SR lowering springs - Mustang Evolution
Old 05-22-2016, 07:25 PM   #1
SR lowering springs
I want the handling gain from the springs but I am very much worry abt the driveshaft issue and also the front end hit parking blocks. Anyone have those can share some informations please?
lzy54610 is offline   Reply With Quote
Old 05-22-2016, 07:37 PM   #2
DiESeven's Avatar
If you're talking about clearing the driveshaft - No issues whatsoever.
Hitting parking blocks - That's not something the springs are going to control lol... That's up to you to not pull in to the spot too much.
Old 05-22-2016, 10:32 PM   #3
LeoGTCS's Avatar
+1
2014 Mustang GT/CS Silver
K&N CAI- Barton Shifter/2Post- Koni yellows & SR springs- Whiteline Suspension- Pypes pypebomb super system
2014 Explorer Sport Ruby Red
LMS 93 Performance-3 Bar V4 tune-160*Tstat-SP534 plugs-Windstorm-H&R Exp Springs
LeoGTCS is offline   Reply With Quote
Old 05-22-2016, 10:56 PM   #4
TRMN8ER's Avatar
No driveshaft issues and the springs will not lower your front end enough to hit a parking curb. I clear by roughly half an inch.
TRMN8ER is offline   Reply With Quote
Old 05-23-2016, 04:36 AM   #5
Strange Mud's Avatar
you will want to consider other parts too....shocks/adj panhard bar/lca relocating bkts. Suspension is not something to do 1/2 way.
I put SR's on mine and am happy but I haven't pulled too far up on the parking blocks.
New England Cruise June 3rd!
see regional forum for details
http://www.mustangevolution.com/foru...post4261510322
Old 05-23-2016, 06:16 AM   #6
LeoGTCS's Avatar
Effectively, you'll need at least the Panhard bar if you don't track it. when I did mine, the diff shifted by an inch so it really is needed. And definitely some camber bolts if not plates.
Old 05-23-2016, 09:46 AM   #7
noldevin's Avatar
Definitely do the panhard bar. Shocks/struts, LCAs and relocation brackets are recommended as well.
I have the BMR handling springs which are about the same drop as the SR springs. I have pulled into a few spots too far and my splitter is barely a milimeter above the curb. Some curbs are higher than others so you'll definitely want to be extra careful parking.
noldevin is offline   Reply With Quote
Old 10-05-2016, 05:50 AM   #8
Noodles76's Avatar
What is the issue with the lca and relocation brackets? Are these a must when lowering the car with eibach pro kit springs?
IG: 14gt5oh
Noodles76 is offline   Reply With Quote
Old 10-05-2016, 05:57 AM   #9
LeoGTCS's Avatar
They are not necessary but they are a must. When you lower the car with any brand of springs you are messing with the car suspension geometry. If you track the car, your traction would be extremely poor. By adding Relo beakers, you'll bring back the correct geometry of the rear suspension resulting in better traction. Hope that helps.
Old 10-05-2016, 06:01 AM   #10
jkeaton's Avatar
So if you don't track your car, then they would not be needed? I'd like tom lower mine an inch or so. Daily driver. I was told I MAY only need caster/camber plates.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 10-05-2016, 08:04 AM   #11
LeoGTCS's Avatar
If you are not gonna be abusing your car, daily running speed limits, your car will survive for sure without them.
Lowering springs or factory springs fordracing63857 1979-1995 Mustang GT 3 06-27-2012 08:42 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
Bushings for lowering springs Blue232 Pre-2005 V6 Mustang 10 10-09-2003 12:33 PM
Where can i get lowering springs (01' Vert) Stang01 Pre-2005 V6 Mustang 3 09-30-2003 10:44 AM
Lowering Springs -- How Much? Stang01 Pre-2005 V6 Mustang 7 09-20-2003 12:07 PM
04:56 AM
