suspension upgrade - Mustang Evolution
Old 06-24-2015, 09:56 PM   #1
falisi_5.0's Avatar
suspension upgrade
I'm about to throw in some ford racing springs, panhard bar and some lower control arms... a few shops want 300 bucks for install.. i have all the tools needed to do it and don't mind putting in the time. Any suggestions on what to do??
falisi_5.0 is offline   Reply With Quote
Old 06-24-2015, 10:15 PM   #2
suspension upgrade
What are your plans/goals for your car?
Adventure till you drop.
Recon is online now   Reply With Quote
Old 06-24-2015, 10:24 PM   #3
falisi_5.0's Avatar
thats a long list!!
for now quick upgrade on the handling so it can handle more power (new headers, x pipe, boss mani)
Old 06-24-2015, 10:26 PM   #4
Black8thElement's Avatar
Sounds like you should do it yourself. Call up somebody to help you I guess
Black 2008 GT "to punish and enslave" edition
Black8thElement is offline   Reply With Quote
Old 06-24-2015, 10:26 PM   #5
oxford5pointoh's Avatar
I would put it on myself if I were you and save or spend that 300 on more mods
IG @Oxford5pointoh
Old 06-24-2015, 10:32 PM   #6
falisi_5.0's Avatar
thats what I'm leaning to ^^^
Old 06-24-2015, 10:33 PM   #7
It's an EASY job. Especially if you have the tools, a place to do it, the patience and an afternoon
IG @Oxford5pointoh
Old 06-24-2015, 10:40 PM   #8
falisi_5.0's Avatar
the only thing I'm worried about is the panhard bar install...
Old 06-24-2015, 10:41 PM   #9
Really? Why is that? That's probably the easiest thing to install in your list.
IG @Oxford5pointoh
Old 06-24-2015, 10:53 PM   #10
falisi_5.0's Avatar
thats good to hear lol i hope so.. i was going by reviews from other people thats all.
Old 06-24-2015, 11:02 PM   #11
Dude, 2 bolts adjust new one to the same length as the stock one to start, install and torque to 130ft lbs. put car on the ground, tape some string with a washer hanging from it above the wheel from the quarter panel. Measure both sides in the same place, split the difference and adjust. Easy peazy
IG @Oxford5pointoh
Old 06-24-2015, 11:09 PM   #12
falisi_5.0's Avatar
you convinced me to try it out.. im sure ill be asking you more when i get into it all!!
Old 06-25-2015, 05:08 AM   #13
👍🏻👍🏻 awesome
IG @Oxford5pointoh
Old 06-25-2015, 09:53 AM   #14
doyouevenforum
Guest
Posts: n/a
I always work on my own cars from putting on turbo kits, pulling trannys to changing spark plugs. Save money, learn alot and you know it's done correctly.
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
Old 06-25-2015, 03:13 PM   #15
Mean14's Avatar
lol panhard bar is the easiest out of the mods you have listed. I would do it myself and save the $300. I just installed everything you have listed plus more and it was fairly easy. The only thing that took a bit longer was the springs. Just take your time and you'll get it done no problem. When changing the lower control arms, make sure you do them one at a time. Also, when installing the panhard bar, I found it easiest to loosen the panhard bar brace on the passenger side in order to give you a little more wiggle room for installation. Remember to tighten it back up though after reinstalling.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 06-25-2015, 03:21 PM   #16
falisi_5.0's Avatar
ok cool.. i also heard i need a wheel alignment after I'm done.. any truth to that??
Old 06-25-2015, 03:39 PM   #17
Mean14's Avatar
Depends how significant the drop is. The eibach sportlines dropped mine 1.3" up front and 1.7" in rear so I will def need one. I've heard people who have dropped it less than that and didn't need an alignment. Either way, you're going to want to wait a couple weeks for the springs to settle if you do decide to get an alignment. I would get it done just for the peace of mind.
Old 06-27-2015, 10:44 AM   #18
jellyroll's Avatar
Get an alignment. Also Firestone offers a lifetime alignment for under 170.00 usd. I dropped only an inch and had to get it aligned. Good luck.
2008 GT/CS - {SLP Loudmouth Axle Back Exhaust- SR Strut Tower Brace - Raxiom Sequential Tail Light Kit - C&L Street CAI - Bama Tune - FRPP Lowering Springs - FRPP Rear Sway Bar - FRPP Struts & Shocks - BMR TCA032 LCAs}
jellyroll is offline   Reply With Quote
Old 07-14-2015, 12:12 PM   #19
falisi_5.0's Avatar
i lost 2 ball bearings from the top of the strut mount.. I know it should be full but whats yalls opinion on missing just 2....
Old 07-14-2015, 12:16 PM   #20
The_Chech's Avatar
Your fine. I mean hell military specs for some thing of that nature is like missing half the bearings before it's considered possible for replacement. But if your only missing two you have nothing to worry about. Hope this helps
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 07-14-2015, 12:18 PM   #21
falisi_5.0's Avatar
sounds good to me thanks
2011 Mustang GT. Suspension Upgrade. TimeMachine 2011-2014 Mustang GT 12 07-06-2012 02:42 AM
Suspension Upgrade BIGRED3361 2005-2010 Mustang GT 17 02-20-2010 03:36 PM
suspension upgrade for convertible nekronos Pre-2005 V6 Mustang 6 07-13-2008 01:52 PM
Brakes and Suspension Upgrade McGrail482 Pre-2005 V6 Mustang 116 05-09-2005 08:27 PM
Suspension upgrade... 98GreenStallion Pre-2005 V6 Mustang 37 11-21-2003 10:57 AM
06:54 AM
