Rattle in auto dimming mirror - Mustang Evolution
Old 04-13-2016, 07:33 AM   #1
!st time mustang owner, 2012 v 6 premium. how have most folks fix the rattle in the mirror, its not the mount to the windshield but the middle seam has some play in it. Thanks
Andy G is offline   Reply With Quote
Old 04-13-2016, 08:47 AM   #2
You can cut and squeeze a small o ring around it between the base and the glass.
Sent from my LG-D850 using Tapatalk
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 04-13-2016, 12:29 PM   #3
WJBertrand's Avatar
Middle seam? Please describe.
My mirror rattles terribly since installing a sub woofer in the trunk. The mount to the windscreen seems solid, no play there. The rattle seems to come from the mirror assembly itself. If I could feel some screws on the back of it I'd disassemble it and stuff some foam or something in there. My car has the auto dimming and I think the compass antenna inside it.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 04-13-2016, 12:50 PM   #4
In-between the windshield and base of the mirror against the windshield.
Old 04-13-2016, 05:20 PM   #5
Does any body know if the auto dimming mirror can be opened up.I'm sure I could fix the rattle then. I can squeeze the top &: bottom with my hand and it quits. But bracket to the windshield is Solid.
Old 04-13-2016, 06:29 PM   #6
WJBertrand's Avatar
This is my exact scenario.
-Jeff-
Ventura, CA
Old 04-14-2016, 11:37 AM   #7
Mine was rattling and what I described above was the remedy. Would stop if I put my hand on the mirror as well.
Old 04-15-2016, 10:24 AM   #8
WJBertrand's Avatar
Worth a try then I guess. Did your's actually have some play or movement there at that point? Mine seems solid but the rubber buffer may be serving as a damper.
-Jeff-
Ventura, CA
Old 04-15-2016, 02:36 PM   #9
It seemed solid as well but some googling this issue landed me on that solution and it worked.
Old 05-12-2016, 05:07 PM   #10
Update on 2012 "Rattle in auto dimming mirror"
FIXED IT by carefully splitting open at the middle seam, cutting a few pieces of the peel & stick weather strip foam tape on either side of the main P C board. Then snapping it all back together.
Old 05-12-2016, 05:39 PM   #11
WJBertrand's Avatar
What did you use to split it open? Did you take any photos? I have some of those plastic pry tools I thought I might try. I did stick some pieces of Dynamat to the tops and bottom of the mirror as a test but it made no difference at all.
-Jeff-
Ventura, CA
Old 05-12-2016, 07:23 PM   #12
Used a med. Flat blade screwdriver w/ pc. Of tape covering the tip, be forewarned the outer plastic case is kinda soft and can leave a impression at the seam, I started at the top and worked my way down Me , I was fixing this or replacing it .
Old 06-01-2016, 10:49 PM   #13
Azr2stang's Avatar
I had the same problem. Took it back to the dealer and they replaced the mirror and have not had a problem since. This must be a common problem.
Azr2stang is offline   Reply With Quote
For Sale: 07-09 GT500 Rear View Mirror - Compass - Auto Dimming Mean14 Mustang Parts for Sale and Wanted 1 11-01-2015 01:37 PM
Dimming lights TonyAvallone General Mustang Discussion 1 08-25-2014 02:21 AM
Tint Question and auto dimming mirror StarzTA17 Mustang Paint, Appearance & Detailing 1 06-03-2014 09:00 AM
Headlights dimming... Project Pony Pre-2005 V6 Mustang 3 08-02-2011 05:52 PM
dimming lights NHStang03 1996-2004 Mustang GT 2 10-12-2008 11:40 PM
09:04 PM
