Lowered Mustang Problem - Mustang Evolution
Old 12-11-2015, 07:52 PM   #1
phobik's Avatar
I just recently lowered my 2010 Mustang GT myself with the Eibach Sportline Springs as well as the J&M Adjustable Camber Plates. The install went fine with a friends help and heard no noise at all once I was done. A couple of days after I went to a local shop to have my alignment done and a day after I started hearing a "clunk" noise on the driver side. Every time I hit a little bump or big bump at any speed I would hear it and then I don't. It happens only when I hit a bump. I went back to my alignment shop and they checked the vehicle and made sure everything was tight and in spec. The issue was still there which is when I went to another shop to have them inspect my suspension. They told me everything was normal and they made sure everything was tighten up good. I am now still having the same issue. I called American Muscle and they were not able to help me. I am not sure what it can be. I still have the stock Shocks at 58K miles but seems odd to me that it is only the driver side. I am not sure if maybe something is defective or not. At this point I am not sure what to do and i'm helping someone here can help me out.
phobik is offline   Reply With Quote
Old 12-11-2015, 09:23 PM   #2
Noise on ft or rear? Exh. Hitting rear diff?
ALLYDRIVER1 is offline   Reply With Quote
Old 12-12-2015, 12:14 AM   #3
oxford5pointoh's Avatar
My guess is the strut mount is bad on that side.
Old 12-12-2015, 04:55 AM   #4
Robostang's Avatar
That or sway bar end link would be my guess.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 12-12-2015, 05:26 AM   #5
phobik's Avatar
No the noise that I am hearing is on the front driver side. I was able to push up on my driver side fender and was able to hear the noise. I am not sure what it can as its only that one side.
Old 12-12-2015, 05:36 AM   #6
Robostang's Avatar
Did you use an impact wrench to tighten the nut in the top of the strut? If not it could be loose.
Old 12-12-2015, 11:06 AM   #7
I am willing to bet it's just the strut mount is bad. These things are one time use, sometimes you can get away with re using but often times they fall apart on ya. So what you are actually hearing is not the strut being loose but the part it is bolted too where all the ball bearings are has gone bad (probably missing some of the ball bearings)
If I were you I would get some GT500 strut mounts. They should be a direct fit on your car. These will eliminate that noise.
Old 12-14-2015, 11:41 AM   #8
phobik's Avatar
I was looking into the Koni Strut Mounts because I believe they are for lowered vehicles and I did drop mine pretty low. I do believe it can be the struts but for some reason I believe it could be the bearing as well. Do these come with the struts or is this something I buy separate? I won't be able to buy struts until after Christmas
Old 12-14-2015, 06:24 PM   #9
Robostang's Avatar
The strut mounts contain the bearings. They sit between the strut and the strut tower.
Old 03-14-2017, 01:35 PM   #10
phobik's Avatar
It actually was the sway bar link and it keeps getting loose that I have to tighten it every once in a while. Is it possible it's gone bad?
Old 03-14-2017, 01:39 PM   #11
jkeaton's Avatar
Possibly yes. Cheap and easy to replace.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 04-12-2017, 11:32 AM   #12
Kristian's Avatar
Sway bar end links are infamous on these cars for this. Seems like you have it tightened all the way and itll still find a way to make noise. Either tighten them or get new ones if they keep doing it over and over
Kristian is offline   Reply With Quote
Lowered 96 Mustang Gt shocks Mosified 1996-2004 Mustang GT 16 01-23-2014 07:25 AM
Lowered with 19's vs lowered with 20's. Post your pics! Xedes Pictures and Videos 38 01-06-2014 10:02 AM
Lowered mustang sikstang03gt 1996-2004 Mustang GT 11 01-06-2013 12:13 PM
For a lowered 87 mustang, what are some shocks that will give me a less bumpy ride? Haav 1979-1995 Mustang GT 11 08-04-2012 04:05 PM
Lowered The Mustang robb15033 Pre-2005 V6 Mustang 25 09-21-2011 11:47 PM
02:14 AM
