Building up the Mach 1 motor - Mustang Evolution
Old 04-20-2016, 08:43 PM   #1
LaserRed99's Avatar
It finally happened, I spun a bearing! So... I'm about to have the thing rebuilt with the good stuff. Manley rods and Diamond pistons, and a good crank if mine turns out to be damaged. This is as long as cylinder walls aren't messed up. Otherwise, I'm just getting a Livernois 4v shortblock.
I'll be maxing out the P1SC, hoping for 600 rwhp. My shop seems to think my TR3650 will hold up to it for a reasonable amount of time as long as I'm not doing any powershifting. Thoughts on that?
Anyway I'm excited... maybe next year I'll get a D1 upgrade and get some more boost.
'03 Mach 1 5spd
Fully forged Manley rods/pistons, Cobra crank, ARP hardware, 8.5:1, Procharger P1SC w/ intercooler, AFM power pipe, 60# injectors, 03/04 Cobra tank with dual fuel pumps, Kenne Bell Boost-a-Pump, O/R X pipe and Flowmasters, Exedy stage 3 clutch, Steeda Tri-Ax, Front and rear upper + lower control arms, Ford Racing springs, Bob Monks tune 448 rwhp @ 9 PSI
LaserRed99 is offline   Reply With Quote
Old 04-22-2016, 02:24 PM   #2
Send a message via AIM to Destination S19
You can break a stock 3650 with 300hp. Going easy might help but it's a time bomb waiting to go off.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Building new motor for 7up lowflyn 1979-1995 Mustang GT 82 06-06-2017 07:10 AM
blown 99 gt motor puting in a 2000 gt motor derrickk 1996-2004 Mustang GT 9 07-12-2015 12:05 PM
No 4v, building new pushrod motor instead 93slowstang 1979-1995 Mustang GT 29 07-23-2012 05:19 PM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
06:07 PM
