Eaton on 2v - Mustang Evolution
Old 08-30-2015, 04:53 PM   #1
SkylerTallman_'s Avatar
Eaton on 2v
So this has probably been asked before but I have $2,000 to spend right now and was wanting a root supercharger. I don't have enough for the 2v adapter kit they sell. I was wondering if I could look around on wrecked cars if I could take the intake and heads maybe of a 4v and bolt a eaton on? And then just have to buy injectors, fuel pump, and maybe relocate something for the belt and all. Sorry if any of that sounded ignorant, not the most educated this topic.
SkylerTallman_ is offline   Reply With Quote
Old 08-30-2015, 05:49 PM   #2
natestang07's Avatar
2 grand won't get you forced induction reliably. I could be wrong though
Old 08-30-2015, 05:56 PM   #3
Rapinator126's Avatar
Don't waste money doing a eaton
🍼and 🌽 fed coyote.
Old 09-08-2015, 12:12 PM   #4
You won't get a new kit on your car for under $5k. Piecing together a used one... $2k might get you all the pieces as far as the blower or a used S trim or something. But you'll still need to do fuel and tune which is going to run another $1k or so most likely. There are always misc parts as well.
Old 09-09-2015, 09:25 AM   #5
LaserRed99's Avatar
I would recommend doing a centrifugal. Cheaper, shouldn't have to worry about heat soak. They call 'em Heatons for a reason. You won't get the same power down low in the band with a centri, but (and somebody correct me if I'm wrong) you should get better power on the same amount of boost up high because the air is cooler.
'03 Mach 1 5spd
Fully forged Manley rods/pistons, Cobra crank, ARP hardware, 8.5:1, Procharger P1SC w/ intercooler, AFM power pipe, 60# injectors, 03/04 Cobra tank with dual fuel pumps, Kenne Bell Boost-a-Pump, O/R X pipe and Flowmasters, Exedy stage 3 clutch, Steeda Tri-Ax, Front and rear upper + lower control arms, Ford Racing springs, Bob Monks tune 448 rwhp @ 9 PSI
LaserRed99 is offline   Reply With Quote
Old 09-09-2015, 10:36 AM   #6
Centri vs PD blower argument is done to death. Both have their advantages and disadvantages. Ppl bash on the Eaton... well because the name "HEATON" is well deserved. The M112 and the TT kit is ok for a street car but will still get soaked real fast. The actual big plus to the TT kit is its the only way to get a TVS or a Whipple onto a 2V since the Kenne Bell kit is proprietary.
Old 09-26-2015, 01:27 AM   #7
Unless you plan on using that $2k to finance a select choice of superchargers on brenspeed.com, you're not likely to find anything that cheap. Well, my statement on applies to newer mustangs.
Sent from my SM-N910V using Mustang Evolution mobile app
motu360 is offline   Reply With Quote
FS: Stock 03 Cobra Eaton Supercharger, TB, Plenum - $500 shipped PureVenom Mustang Parts for Sale and Wanted 18 02-07-2007 12:32 PM
2003-2004 Eaton Supercharger jimmy_beaner Mustang Parts for Sale and Wanted 2 03-02-2006 02:39 PM
eaton m90 question VindictiveStang Pre-2005 V6 Mustang 8 09-17-2005 11:37 PM
Eaton 7.5 Posi? timpryor Pre-2005 V6 Mustang 4 04-28-2005 05:58 PM
eaton m90 question greenpony02 Pre-2005 V6 Mustang 10 01-23-2005 12:07 PM
04:37 PM
