First mods - Mustang Evolution
Old 08-16-2015, 01:45 AM   #1
Tplanck's Avatar
First mods
Got a 97 cobra convertible a month back. Wondering what some of my first mods should be. It's all stock now. I know I want to put 4.10s on it. What else should I do. Not wanting to do anything to expensive right now. Keeping it under 1500$ all together for now.
1997 Cobra
Tplanck is offline   Reply With Quote
Old 08-16-2015, 10:58 AM   #2
hctr154's Avatar
Sub-frame connectors....
2013 GT A6
hctr154 is offline   Reply With Quote
Old 08-16-2015, 06:25 PM   #3
For $1500, a gear install and the gears themselves is going to run in the $500-$600. Mid pipe will be $150 for catless and $300 for catted and a good catback is $500. Then a tuner and you are at $1500. This is where I would start. Oh and a shifter. You can get a used Tri-Ax for $100 in forum classifieds if you look.
Old 08-16-2015, 06:38 PM   #4
Gears
Subframe connectors
Tuner
Old 10-10-2015, 11:48 AM   #5
Tplanck's Avatar
This guy wants to trade me a 94 gt body with a 351 roller in it. Says his wife wants a convertible. He says that it makes 400+ hp. I'm not sure if that's true or not. I don't know very much about that motor. Here is the list of mods he says he has :
Mustang GT with a built fuel injected 351 roller motor. 6" Cowl hood 303 roller cam-hits a nice lick Edelbrock Performer RPM upper and lower intakes Trick Flow elbow BBK cold air intake BBK 70mm throttle body 24 lb injectors MSD distributor and coil Trick Flow valve covers Roller rockers Canton high capacity race oil pan and high volume oil pump B&M short throw shifter BBK long tubes into off-road x pipe Magnaflow exhaust-sounds amazing with dumps at rear axle Aluminum driveshaft 3:73 gears Steel motor mounts Welded in frame connectors FR500s 18x9 fronts 18x10 rears with very good tires A/c delete, but could be added back on Hot heat Factory Mach radio works great Nice grey leather with normal wear It only has 115k miles. YES speedo and odometer both works. Mileage is actually less due to rear gears causing it to run faster. actual Mileage is closer to 100. This car was built right, no junk here. It runs VERY STRONG!
Idk if that will make that much power. Let me know what you think!
1997 Cobra
Old 10-11-2015, 12:19 PM   #6
Mile high JDF's Avatar
I'd pass. If he can't take the time to properly calibrate his speedometer ythen what else did he skimp out on? Why does he want to trade down to a car with "less" power? I doubt a cam/intake 351 makes 400hp, but I'm no expert. I tend to be very skeptical of some e wanting to trade a highly modified car for a mostly stock car.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 10-11-2015, 12:22 PM   #7
Tplanck's Avatar
That's true. He said he sold the car last night anyways. So I will just continue to do little things to my car here and there I have a header leak so I'm going to go ahead and do a full exhaust. Bbk long tubes with off road x. And some super 10 mufflers.
1997 Cobra
Old 10-12-2015, 03:45 PM   #8
Tplanck's Avatar
Hey guys I know that they say you shouldn't put 10 inch wide tires in the front, but on AM they have a set of rims on sale that I like and they only have 18x10s. And I looked around everywhere for 18x9s in the front and no one has them unless you want to buy a set of 4. The rims are on close out and thus AM doesn't even have 18x9. Let me know if you think I can pull it off. Thanks. Click image for larger version
Name:	ImageUploadedByMustang Evolution1444686338.693141.jpg
1997 Cobra
Old 10-16-2015, 08:54 AM   #9
Not going to fit without major modifications.
Old 10-17-2015, 06:36 AM   #10
Tplanck's Avatar
Just tried a IMRC cleaning.. Well when we tried to start the car back up its was smoking a little bit and the injectors were leaking a little gas.. Any ideas of what to do next? I was told to get some new O rings for the injectors. But as for the smoke I have no clue.
1997 Cobra
Old 10-17-2015, 01:08 PM   #11
Tplanck's Avatar
Got it all worked out. Didn't have the injectors all the way in.
1997 Cobra
Old 10-19-2015, 08:16 AM   #12
Yeah things don't usually work out when you just have the tip in...
First new car, first mustang, first ford Sportsman New Member Introductions & Greetings 21 11-20-2015 02:59 PM
First Mustang...First Ford...First Car This Awesome! Debster New Member Introductions & Greetings 13 04-28-2013 12:30 PM
MODS MODS MODS! S197Miller 2005-2010 Mustang GT 28 02-10-2013 01:36 PM
Mods.....Mods.....Mods.... Srohda 2011-2014 Mustang GT 8 06-01-2012 12:50 PM
First Post, First Car, First Mustangg EdgeLivin New Member Introductions & Greetings 14 04-03-2012 12:49 PM
10:10 AM
