Cobra problems - Mustang Evolution
Old 05-03-2016, 02:51 PM   #1
Tplanck's Avatar
Cobra problems
Hey guys I got a 1997 cobra and I have been having some trouble with it. When I'm driving down the road and I go from let's say 4th or 5th to neutral the rpms drop all the way down to 0. In better terms it dies. But if I tap the gas real fast right after I put it in neutral it will be fine and not die. Any ideas on what this could be? Thanks
Tplanck is offline   Reply With Quote
Old 05-04-2016, 07:22 PM   #2
Tplanck's Avatar
Help anyone?
Old 05-04-2016, 07:37 PM   #3
IAC? Replace with an OEM one (rockauto) and see if that fixes it.
Old 05-04-2016, 07:50 PM   #4
Tplanck's Avatar
I will try that. Less than 4000 miles ago I cleaned the IMRCs and throttle body. It's got fresh plugs, but the wires and coil packs are still the factory ones. Car has 110k on it
Old 05-04-2016, 09:39 PM   #5
Coil packs should not be an issue but wires... yeah... that could do it.
Old 05-07-2016, 08:53 PM   #6
Tplanck's Avatar
Hey man I'm getting a new clutch put in and I was wondering is you knew if this flywheel would fit my cobra. I know it say 05-09 mustang but I'm pretty sure since it's an 8 bolt it will fit Click image for larger version
Name:	ImageUploadedByMustang Evolution1462676004.153024.jpg
Old 05-08-2016, 10:32 AM   #7
That will fit and is correctly weighted. You may have to punch out the dowel pins and install yours or new ones.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 06-07-2016, 02:57 PM   #8
Tplanck's Avatar
Any tips on how to get the top bolts on the bell housing off. They are just plain stuck. Been working on the for about 6 hours
Old 06-07-2016, 03:14 PM   #9
4 feet of 1/2" extensions, universal on the socket going to the bolt. Big breaker bar with a piece of pipe on it for leverage. Have a buddy on the breaker while you have a hand up there keeping the socket flush.
Old 06-13-2016, 06:29 PM   #10
Tplanck's Avatar
Hey man, couldn't get the bolts out.. Tried everything. So I have to have it towed to a shop. I have the driveshaft out. It's it going to be okay to get it towed on a flatbed truck with it out?
Old 06-13-2016, 08:38 PM   #11
Yeah it'll be fine. Did you round the bolts off or something? If you can still get a good bite on the bolts they'll come out with a breaker bar and a pipe on the end of that. If you are on your back in the driveway I guess it could be an issue... I always do them on a lift.
You can also pull the intake manifold and the top 2 bolts will be right there easy to get to from the top if you don't feel like towing it.
Old 06-13-2016, 09:49 PM   #12
Tplanck's Avatar
Sadly I don't have a lift. I will try to get to them from the top side then. Even with a breaker bar and extensions they wouldn't break free. I have never seen anything like it
Old 06-14-2016, 06:00 AM   #13
Spray the **** out of them with liquid wrench. And then get the breaker and put a piece of pipe onto the breaker to get even more leverage. You'll either snap the bolt head off or remove it... or round it off...
When I did the trans on my 98 We had a solid 30" of leverage with the breaker bar to pop off one of the bolts, that sucker was stuck. Loud pop and creak when it finally let go.
Problems and more problems BigB227 1996-2004 Mustang GT 1 08-22-2012 09:12 AM
99 Cobra idling problems, help =( nasty99 1996-2004 Mustang GT 7 03-03-2011 04:40 PM
95' Cobra SVT Problems xspektrex 1979-1995 Mustang GT 43 01-19-2011 11:42 AM
Tranny problems with my 97 Cobra Sparkdic 1996-2004 Mustang GT 0 04-28-2010 06:38 AM
1997 Cobra tranny problems oojdbozoo 1996-2004 Mustang GT 5 05-13-2009 12:57 AM
12:07 AM
