How Much of a Gain? - Mustang Evolution
Old 09-09-2015, 04:47 PM   #1
NewMtang's Avatar
Question How Much of a Gain?
I have read many posts that talk about adding a Throttle Body to a V6.....Most say you won't have enough of a gain or no gains.
How about adding the following?
1) 73 mm Throttle Body
2) Bigger Fuel Injectors
3) Milled Heads
4) Polish and Port
Old 09-09-2015, 04:54 PM   #2
LaserRed99's Avatar
Not much. Especially without a tune. It'll be good for supporting other mods in the future.
'03 Mach 1 5spd
Fully forged Manley rods/pistons, Cobra crank, ARP hardware, 8.5:1, Procharger P1SC w/ intercooler, AFM power pipe, 60# injectors, 03/04 Cobra tank with dual fuel pumps, Kenne Bell Boost-a-Pump, O/R X pipe and Flowmasters, Exedy stage 3 clutch, Steeda Tri-Ax, Front and rear upper + lower control arms, Ford Racing springs, Bob Monks tune 448 rwhp @ 9 PSI
LaserRed99 is offline   Reply With Quote
Old 09-09-2015, 05:45 PM   #3
natestang07's Avatar
My assumption would be the throttle body is a waste and injectors are a waste without forced induction
Old 09-09-2015, 08:43 PM   #4
NewMtang's Avatar
I have a tune.
Old 09-09-2015, 08:49 PM   #5
LaserRed99's Avatar
Originally Posted by NewMtang View Post
I have a tune.
Even so, it's probably only good for a few HP and only at the higher RPMs. Adding full (as in headers too) exhaust and a good CAI will work together with that for a decent gain. How much of a gain vs without a TB upgrade, I'm not really sure.
Also natestang07 is right, the bigger injectors will do absolutely nothing unless you are going to have FI. The throttle body will also help with FI.
'03 Mach 1 5spd
How much HP gain with LT headers and x-pipes? USMCSS 1996-2004 Mustang GT 9 01-05-2007 01:44 PM
How Much Of A Gain Fellas JAYS MUSTANG Pre-2005 V6 Mustang 23 11-06-2006 07:18 AM
how much gain from sct flasher? tedness Pre-2005 V6 Mustang 22 08-02-2005 07:11 AM
How much HP will gain with custom superchip 99'sleeper Pre-2005 V6 Mustang 15 02-12-2005 11:54 AM
VENON400 Performance Module..How much HP/Torque gain REALLY? yellowgt6 Pre-2005 V6 Mustang 8 10-08-2003 10:29 PM
» Members Mustangs
Trudy
Torino
LOU'CY
boink
Add your Mustang
08:55 PM
