What the heck is e 85 and why does everyone use it? - Mustang Evolution
Old 08-14-2015, 02:30 PM   #1
PatrioticAlex's Avatar
Ive been noticing a lot of high powered mustang are using e 85. Why e 85 and not 93 octane? Where do you even buy e 85?
Sent from my SM-G900P using Mustang Evolution mobile app
Texan Mustang
PatrioticAlex is offline   Reply With Quote
Old 08-14-2015, 02:43 PM   #2
natestang07's Avatar
E 85 is equivalent to 100 octane or something silly
Old 08-14-2015, 02:53 PM   #3
What gas do you use nate?
Texan Mustang
Old 08-14-2015, 02:58 PM   #4
92
Old 08-14-2015, 03:14 PM   #5
alterego's Avatar
Can't find e85 here. How is it priced compared to 87?
alterego is offline   Reply With Quote
Old 08-14-2015, 03:17 PM   #6
I head its cheaper but the mpg is a lot worse so basically it will cost more. Im texas gas is cheap, 93 oct is like 2.70 and 2.30 for 87 and going back down
Texas Rider
Texan Mustang
Old 08-14-2015, 03:20 PM   #7
alterego's Avatar
I bought e85 down south just because, don't remember the price comparison but it did noticeably burn quicker.
Old 08-14-2015, 03:20 PM   #8
E85 is a subsidized fuel so it is a little less expensive than premium pump gasoline.
The performance advantage to using it, is much like using straight alcohol. It has an excellent cooling effect inside of the combustion chambers due to the fact that you are using a considerably larger amount of the E85 to do the same amount of work that would be required if the engine was running on gasoline. This allows you to increase the compression ratio on a Normally Aspirated engine or, to increase the boost on a Forced Induction engine, and run a more aggressive ignition timing curve. With none of the negative effects that you would see if using pump gasoline... With the exception of increased fuel consumption.
It's a neat fuel for certain applications! Although, it would be much more expensive if it weren't being government subsidized.
It's basically a "poor man's" racing fuel. Before E85, aviation fuel was the next best alternative to racing fuel. But it also has a little lead in it.
I live in a place where the nearest E85 pump is more than 60 miles away. It would be impossible to run my Mustang, on E85, on the street, due to the availability.
Old 08-14-2015, 03:23 PM   #9
alterego's Avatar
I can get leaded 110 race fuel here $7 a gallon. I do add a lil when I'm feeling frisky. Love the way it smells burning. But it would be cool to see e85 here as well.
Old 08-14-2015, 03:25 PM   #10
alterego's Avatar
A short answer to the question. E85 is 85% ethanol 15% gasoline.
Old 08-14-2015, 03:33 PM   #11
Thank you a lot for that well written explanation. Do you think it is worth using e 85 on a daily basis if i have one located nearby? How much does it help anyway?
Texas Rider
Texan Mustang
Old 08-14-2015, 03:34 PM   #12
You need larger injectors and a tune to safely run E85 in your car, so I wouldn't make a habit of doing that.
Old 08-14-2015, 03:37 PM   #13
Rapinator126's Avatar
E85 is 105 octane
And cost ranges from $1.80- $2.00 a gallon for me here.
Rapinator126 is online now   Reply With Quote
Old 08-14-2015, 03:41 PM   #14
Which ones you recommend for e 85? Like 80lb/hr?
Texas Rider
Texan Mustang
Old 08-14-2015, 03:42 PM   #15
Texas Rider
Only if you want to achieve the maximum performance from your engine.
There can be considerable gains even using it in a stock engine, with the right tune. And even bigger gains on a built engine!
It will end up costing you more in fuel because you will be burning much more E85.
It really depends on how aggressively you "daily drive" the car I guess.
Old 08-14-2015, 03:45 PM   #16
Texas Rider
Rapiinator knows more about it than I do but, I think that you need 47# on these engines.
Old 08-14-2015, 03:45 PM   #17
hctr154's Avatar
Texas Rider
Ford Racing 47lb injectors are what you need. They are direct fit and pretty easy to swap them out.
You will also need a e85 specific tune as well.
Just realized this is not on 2011-2014 Mustang forum....not sure about the 3 valve engine.
Sent from my SM-T217S using Mustang Evolution mobile app
2013 GT A6
hctr154 is offline   Reply With Quote
Old 08-14-2015, 03:46 PM   #18
Okay. I plan using 93 octane for now.
Texas Rider
Texan Mustang
Old 08-14-2015, 03:48 PM   #19
The Ford racing 80lb injectors are **** on the coyotes.
If you plan on staying NA then the 47lbs will work.
