Battery tender - Mustang Evolution
Old 10-09-2015, 03:36 PM   #1
dffej51's Avatar
Battery tender
Because my '07 GT Mustang sits for weeks at a time between use (it is heavily modded and not a daily driver) I keep a battery tender/maintainer hooked up when not is use. I have done this with all my Mustangs past and present and have always hooked both the positive and negative clips directly to the posts on the battery. However, after finally reading the directions on use of battery tenders it appears that it is recommended to attach the negative clip (ground) to a part of the chassis instead instead of the negative post. I have never had any issues with attaching both clips to the battery posts. Does anyone know of any damage being done to the battery by dong so?
dffej51 is offline   Reply With Quote
Old 10-09-2015, 04:01 PM   #2
Diehard's Avatar
It has always been my understanding that what is recommended is a safety measure. That is, in case there is any leaky fumes around the battery, the point of spark would be away from the battery. And of course the negative should be the last connection made, for that reason.
Old 10-09-2015, 04:13 PM   #3
It sounds like the same instructions for safely connecting jumper cables to a battery.
Most people don't realize that they are driving around with a 30 pound hydrogen bomb underneath their hood.
They recommend that you connect the positive lead first, and then connect the ground to a metal part that the battery is grounded to, as far away from the battery as is practical. This is in case there is any hydrogen gas venting from the battery, which could be ignited by the small spark created when the ground is connected.
And car batteries do explode! I have seen it happen twice!
There is no danger to the battery, other than a risk of explosion. You would have to connect the ground directly to the battery if it is not installed in the car, correct?
It is just good practice to keep the spark as far away from the battery as you can, in case any hydrogen gas is present.
Battery Tender Spiney General Mustang Discussion 1 11-22-2011 08:29 AM
Running 2 Gauge from battery to trunk = not fun Brent Mustang Audio & Video 4 05-04-2004 07:00 PM
Optima Battery McGrail482 Pre-2005 V6 Mustang 6 04-25-2004 03:08 PM
Battery Light fordfan1184 Pre-2005 V6 Mustang 2 08-27-2003 03:16 PM
07:30 PM
