New Product Development - Mustang Evolution
Old 12-17-2015, 07:38 AM   #1
alrefire's Avatar
Ladies, gentlemen,
This is a post in regards to a separate clutch fluid reservoir.
As I was collecting parts for my manual transmission swap, one of the things required was the brake reservoir from a manual car (since our cars use the same fluid for our brakes and clutch).
I read a thread over on svtp where they used a reservoir out of a gto, and it helped to eliminate/lessen the number of instances where the clutch pedal would stick under heavy braking. It also made changing brake fluid significantly easier, since you no longer have to drain from the rear passenger brake caliper.
I contacted jack Markgraf to see if he could develop one for me.
​​ He came through and developed it. It's $150, and includes mounting hardware, the cap, and the tube to your master cylinder. It also includes the cap for your brake fluid reservoir (since you won't have a line out for your clutch) It mounts on the inner fender.
The test one (pictured) is painted, but all of the future ones will be powdercoated.
Fits all 11-14 mustangs
I will be using this with my mt82 swap this weekend.
Contact Jack and order now.
Link to his page: https://m.facebook.com/profile.php?i...urce=typeahead
ID:	194900   Click image for larger version
Old 12-17-2015, 09:32 AM   #2
Voltwings's Avatar
I like it, i can see myself picking one up here soon.
Sight level is kind of useless though lol. Granted, you wont be bleeding the clutch nearly as often as the brakes.
Old 12-17-2015, 09:52 AM   #3
alrefire's Avatar
he can make it without the sight level for less
Old 12-22-2015, 01:26 AM   #4
alrefire's Avatar
Installed and it is fantastic.
Finished my mt82 swap as well. Details in other thread
Old 01-13-2016, 10:03 PM   #5
I saw the manual trans camaros are having the same problem with clutch peddles sticking to the floor. The attempt at using gto independent reservoirs seems to help only slightly. It seems that fluid contamination from clutch dust is the culprit. A remote bleeder from tick performance helps for easier changes but still have sticking clutches if not changed regularly. Looks like your reservoir is sufficient in volume to eliminate that problem. I am looking forward to your results.
masterguns95 is offline   Reply With Quote
Old 01-13-2016, 11:54 PM   #6
alrefire's Avatar
What result would that be? Haha
It's on my car right now.
The best news is I didn't have to swap brake reservoirs when I changed the trans. It looks cool (added bonus)
But I agree with you. The main issue is the clutch, line, and fluid type, all of which I plan on replacing... eventually.
Old 01-14-2016, 07:44 AM   #7
I just wonder why the industry can't seem to prevent the migration of the clutch dust into fluid. There has got to be a bunch of high dollar engineers working on it. I thought it was a GM thing. I think maybe there should be away to cycle the slave cylinder fluid to the reservoir allowing that fluid to cool and readily mix. Oh well. Interesting. I do like you reservior's good looks. Being new to here, is a remote bleed available for our mustangs?
Old 01-24-2016, 07:53 AM   #8
alrefire's Avatar
I forgot to post these pics.
ID:	196152   Click image for larger version
Old 01-25-2016, 10:28 PM   #9
alrefire's Avatar
UPDATE:
the Reservoir is now available for 110 shipped without the gauge on the side!
Old 01-26-2016, 01:59 PM   #10
CodyC's Avatar
Besides price, are there any advantages to this one over the Shelby remote reservoir? Also, from looking at the pictures it seems like the reservoir may interfere with aftermarket hood struts. Do you know if that is correct?
CodyC is offline   Reply With Quote
Old 01-26-2016, 03:44 PM   #11
alrefire's Avatar
I'm not 100% sure where aftermarket hood struts mount, but if they are an issue, you can mount the reservoir on the underside and get a longer bolt..
And in regards to the difference.. the Shelby one is 200 bucks and is plastic. This one is 110, is aluminum, and comes powdercoated black (or you can get it raw if you wish)
They serve the same function, it's just a matter of price and looks.
2015 Steeda Mustang Product Development Updates tj@steeda 2015 Mustang GT 0 10-14-2014 06:29 PM
Got NEW V6 exh. setup, existing Mfg., in development: RGR Pre-2005 V6 Mustang 62 02-14-2006 03:02 AM
New product soon to be available, POLY-HONE... RGR Pre-2005 V6 Mustang 38 10-07-2004 02:37 PM
NEW PRODUCT: Genuine leather armrest cover from RedlineGoods! RedlineGoods Mustang Audio & Video 4 08-25-2004 11:24 PM
06:28 AM
