1999 V6 MPG - Mustang Evolution
Old 08-17-2016, 11:43 AM   #1
1999 V6 MPG
So... I have this 1999 v6 5 speed mustang that's been setting in our garage for about 5 years. It has 134,000 miles. I just put in a new fuel pump, fuel filter, k&n cai, cleaned throttle body with throttle body cleaner, cleaned maf sensor with maf cleaner, replaced the 15" stock wheels/tires with 17" x 9" ford cobra r wheels with 245/45/17 on front and 255/55/17 on back and the best wheel alignment garage in the area performed the wheel alignment. The spark plugs and wires were replaced 6,000 miles before putting in garage. I've now ran 3 tanks of gas through the car.
I sold my van and decided to put this mustang back on the road to drive to and from work. The car used to get anywhere from 24-27 mpg depending on how heavy your foot is prior to putting it in the garage. Now its getting 20-21 with driving around like there is a egg between my foot and the gas pedal.
Would those wheels/tires make that big of a difference?? If so they are gonna have to go! lol
ID:	204264   Click image for larger version
KirkComer is offline   Reply With Quote
Old 08-18-2016, 12:51 AM   #2
Revvv's Avatar
I doubt the wheels are going to cause a fuel mileage issue. You should see the same mpg as with the factory 15s.
I love those wheels. I tried to talk a guy down the road from me out of his. I wanted to trade my Bullitts for his Cobra wheels.
Old 08-18-2016, 05:36 AM   #3
Strange Mud's Avatar
if you can swap back and re-check mpg. other ideas tire pressure or is the od different enough where your odometer is off? you can check by comparing speed to a GPS long shot idea but on mine I have 2 sets with a 3/4" OD difference on mine that is a 3% odometer/speedometer error
"every one of you was going 50"
Old 08-18-2016, 08:52 AM   #4
Revvv's Avatar
I didn't think about two different tire sides between the two.
Old 08-18-2016, 11:41 AM   #5
Unfortunately the 15" tires were dry rotted and one actually blew out before I got these wheels and tires so I can't put them back on to make a comparison.
I added a bottle of lucas fuel injector cleaner on my last fillup and I'm also not turning on the air conditioner during this current tank. When my speedometer shows 55 mph ... my gps shows 52 so 3 mph difference but wouldn't that reflect more mpg from the odometer compared to actual? For example if I drove for one hour and used 2 gallons of gas:
55 miles/2 gallons=27.5 (according to speedo/odometer)
52 miles/2 gallons=26.0 (according to gps)
So... my fuel milage is even worse than the 20-21 mpg I have been calculating over the past 3 tanks.... wow
It's hard for me to believe that the tires are making that much of a difference but maybe it is. The first tank of gas came from citgo and the last two tanks have came from wal-mart. My next fillup will be at a exxonmobile or texaco to see if that makes any difference. So if my math is correct here is the difference in tires.
Old 08-18-2016, 11:43 AM   #6
Revvv's Avatar
Cheap gas makes a difference.
Old 08-18-2016, 11:59 AM   #7
when you put in the plugs had you checked mpg afterwards (long time ago) are they correct plugs/gap?
I want to make a funny about how gas was better back in the day....I wonder if it's the ethanol in it?
I will say the new rims look good
Old 08-18-2016, 12:06 PM   #8
I had a 2002 Pontiac Montana Mini-Van. No matter where I got gas for 15 years (I tried them all) I always got between 22-23 mpg. Maybe this mustang is more picky on fuel. I was hoping to do better on gas than the van did. Thanks for the comments. I'll update the thread on how my next couple of tanks go.
Old 08-18-2016, 12:11 PM   #9
When they were changed it did not make a difference in mpg back then. Maybe I'll put in a new set just to see it if helps.
Maybe the gas has gotten worse in 5 years.lol Could be the plugs need changing just from setting... idk The wheels and tires do look really good but they may have to go... or maybe the whole car for that matter. lol
Old 08-19-2016, 04:35 PM   #10
Project Pony's Avatar
My 03 had no problem hitting 29 on the highway. It's had 255s front and rear. Maybe installing all new everything played a bigger factor for me. And I really mean everything...that car was better than new when it got sold.
Sent from my SAMSUNG-SM-G920AZ using Mustang Evolution mobile app
[SIGPIC][/SIGPIC]
05-09 GT mpg vs 99-04 GT mpg GP3GT 2005-2010 Mustang GT 10 05-03-2013 04:08 PM
MPG-MPG insidious_ruin 2011-2014 Mustang GT 26 07-19-2012 08:18 AM
1999 GT 35 year Anniversary :: 1999 Ford Loraco Member Garages 0 06-15-2011 01:01 PM
MPG update Ponycarman The Bar 16 01-09-2005 11:23 PM
02:43 AM
