I forgot about this thread, but I can offer this.
On your browser type in "whois.net"
Then do a search for "speedconcepts.net"
A much more in depth logging for them is with a terminal.
I don't know if a PC will work like this, but on a Mac/Linux/Unix machine, start the terminal and type in "whois speedconcepts.net"
and you will get a ton if info on them. The following is what I saw today.
You might be able to reach them through GODADDY.COM, or perhaps one of the email addresses or phone numbers below.
- - - results start here - - -
Whois Server Version 2.0
Domain names in the .com and .net domains can now be registered
with many different competing registrars. Go to
InterNIC | The Internet's Network Information Center
for detailed information.
Domain Name: SPEEDCONCEPTS.NET
Registrar: GODADDY.COM, LLC
Sponsoring Registrar IANA ID: 146
Whois Server: whois.godaddy.com
Referral URL:
http://www.godaddy.com
Name Server: NS509.WEBSITEWELCOME.COM
Name Server: NS510.WEBSITEWELCOME.COM
Status: clientDeleteProhibited
https://icann.org/epp#clientDeleteProhibited
Status: clientRenewProhibited
https://icann.org/epp#clientRenewProhibited
Status: clientTransferProhibited
https://icann.org/epp#clientTransferProhibited
Status: clientUpdateProhibited
https://icann.org/epp#clientUpdateProhibited
Updated Date: 31-mar-2016
Creation Date: 19-feb-2002
Expiration Date: 19-feb-2017
>>> Last update of whois database: Mon, 24 Oct 2016 04:00:11 GMT <<<
For more information on Whois status codes, please visit
NOTICE: The expiration date displayed in this record is the date the
registrar's sponsorship of the domain name registration in the registry is
currently set to expire. This date does not necessarily reflect the expiration
date of the domain name registrant's agreement with the sponsoring
registrar. Users may consult the sponsoring registrar's Whois database to
view the registrar's reported date of expiration for this registration.
TERMS OF USE: You are not authorized to access or query our Whois
database through the use of electronic processes that are high-volume and
automated except as reasonably necessary to register domain names or
modify existing registrations; the Data in VeriSign Global Registry
Services' ("VeriSign") Whois database is provided by VeriSign for
information purposes only, and to assist persons in obtaining information
about or related to a domain name registration record. VeriSign does not
guarantee its accuracy. By submitting a Whois query, you agree to abide
by the following terms of use: You agree that you may use this Data only
for lawful purposes and that under no circumstances will you use this Data
to: (1) allow, enable, or otherwise support the transmission of mass
unsolicited, commercial advertising or solicitations via e-mail, telephone,
or facsimile; or (2) enable high volume, automated, electronic processes
that apply to VeriSign (or its computer systems). The compilation,
repackaging, dissemination or other use of this Data is expressly
prohibited without the prior written consent of VeriSign. You agree not to
use electronic processes that are automated and high-volume to access or
query the Whois database except as reasonably necessary to register
domain names or modify existing registrations. VeriSign reserves the right
to restrict your access to the Whois database in its sole discretion to ensure
operational stability. VeriSign may restrict or terminate your access to the
Whois database for failure to abide by these terms of use. VeriSign
reserves the right to modify these terms at any time.
The Registry database contains ONLY .COM, .NET, .EDU domains and
Registrars.
Registry Domain ID: 83761672_DOMAIN_NET-VRSN
Registrar WHOIS Server: whois.godaddy.com
Registrar URL:
Update Date: 2015-03-17T15:03:23Z
Creation Date: 2002-02-19T01:39:27Z
Registrar Registration Expiration Date: 2017-02-19T01:39:27Z
Registrar: GoDaddy.com, LLC
Registrar Abuse Contact Email:
abuse@godaddy.com
Registrar Abuse Contact Phone: +1.4806242505
Domain Status: clientTransferProhibited
http://www.icann.org/epp#clientTransferProhibited
Domain Status: clientUpdateProhibited
http://www.icann.org/epp#clientUpdateProhibited
Domain Status: clientRenewProhibited
http://www.icann.org/epp#clientRenewProhibited
Domain Status: clientDeleteProhibited
http://www.icann.org/epp#clientDeleteProhibited
Registry Registrant ID: Not Available From Registry
Registrant Name: Registration Private
Registrant Organization: Domains By Proxy, LLC
Registrant Street: DomainsByProxy.com
Registrant Street: 14747 N Northsight Blvd Suite 111, PMB 309
Registrant City: Scottsdale
Registrant State/Province: Arizona
Registrant Postal Code: 85260
Registrant Country: US
Registrant Phone: +1.4806242599
Registrant Phone Ext:
Registrant Fax: +1.4806242598
Registrant Fax Ext:
Registrant Email:
SPEEDCONCEPTS.NET@domainsbyproxy.com
Registry Admin ID: Not Available From Registry
Admin Name: Registration Private
Admin Organization: Domains By Proxy, LLC
Admin Street: DomainsByProxy.com
Admin Street: 14747 N Northsight Blvd Suite 111, PMB 309
Admin City: Scottsdale
Admin State/Province: Arizona
Admin Postal Code: 85260
Admin Country: US
Admin Phone: +1.4806242599
Admin Phone Ext:
Admin Fax: +1.4806242598
Admin Fax Ext:
Admin Email:
Registry Tech ID: Not Available From Registry
Tech Name: Registration Private
Tech Organization: Domains By Proxy, LLC
Tech Street: DomainsByProxy.com
Tech Street: 14747 N Northsight Blvd Suite 111, PMB 309
Tech City: Scottsdale
Tech State/Province: Arizona
Tech Postal Code: 85260
Tech Country: US
Tech Phone: +1.4806242599
Tech Phone Ext:
Tech Fax: +1.4806242598
Tech Fax Ext:
Tech Email:
DNSSEC: unsigned
URL of the ICANN WHOIS Data Problem Reporting System:
http://wdprs.internic.net/
>>> Last update of WHOIS database: 2016-10-24T04:00:00Z <<<
https://www.icann.org/resources/pages/epp-status-codes-2014-06-16-en
The data contained in GoDaddy.com, LLC's WhoIs database,
while believed by the company to be reliable, is provided "as is"
with no guarantee or warranties regarding its accuracy. This
information is provided for the sole purpose of assisting you
in obtaining information about domain name registration records.
Any use of this data for any other purpose is expressly forbidden without the prior written
permission of GoDaddy.com, LLC. By submitting an inquiry,
you agree to these terms of usage and limitations of warranty. In particular,
you agree not to use this data to allow, enable, or otherwise make possible,
dissemination or collection of this data, in part or in its entirety, for any
purpose, such as the transmission of unsolicited advertising and
and solicitations of any kind, including spam. You further agree
not to use this data to enable high volume, automated or robotic electronic
processes designed to collect or compile this data for any purpose,
including mining this data for your own personal or commercial purposes.
Please note: the registrant of the domain name is specified
in the "registrant" section. In most cases, GoDaddy.com, LLC
is not the registrant of domain names listed in this database.
