OIL CHANGE TIME!! - Mustang Evolution
Old 03-07-2016, 09:06 AM   #1
Arrow OIL CHANGE TIME!!
Hello Stang lovers,
I just purchased a 2013 v6 with a price I could not reject! received at 25k, now at 34k Bailey (carname ) needs an oil change. My question for you guys is..... Should I use Royal Purple? Or just go straight to dealer and have them do all that good stuff for me.
Please let me know what you guys recommend, Or stories, new to this website and glad there's a big community so I can ask silly questions like this,
Thank you
Jay_Wolve is offline   Reply With Quote
Old 03-07-2016, 11:49 AM   #2
tym_v6's Avatar
If you want some 19 year old kid to maybe change your oil correctly, go to the dealer. Or, get some full syn oil and a filter and do it in your driveway. I use Mobil 1, but RP is fine too.
Old 03-07-2016, 12:25 PM   #3
etr3.7's Avatar
I went to the dealer once, it took 4 hours!!! That is why I do it myself. I use royal purple and can't complain,I have used it in every other vehicle I have owned.
etr3.7 is offline   Reply With Quote
Old 03-08-2016, 11:40 AM   #4
Mobil 1 Extended Performance oil, Napa Gold (WIX) filter. Done.
Old 03-09-2016, 02:27 PM   #5
Koryak's Avatar
If you're off warranty you can use Royal Purple HPS as it has more anti-wear additive than regular RP synthetic. If you drive lots of short trips then more frequent changes with any brand oil is better than expensive oil changed less often. In some cases 3 -4 k mile changes are not too often.
Koryak is offline   Reply With Quote
Old 03-18-2016, 01:18 PM   #6
I been maintaining my own car since the 70's so I done many oil changes tried many different oils and additives, I bought a 2014 mustang v6 in dec of 2014 it had 20,000 miles on it. It is the first car I ever used Royal purple in, I will never go back to anything else, my MPG went up, it seems to run smoother and cooler and when I drain the oil it is not gritty and is a lot cleaner then any other oil I have drained in the past. I am going to try their gear lube next
Logan541 is offline   Reply With Quote
Old 03-23-2016, 06:15 PM   #7
mustangphoenix's Avatar
Honestly, seems to me like you pay more for the same results. But as usual, thats only in my experience. Depends on the car and the way its driven.
Sent from my SM-G925V using Mustang Evolution mobile app
mustangphoenix is offline   Reply With Quote
Old 03-23-2016, 06:16 PM   #8
And I always do my own oil, idk. Dont think its worth paying a lot of money for something as simple as an oil change.
Old 03-23-2016, 08:16 PM   #9
People always say "I can get it done for $40 at the shop and that's what oil and a filter costs anyway". But they fail to realize that its some rando doing the change and "bulk oil" from a drum. I pay about $30 for 6 quarts of real high quality oil and $6 for a WIX filter and I KNOW its done correctly.
10% of people can properly maintain cars. And computers. Basically the 2 things we use more than anything these days. I do all my own work and build my own PCs. #soapbox
Old 03-24-2016, 10:06 AM   #10
Exactly. Well said.
Old 03-26-2016, 05:45 AM   #11
I'd never let any do ANYTHING on my cars I can do myself.
bodon is offline   Reply With Quote
Old 03-26-2016, 07:04 PM   #12
If you're do it yourself there's no surprises
FM758713 is offline   Reply With Quote
Old 03-27-2016, 03:12 PM   #13
Trevorhart3's Avatar
My thing is: how confident are you in your bike (or vehicle) at 200mph (or 140mph). Do your own work, be confident and in control of your own safety. That being said if you don't know how to do it, probably better a shop does.
Sorry for the conversion from super sport bikes to mustangs. Usually use that saying for bikes more.
What intervals do you guys run between oil changes? I usually do 3k to be on the safe side even though ford says 5k.
