Car won't start. Lost at this point - Mustang Evolution
Old 09-22-2015, 11:45 AM   #1
SkylerTallman_'s Avatar
Alright, so I took my car and I didn't notice I was rubbing my front left wiring harness and it destroyed it and the car wouldn't crank. So I went and bought a new wiring harness and installed it and the car still doesn't. The fuel pump turns on, all electrical stuff turns on, but the car will not crank or anything. Any help is appreciated, I'm totally lost at what it could be now.
SkylerTallman_ is offline   Reply With Quote
Old 09-22-2015, 01:15 PM   #2
MORE INFO WOULD HELP
ALLYDRIVER1 is offline   Reply With Quote
Old 09-22-2015, 01:19 PM   #3
Im getting relay from the fuse box and clicking but no turn over
Old 09-22-2015, 03:30 PM   #4
Robostang's Avatar
Have you tried charging the battery? I'm not sure what you did to the harness but it could have caused a drain on the battery.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 09-22-2015, 07:55 PM   #5
[QUOTE=Robostang;2294961]Have you tried charging the battery? I'm not sure what you did to the harness but it could have caused a drain on the battery.[/QUOTe
beat me to that,sometime the most simple things cause most headaches
Old 09-23-2015, 07:08 PM   #6
When I went through the same thing couple of weeks ago, I kept one of those battery jumper kits with me to eliminate any battery doubts in my mind. Pulled and tested each fuse in fuse box. Cleaned up or replaced all battery connections, added a ground wire, cleaned connections on starter too.
Old 09-25-2015, 11:48 AM   #7
Panther140's Avatar
All of your electrical stuff is working as it should but it still wont crank?
That means engine is either locked up, or the starter gear/flywheel is missing all of the teeth.
Panther140 is offline   Reply With Quote
Old 10-02-2015, 11:16 PM   #8
tym_v6's Avatar
Bad starter or starter solenoid?
Can you pull the starter and bench test it to make sure it works?
Strut tower brace 2 point vs 4 point? king_13 2011-2014 V6 Mustang 69 05-21-2015 10:54 AM
Car won't start? Dude87 1996-2004 Mustang GT 16 10-13-2008 11:32 AM
Car Won't Start joseandmarilyn 1979-1995 Mustang GT 11 02-18-2008 12:22 PM
Car won't start Torchred02 1996-2004 Mustang GT 9 02-18-2007 01:17 PM
Car won't start V6STANG007 Pre-2005 V6 Mustang 31 12-07-2004 06:07 PM
01:59 AM
