Question about BAMA tune / OBDII monitoring - Mustang Evolution
Old 11-28-2015, 08:47 AM   #1
dorkdog's Avatar
Hi
I finally pulled the trigger and bought a tune for my 2010 auto V6 premium vert. which has 46K and is bone stock. I'll most likely end up running 93 race tune most of the time; my commute allows for some twisties and spirited driving thru rural 45-50 MPH backroads.
I also run a Samsung tablet with gauges to measure OBDII parameters - I currently monitor my intake, water, and tranny temps along with voltage, MPG.
I understand that these tunes are somewhat generic, and I want to make sure that the tune received isn't putting any undue stress on any of the car's components due to some slight difference between my car and the norm.
What OBD parameters should I start monitoring now, in stock configuration, so I can assess any influence the tune has by comparison afterwards? I know, for example, that it's possible to 'over-lean' the engine - how can I use the data available through the OBDII port to keep an eye out?
Thanks!
dorkdog is offline   Reply With Quote
Old 11-30-2015, 01:36 PM   #2
hitmeagain's Avatar
I would look at knock, timing, air fuel ratio. Stuff like that just to start in sure there's lots more
hitmeagain is offline   Reply With Quote
Tire pressure monitoring system :/ RomanG 2011-2014 V6 Mustang 12 10-01-2014 05:04 AM
Understanding SCT monitoring help Stephen06v6 2005-2010 V6 Mustang 0 07-30-2013 12:07 PM
bama race tune > bama hybrid tune 13 stang22 2011-2014 V6 Mustang 11 04-16-2013 05:26 PM
How does the SCT data logging and monitoring work rebeltx 2011-2014 V6 Mustang 3 01-30-2013 08:29 AM
01 gt diablo tuner monitoring lowering kit 1996-2004 Mustang GT 0 06-20-2008 07:59 AM
01:56 PM