Trevorhart3 is offline   Reply With Quote
Old 03-27-2016, 03:27 PM   #14
jek57's Avatar
Save yourself some money do it yourself .I use mobile 1 15000 mile oil 6 qts for about 33 dollars ford filter 3 plus dollars Takes me about a hr plus you know that it done right..The extended might be overkill but i do it in the spring run it all summer till i put it up for the winter
jek57 is offline   Reply With Quote
Old 03-27-2016, 04:14 PM   #15
Senior Member
Spartanator's Avatar
I changed it myself in my 11 5.0
Never paying someone to lean on my car again. I am extremely paranoid about mine.... If it's your first time jacking the car off the ground make sure you know the proper jacking points. I have seen way too many people almost get crushed.
MT-82 hate.
Spartanator is offline   Reply With Quote
Old 03-27-2016, 04:48 PM   #16
About 6 months ago I bought a scissor lift from harbor freight it makes life soooo simple
Old 03-27-2016, 05:10 PM   #17
Senior Member
Thanks for making me jealous.....
MT-82 hate.
Old 03-27-2016, 05:30 PM   #18
$1341. shipped and put right in garage. I have 6 vehicles and work on friends cars but the real justification for buying it was my 2014 stang, I cant get it up ramps, and I need to use a scissor jack I also want to add a rear valance and paint calipers so I said; "treat yourself to a nice Christmas present." LOL
Old 03-27-2016, 05:34 PM   #19
Makes life easier.
Adventure till you drop.
Old 03-27-2016, 05:35 PM   #20
much
Old 03-28-2016, 06:43 PM   #21
heebe_geebe's Avatar
Being an old Iron Worker I modified my ramps to accept custom made aluminum tread plate removable extensions to decrease the angle of approach. They work great front or back. No more dragging.
ID:	198931   Click image for larger version
2014 MCOA, V6 PREMIUM, PERFORMANCE PACKAGE, COMFORT PACKAGE, SECURITY PACKAGE, DEEP IMPACT BLUE WITH SILVER CUSTOM COBRA STYLE STRIPES, AIRAID TUBE, TINTED 35%, PIONEER 8000 NEX, REAR CAMERA, BORLA TOUR AXLE BACK, K&N FILTER. JLT OIL CATCH CAN, CUSTOM MADE HOOD STRUTS, BBK SHORTY CERAMIC
heebe_geebe is offline   Reply With Quote
Old 03-29-2016, 04:33 PM   #22
Agreed.
From another person who does his own car maintenance as well as desktop and laptop computers.
nanobyte is offline   Reply With Quote
Old 04-02-2016, 04:10 PM   #23
Region: New Mexico
I watched a video about changing oil on a 2011-14 GT and it looked a little messy because of a tray under the oil filter. Someone said use a gallon baggie around the filter to catch the spills. Do you guys find it messy or not bad if you're careful. Asking since this is new car to me first Mustangs.
WoodDA is offline   Reply With Quote
Old 04-03-2016, 05:33 AM   #24
2011 Kona Blue's Avatar
Its really not that bad. Yes, some oil does get on the tray, just wipe it off. Not a big deal.
Just a near stock 3.7
Old 04-03-2016, 05:49 AM   #25
dave73's Avatar
Yeah it's not really a big deal a little gets on the tray just wipe it off.
dave73 is offline   Reply With Quote
Old 04-03-2016, 12:20 PM   #26
Words of wisdom. Wipe it off. Ha ha ha.
Old 04-03-2016, 12:28 PM   #27
dave73's Avatar
Ok well don't then
Try adding this to your oil next oil change Joe Dirt 222 General Mustang Discussion 18 05-23-2015 01:04 PM
Smell oil burning thru interior air vents after oil change dentman43 2011-2014 Mustang GT 7 10-27-2014 08:36 AM
First oil change what oil sinister 2011-2014 Mustang GT 48 08-18-2014 07:57 AM
Oil Change Time 93mstnglx 2.3 Mustang 7 12-13-2012 09:55 AM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
06:39 AM