Expect a drop in gas mileage and depending on how aggressive you get with timing will determine what kind of power you will make.
Old 08-14-2015, 03:52 PM   #20
Pretty sure OP has a coyote though. May be wrong
Old 08-15-2015, 10:48 AM   #21
dwbrand's Avatar
He's got an 06 3V... because every time I post a reply to him, it's along the lines of "well on my dad's 06..." haha
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 08-15-2015, 10:48 AM   #22
E85
I thought it was Ethanol--85% gasoline, 15% Ethanol, which is made from corn, which is more expensive to make and a gallon only takes you about 2/3 of what a gallon of regular gas does. At least this is what I understand the situation to be. I used to see it on the pumps down here all the time. Right now I use 87-91 on my '15 GT with PP. Getting a little over 17.5 MPG city driving although, city for me here also includes quite a bit of freeway driving.
reflections is offline   Reply With Quote
Old 08-15-2015, 10:51 AM   #23
dwbrand's Avatar
No it's 85% ethanol
Doesn't ethanol supposedly burn cleaner? Years ago (like 2002-03) I wrote a term paper arguing in favor of ethanol and funny how now I'm not so much in favor of it anymore.
1968 Mercury Cougar
Old 08-15-2015, 10:53 AM   #24
Forgot to mention that it may be used more as a winter blend, but as I recall, Ethanol was in all the octane levels due to government meddling.
Old 08-15-2015, 12:17 PM   #25
Fabman's Avatar
Built 3 Valve here...
e85 kicks azz, why should I pay 16.00/gal for 106 octane racing fuel when I can get e85 for a couple bucks a gallon and run 20 psi on the street everyday?
Yes, it uses a little more fuel, about 20% more, but at 3 bucks a gallon, who cares? Now I track my car a lot but I also like to do cruises and cars shows so e85 means I can run this monster on the street and then take it to the track and change nothing but the tires. Same pulleys, same tune.
Now it's not available everywhere, and for a true daily it's probably not worth it, but for me, it's awesome.
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 08-15-2015, 12:44 PM   #26
I love the stuff also. But I love my c16 more
Old 08-15-2015, 12:47 PM   #27
Fabman's Avatar
c16 is 16.75/gallon here...I couldn't afford to drive my car.
Tuned by AED
Old 08-15-2015, 12:52 PM   #28
Lol me either if it ran off of it all the time.
The car runs off e85 the c16 is just in the dedicated system for the bottle. So 5 gallons max.
I got lucky though. The guy we rent our yard from for our shop. He is friends with the head sales man for VP racing. I get it for $10 a gallon
Old 08-15-2015, 12:54 PM   #29
Fabman's Avatar
3.00/gal vs. 10.00/gal
I'll stay with e85.
Tuned by AED
Old 08-15-2015, 12:55 PM   #30
$2.00 a gallon for e85 right now down here. It's usually $1.80 but went up for the summer
The only reason I run c16 is I can run around on 1 tune, vs swapping back and forth, and be safe with the 300 hit.
Old 08-15-2015, 12:56 PM   #31
Fabman's Avatar
And don't forget....it's a sustainable fuel source.
Tuned by AED
Old 08-15-2015, 12:59 PM   #32
Fabman's Avatar
The only thing I know about nitrous is that it blows a lot of motors up.
20 psi and high compression on the street....e85 works for me.
Tuned by AED
Old 08-15-2015, 01:02 PM   #33
1 motor so far and 1 set of valves.
Good odds
Your car is set up perfect for track/street
Old 08-15-2015, 01:05 PM   #34
Fabman's Avatar
Good odds
Thanks.
I know nitrous makes serious hp.......seen it first hand. Just scares the crap out of me. This motor was not cheap.
Tuned by AED
Old 08-15-2015, 01:08 PM   #35
We will see what e85 and high boost does on my old 03 cobra. It goes in for the final tune next week.
It has a 2.3 Whipple and 22psi, 10.1 compression,
Ported heads
Stage 3 blower cams
Longtubes
Then all your other "boltons"
Pic I got last time I was at uncles b4 it went back in the car
What Oil and filter does everyone use?? r3ap3r911 2011-2014 Mustang GT 16 09-27-2014 06:33 PM
Why the heck did the factory crush the mid pipe on driver side??? GT 1 2011-2014 V6 Mustang 28 07-13-2014 03:13 PM
WHY WHY WHY??? Krustey Monkey General Mustang Discussion 24 08-08-2012 07:22 AM
how the heck does a turbo work? Zim 1979-1995 Mustang GT 12 03-06-2004 06:34 PM
Why does everyone use AIM? Ken The Bar 13 05-08-2003 09:18 PM
02:57 PM
