(if the cylinders need bored)I prefer buying a short block already assembled by a company such as Forged Piston | Stroker Kits | Crate Engines
Country Home Products ,etc.Then install some Trick Flow or AFR heads and you've got a strong reliable package that you can add to as you go.Decide how much power you want and whether the cars gonna be strictly a daily driver,street and strip or just strip,then build the package that meets those conditions.You can replace every part on these cars so your options are unlimited.
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 04-13-2015, 11:59 AM   #3
Find a cheap 96-98 GT with a blown motor and/or trans first as a donor for your trans/rearend/brakes/axle etc... Get the T45 rebuilt by thet45source.
Then drop a Coyote into it. No donor car=complete pain in the nuts for all the small parts and stuff to support the V8 and you can get a NPI GT parts car for real cheap. Like $500-$1k cheap.
Or... you can take said 96-98 NPI car and swap all the electronics too and then find a cheap PI motor out of a JY and drop it in with a set of cams and have a 300whp ride for pretty cheap.
To answer your original question, if you are going to put a stroker pushrod in it, going 302 based is a waste of time and money, get a 351 and build that. Almost the same overall cost (only marginally more $$$) and way way better results. Plan on $20-$25k for the motor/driveline/fuel etc... for a good shop to do it all correctly. A 408 stroker (or a 347 stroker) done right with the supporting cast is not cheap.
foxbody
rebuild of a recent rebuild Black99Snake SVT Mustang 12 08-20-2011 05:24 PM
Foxbody 10 Holes with a Twist bluemustang Mustang Wheels & Tires 16 04-13-2007 01:51 AM
Great foxbody!! jjbg86 Mustangs for Sale and Wanted 7 11-10-2006 06:08 AM
donor rebuild vs current engine rebuild cash05_mustang Pre-2005 V6 Mustang 2 07-01-2006 01:09 PM
05:43 PM
