Driving manual mode for automatic - Mustang Evolution
Old 06-17-2015, 11:33 PM   #1
I have a 2014 auto and I was wondering if it's bad for the transmission of I drive it in sport mode(manual shifting) all the time?
Sent from my HTC One M9 using Mustang Evolution mobile app
mark09 is offline   Reply With Quote
Old 06-18-2015, 04:19 AM   #2
Noodles76's Avatar
It's there to use. You should be fine. But if that's what you're doing why didn't you just buy a manual?
Rollin' in my 5.0
Noodles76 is offline   Reply With Quote
Old 06-18-2015, 07:38 AM   #3
Senior Member
rlma84's Avatar
I drive mine that way every day... nothing is broken yet
rlma84 is offline   Reply With Quote
Old 06-18-2015, 07:41 AM   #4
Look at this way...
If it was bad on the trans why would they have it as an option to manually shift it?
Adventure till you drop.
Old 06-18-2015, 10:15 AM   #5
Rollin' in my 5.0
i live in LA so theres insane traffic so sometimes its not convinient
Old 06-18-2015, 11:07 AM   #6
Shouldn't be any different than the auto shifting itself. The only difference are shift points, so you may cause extra drivetrain wear over normal use by running up the RPMs all the time and lose gas mileage. Overall likely to be negligible.
bmatticus is offline   Reply With Quote
Old 06-18-2015, 12:00 PM   #7
Noodles76's Avatar
Understandable.
Rollin' in my 5.0
Old 06-18-2015, 12:54 PM   #8
Better wear
Sport mode hooks up better and shifts more firmly than drive mode or than a manual transmission.
You don't have to shift manually in sport mode, but you can if you want to...personally I like sport mode for hole shots and drive mode for commuting.
I have not heard any chatter about wear issues in sport mode, if anything , the quicker shift will extend the clutch pack wear...it doesn't as much.
Kelleniz is offline   Reply With Quote
Old 06-18-2015, 12:55 PM   #9
I have not heard any chatter about wear issues in sport mode, if anything , the quicker shift will extend the clutch pack wear...it doesn't slip as much.
Old 06-18-2015, 01:32 PM   #10
I don;t think it hurts the car---But---
You will probably get terrible miles per gallon.
Old 06-18-2015, 01:53 PM   #11
also, i like to do canyon runs sometimes, so when i manually down shift and it revs to 3-4k rpm through a turn is that alright? or does it hurt the transmission?
sorry noob here lol
---------- Post added at 07:53 PM ---------- Previous post was at 07:53 PM ----------
smiles PG > MPG
haha
Old 06-18-2015, 02:57 PM   #12
Vinny's Avatar
smiles PG > MPG
haha
I doubt any harm will come, but I am guessing the engine braking will help with corner braking.
Vinny is offline   Reply With Quote
Old 06-20-2015, 10:27 AM   #13
Nothing about shifting manually is going to hurt the auto.
Old 07-16-2015, 11:56 PM   #14
Odai1437's Avatar
Yeah i also have a 2014 auto and im pretty sure that you wont harm the car because the sport mode will not let you shift if you will cause any damage
Odai1437 is offline   Reply With Quote
Old 07-17-2015, 01:46 PM   #15
MADSCOTSMAN's Avatar
"S" - Selectshift mode is like the older mustangs when you took it out of overdrive. D (Like Overdrive) for highway use where better (LOL) gas mileage is desired, S for local and spirited drives. S takes away 6th gear and changes shift points and engine braking.
MADSCOTSMAN is offline   Reply With Quote
Sport mode automatic problem roushMarlon831 2011-2014 V6 Mustang 7 12-22-2014 01:27 AM
Manual mode use with Automatic tran 007_13tang 2011-2014 V6 Mustang 4 04-19-2014 09:36 AM
Automatic Driving Question ElSaborAsiatico General Mustang Discussion 38 02-11-2014 07:11 PM
Driving in Sport Mode? gilbert2112 2011-2014 V6 Mustang 4 12-06-2013 11:48 PM
2013 Hooked on Driving/Camp Steeda Driving Event tj@steeda General Mustang Discussion 3 04-24-2013 06:31 AM
09:31 AM
